Old Aug 25, 2011, 03:25 PM
JLogan is offline
Find More Posts by JLogan
AMA#313760
JLogan's Avatar
United States, MI, Taylor
Joined May 2009
Originally Posted by Manu Simon View Post
Always nice to see in flight pics of this little jewel
John, may I suggest a bit of touchup paint on your horn/clevis
Those white spots are the only details that need to be corrected !
Thank You Manu,
Replacement of all the stock clevis is in order. Already have the Spring Steel Kwik-Links clevis installed on the elevator's and I will replace the others as well. I'm still thinking of the Langing gear struts, they need to go. As we already seen the Robart 652R/652L Struts work well on this mustang. The tail retract may need to go altogether, still looking for a way to get the backward sweep
John
JLogan is offline Find More Posts by JLogan
Old Aug 25, 2011, 03:57 PM
ALL American is offline
Find More Posts by ALL American
It's Not Too Windy...Man Up
ALL American's Avatar
USA, CT, Wallingford
Joined Oct 2009
I agree John and have already started replacing my clevises with Sullivan Gold N' Clevises. Are the Kwik Links black? If so, maybe I'll use them.
Here's what I did about the struts.
http://static.rcgroups.net/forums/at...g?d=1313696034
http://static.rcgroups.net/forums/at...g?d=1313695888
I modified the fixed gear struts that came with the P51B and attached the gear doors with nylon landing gear straps (both the flat and the U shaped) and spaced them with nylon spacers. I still have to paint the screw heads so they're less obtrusive but the modified struts have performed well for the three flights I have on them.
Here's how I corrected the tail retract issue.
http://www.rcgroups.com/forums/showthread.php?t=1471800
Regards,
Anthony
ALL American is offline Find More Posts by ALL American
Old Aug 25, 2011, 04:09 PM
EricClark is offline
Find More Posts by EricClark
AMA - 734492
EricClark's Avatar
United States, MT
Joined Mar 2007
Anthony,
That is a great mod for the stock gear. Looks much better!
Eric
EricClark is offline Find More Posts by EricClark
Old Aug 25, 2011, 08:12 PM
JLogan is offline
AMA#313760
JLogan's Avatar
Joined May 2009
Regards,
Anthony
Yes the Kwik Links are Black. The other mods you did look outstanding.
Horizon's R&D for the MCPx helicopter is working very hard to make upgrades to make the helicopter fly better(Outstanding), now if they would only work on the fixed wing aircraft like this outstanding p-51b. I'd buy the new upgrade 51 like right now.
Old Aug 26, 2011, 08:33 AM
Joined Oct 2009
Originally Posted by EricClark View Post
Anthony,
Eric
Thank You Eric and John.
The E Flite provided fixed gear struts were staring me in the face as a better alternative than the struts with reversed axles. I had to shorten the top of the struts by 1/8" and grind a new flat, then I had to re-bend the struts so the wheels sat deeper in the wells. I never liked the stock gear door attachment and had planned on using landing gear straps and screws from the onset. I used nylon washers of various thickness to accommodate the struts sitting deeper in the wells.
Great minds think alike! At the time I had posted initial photos of my tinkering with this mod http://www.rcgroups.com/forums/showp...postcount=1314 one of our most esteemed members had contacted me because he had already completed the same mod. He shared the method and the issues he had encountered while completing this mod. The gear doors on his P51B look better than mine because the hardware is hidden from view, versus the screw heads on the outside of my P51B's gear doors.
Once the hurricane has passed, I'll post some close up pictures of the main gear and how I attached the gear doors. Right now, I'm already in my bunker LOL
If anyone uses Oleo struts, please post your results.
Regards,
Anthony
Old Aug 26, 2011, 11:28 AM
V2rider is offline
Find More Posts by V2rider
V2rider's Avatar
USA, MD, Hagerstown
Joined Jun 2009
Regards,
Anthony
It's the calm before the storm, looks like you have the same weather I do here today. last chance to fly before all breaks loose.
V2rider is offline Find More Posts by V2rider
Old Aug 26, 2011, 12:47 PM
Joined Oct 2009
I'm off to the field now... LOL
Regards,
Anthony
Old Aug 26, 2011, 01:32 PM
Tom Hunt is offline
Find More Posts by Tom Hunt
got any foam to bash?
Tom Hunt's Avatar
Lake Grove,LI, NY
Joined Aug 2000
Yup, I wen't out this morning, beautiful! Did not bring the stang today though.
Tom
Tom Hunt is offline Find More Posts by Tom Hunt
Old Aug 26, 2011, 01:51 PM
SmokeDogg is offline
Find More Posts by SmokeDogg
"Fly Low, Fly Fast, Turn Left"
SmokeDogg's Avatar
United States, CA, Red Bluff
Joined Jul 2009
I wish all you guys the best over there...
SmokeDogg is offline Find More Posts by SmokeDogg
Latest blog entry: Miss Foxy Lady eBuild
Old Aug 26, 2011, 04:34 PM
capteasy is offline
Find More Posts by capteasy
capteasy's Avatar
USA, Texas Hill Country
Joined May 2008
..... second that. Hoping all will be a non event.
capteasy is offline Find More Posts by capteasy
Old Aug 27, 2011, 04:14 PM
Joined Oct 2009
Yesterday, I flew my P51B three times. The more I fly it the more I like it. One of my landings was very fast and after setting the wheels down on the grass she began tipping forward so I added some more up elevator and she went airborne again. About a foot off the ground all I could think was "OH NO" but I increased the throttle a bit to avoid a stall and I touched down a little further up the runway for a nice landing. On that landing I didn't get to the flap switch quick enough and it's important to get those flaps back up as soon as this bird is on the ground. Either that or I need to slow my landing down quite a bit. All-in-all, my P51B's first six flights have been successful and uneventful.
On one 5 minute flight I guess I must have flown more aggressively and I wound up putting 3400 Mah back into a 4000 Mah pack. The pack was warm, not hot and it was at 3.65 volts per cell after the flight. I never run my packs down that far. I am flying with an APC 13 X 8E prop, E Flite Power 32 and a Gens Ace 4S - 4000 MAh 25C-50C pack. The plane is fast and the power system smooth so it's easy to get carried away.
Everyone in the path of the Irene, stay safe and good luck!
Regards,
Anthony
Old Aug 27, 2011, 04:24 PM
V2rider is offline
V2rider's Avatar
USA, MD, Hagerstown
Joined Jun 2009
Regards,
Anthony
Now aren't you glad you came back out of the bunker? I took my own advice and went out yesterday for the H9 Corsair maiden. Forgot to bring my second 5000ma pack though. The maiden went so well I had to hang out and recharge at the field for a second flight. Yet another great flying plane offered up from HH. Now that it's done I can start putting together my second b.
Note to self. Double check control throws this time.
Old Aug 27, 2011, 04:31 PM
Joined Oct 2009
Congrats on the successful maiden of your Corsair.
Now that my B is flying I have to choose between the 63" Top Flite P47 or the Hangar 9 65" P47. I like the Top Flite because it looks more true scale and it already has a battery hatch
Regards,
Anthony
Old Aug 27, 2011, 04:52 PM
V2rider is offline
V2rider's Avatar
USA, MD, Hagerstown
Joined Jun 2009
I love the P-47. If I didn't already have the H9 150 size I would go for the Top Flite version. The hatch already being there is a huge plus. I have a VQ p-40 that I have to put a hatch in. No way am I going to deal with removing a wing to get at the packs.
Old Aug 27, 2011, 07:37 PM
JLogan is offline
AMA#313760
JLogan's Avatar
Joined May 2009
Regards,
Anthony
Top Flite!!!!!!!! All the way. I have a gold kit p-47 and she flys very well.
John
Discussion E-Flight Platinum series P-51b nitro_star Scale Kit/Scratch Built 2 Aug 27, 2010 04:09 PM
Question E-flite p-51b RCDestroyer Electric Plane Talk 4 Aug 26, 2010 12:10 PM
Sold ESM P-51B Mustang - "Frank Tiano Series" mustang1971 Aircraft - Fuel - Airplanes (FS/W) 8 Jun 06, 2010 02:32 PM
For Sale Nib E-flite platinum series AT-6 Texan w/ optional accsry's lavochkin Aircraft - Electric - Airplanes (FS/W) 8 Mar 31, 2009 06:51 PM
For Sale NEW - Top Flite P-51B Mustang #RARE# JimJams Aircraft - Fuel - Airplanes (FS/W) 5 Apr 13, 2006 05:17 AM
