Old Jan 12, 2013, 06:43 AM
skyhawk newbie is offline
Find More Posts by skyhawk newbie
Not a newbie anymore..
skyhawk newbie's Avatar
Ireland, Cork
Joined Oct 2010
Just passed my A Cert, flying my WOT4 FoamE...
Sean
skyhawk newbie is offline Find More Posts by skyhawk newbie
Old Jan 31, 2013, 06:42 PM
electricgeoff is offline
Find More Posts by electricgeoff
electricgeoff's Avatar
United Kingdom, England, Lincs
Joined Apr 2011
Sean
According to our examiner, it is good enough to get your 'B' on too.
Well done
E G
electricgeoff is offline Find More Posts by electricgeoff
Old Jan 31, 2013, 07:10 PM
Ireland, Cork
Joined Oct 2010
Well done
E G
Thanks....Thats handy to know...
I would think that the A and B cert would be the same in both the UK and Ireland..
Sean
Old Feb 07, 2013, 02:55 PM
Joined Apr 2011
Sean
Do you use BMFA rules there too, otherwise it could be different.
'B' here is: -
Carry out pre flight checks according to BMFA Safety Codes.
Take off and fly left or right hand circuit and overfly the takeoff area.
Fly figure 8 at constant height, with crossover infront of pilot.
Fly into wind and complete 1 inside loop.
Fly downwind and complete outside loop (bunt) from the top.
Complete 2 consequtive rolls into wind.
Complete 2 consequtive rolls downwind with opposite rotation to above.
Complete stall turn, left or right.
Gain height enough to complete a 3 turn spin, must fall into spin, not aileron powered.
Fly rectangular landing approach, then overshoot from below 10ft.
Fly a rectangular circuit, reverse direction of abaove at constant height of no more than 40ft.
Fly another rectangular approach and land within a 30 metre agreed area.
Complete post flight checks as per the BMFA Safety Codes.
Answer a minimum of 8 questions on safety taken from the BMFA Handbook on Codes for General Flying, Model Flying Displays and local flying rules.
One club plus another appointed examiner to be present.
Still can't get everything right in one attempt of two allowed per day, so haven't got to the questions yet!!
Still, it's only a hobby and not compulsorary.
Good luck
EG
Old Feb 07, 2013, 03:29 PM
Ireland, Cork
Joined Oct 2010
'B' here is: -
Good luck
EG
Yeah.. The MACI rules are more or less the same as BMFA.
http://www.maci.ie/rulebook/AB-cert-rules.html
Sean
Old Feb 11, 2013, 04:10 PM
Lbayorkie is offline
Find More Posts by Lbayorkie
Alan M
Joined Jul 2011
Decal Set for Wot4 Foam E
I found that my Wot4 Foam E was almost impossible to fly at any distance because the decals are so similar above and below the wing i couldnt tell the underside from the top!
The answer was to paint it a dark colour under the wing and a starburst on top-now its so much easier to orientate.
The disadvantage of using paint is that it tends to crack and rub off, plus aerosol paint is very expensive in the quantities that are required, and the masking process is a bore.
Has anyone come across a 'kit' or 'set' of decals made especially for the Wot Foam E? It would make life much simpler just to have to put stickers on the aeroplane and not have to worry about cracking or the hassle and expense of paint.
Alan
Lbayorkie is offline Find More Posts by Lbayorkie
Old Feb 12, 2013, 06:00 PM
ulogix is offline
Find More Posts by ulogix
Birmingham (UK)
Joined Sep 2010
Alan
The simplest solution is to use the decals supplied with the WOT 4, but apply them differently onto the main wing so that you have decals on the top, but none on the bottom. That's what I did with my second WOT 4 Foame, and it's great.
ulogix is offline Find More Posts by ulogix
Old Feb 13, 2013, 04:11 PM
Alan M
Joined Jul 2011
Thanks, but I found a solid colour under the wing and a starburst above made it really easy to orientate at longer distances. My eyes are not what they used to be!
Alan
Old Feb 14, 2013, 07:50 PM
megadaz is offline
Find More Posts by megadaz
United Kingdom
Joined Mar 2012
Hi guys
I have a dilemma,I own several planes,pkzone spitfire,se5a,mig 15,f86 saber,geebee and a few others. Is it worth getting one of these as I've just joined a club and want to take my A test,do I get one just for the test?
megadaz is offline Find More Posts by megadaz
Old Feb 15, 2013, 03:50 AM
Ireland, Cork
Joined Oct 2010
Originally Posted by megadaz View Post
Hi guys
There is no rule as to what model you fly on a A cert ( with in reason),,,, I've seen a guy sit his A cert flying a PZ Extra 300,,,
as long as it can take off from a run way and land again..... No hand launch . . .
But if you can aford to buy a WOT4 Foam-e there a lot of fun...
Sean
Old Feb 15, 2013, 03:26 PM
BrumBob is offline
Find More Posts by BrumBob
Birmingham, UK
Joined Apr 2007
Wots the weight of a Wot 4 FoamE? It needs to be 1kg - 2.2 lb to use for an 'A'. I can't see an ad that actually states the weigh.
BrumBob is offline Find More Posts by BrumBob
Old Feb 15, 2013, 03:40 PM
Ireland, Cork
Joined Oct 2010
Deleted... Sorry..
Old Feb 16, 2013, 04:44 AM
megadaz is offline
United Kingdom
Joined Mar 2012
Got my wot yesterday,went together kinda ok apart from the pushrods for the elevator,and rudder which needed some fiddling as the screws weren't holding the rods in properly. Also not sure how to secure the esc in although when the battery is in nothing seems to move once it's packed in there. Got all my throws set and ready. Any first flight tips?
Old Feb 16, 2013, 09:19 AM
BrumBob is offline
Birmingham, UK
Joined Apr 2007
yes - relax and remember you can always close the throttle if things start to feel uncomfortable.
Old Feb 17, 2013, 07:59 AM
ulogix is offline
Birmingham (UK)
Joined Sep 2010
Only one tip -
Set your TX rates to 50% until you are comfortable with the flying characteristics.
Discussion Wot 4 Frank Hurd Sport Planes 75 Dec 21, 2012 04:46 PM
Discussion Wot 4 or Acrowot sg sailing Fuel Plane Talk 9 Sep 17, 2011 01:06 PM
Wot- 4 Twister 60 e-conversion leccyflyer Sport Planes 51 Jun 14, 2010 11:25 AM
Discussion OS 61FX in a Wot 4? Sosbe1 Power Systems 1 Mar 25, 2010 12:31 PM
Discussion WOT 4 Mk3 Build ben64 Fuel Plane Talk 0 Oct 10, 2009 06:21 PM
