Aug 27, 2010, 03:37 PM
NorthBend/Coos Bay,Oregon USA
Joined Dec 2009
Originally Posted by vintage1
If the pack will fit just behind the former the gear is laced to, put it there.
servos easy: 1/4 sq spruce rails across fuselage near CG. Access via wing
Lightweight push rods or snakes to tail.
rx somewhere in a balsa box ..
Or you can make a servo/RX tray out of 1/8" balsa with 1/16" ply strips to take screws..glue under lower window frame.
Thanks Vintage, yes, the battery will fit against the firewall with velcro, and make a hatch. A Rx / servo tray made of 1/16 balsa with 1/16 ply strips at the c.g. under the wing. Kevlar pull pull on the elevator and rudder.
Scott
