Old Sep 03, 2012, 08:50 PM
BlenderBoy is offline
Find More Posts by BlenderBoy
Fly, crash, repair, repeat....
BlenderBoy's Avatar
United States, UT, West Jordan
Joined Sep 2011
Heres the video. Its ok, I'll try to get better next time.
Combat 9-3-12 (4 min 57 sec)
BlenderBoy is offline Find More Posts by BlenderBoy
Old Sep 03, 2012, 09:41 PM
OICUFly12 is offline
Find More Posts by OICUFly12
Eek! I see RC People!
Utah
Joined Oct 2009
My video did not turn out at all. I think I forgot how to make a video with my camera. I have to figure it out again.
OICUFly12 is offline Find More Posts by OICUFly12
Old Sep 03, 2012, 11:27 PM
Utah
Joined Oct 2009
Mentioned on rchelination, but I'll go ahead and post it here anyway.
IRCHA 2012 (3 min 56 sec)
Old Sep 04, 2012, 03:01 AM
Utah
Joined Oct 2009
Carlos,
I hope you read this before you send you ESC back to Castle. I'd like you to try futzing with your throttle curves. Can you tell me what the values for each of your curves? I thought that your heli worked better when the throttle curve was flatter. That is, I seem to remember that you originally had something like 80 - 70 - 80 on one of your curves. We then changed it to 100 - 70 - 100 curve. I thought it worked better with the 80 - 70 - 80 curve. So is there a way you can set it to 100 - 95 - 100? I think you would have to change the pinion to keep your head speed reasonable. You might also want to try a flat 100 or flat 95 curve, ie 100 - 100 - 100 or 95 - 95 - 95.
Hope this makes sense. Something to try anyway. Better than waiting for Castle which has a 8 or 12 week waiting list right now.
Old Sep 04, 2012, 08:27 AM
BlenderBoy's Avatar
Joined Sep 2011
If you're using the governor with the cc esc, shouldn't you be using flat throttle curves anyway....it tells you what to set them up at in the software per headspeed. Otherwise you're changing headspeed by not running a flat curve if you are using the governor
Old Sep 04, 2012, 09:54 AM
Utah
Joined Oct 2009
He was using governor mode, but switched to fixed endpoint mode. My suggestion was for fixed endpoint mode.
Old Sep 04, 2012, 10:51 AM
BlenderBoy's Avatar
Joined Sep 2011
Was he using flat throttle curves in governor mode?
Old Sep 04, 2012, 11:13 AM
Utah
Joined Oct 2009
Yes.
Old Sep 04, 2012, 11:28 AM
J_Arner is offline
Find More Posts by J_Arner
Limbo with 30,000V...
J_Arner's Avatar
United States, UT, Roy
Joined Apr 2008
Looks like you all had a great time this weekend! Hopefully I'll be able to get out and fly some now that Summer is winding down some.
J_Arner is offline Find More Posts by J_Arner
Old Sep 04, 2012, 11:55 AM
Utah
Joined Oct 2009
That would be great, Jim.
Old Sep 04, 2012, 09:03 PM
crgonzalez08 is offline
Find More Posts by crgonzalez08
Carlos G.
crgonzalez08's Avatar
United States, UT, Centerville
Joined Aug 2008
I will give it one more try Phill and yes, that was my curves.
On gov mode
Flat 30% ............2000rpm
Flat 70% .............2250
Flat 100% ........... 2350
With 80 70 80 I was around 2200 and with 100 80 100 went to 2400
I did try a flight with only fast forward flight and the graph shows some picks consistence with the tail wag so I'm thinking for some reason the esc is pooping out, so I will prob end sending the esc back
crgonzalez08 is offline Find More Posts by crgonzalez08
Old Sep 04, 2012, 09:04 PM
Carlos G.
Joined Aug 2008
Does are great pics of the wings in combat! Wondering who took does ????
Old Sep 04, 2012, 09:06 PM
Carlos G.
Joined Aug 2008
Jim, flying was nothing............ lunch was even better!
Your missing buddy
Old Sep 04, 2012, 10:46 PM
Utah
Joined Oct 2009
Carlos,
That's what I remember from last Sunday. What I'm suggesting is that you go to a smaller pinion. Then set your throttle curves to 100 - 95 - 100 so that you're still getting the 2400 rpm. Now the curve is flatter, the ESC has less work to do and hopefully there will be less interaction with the gyro. I don't know what pinion you're running now, but you only need to drop one or two teeth.
Hope that makes sense.
Old Sep 05, 2012, 12:14 PM
BlenderBoy's Avatar
Joined Sep 2011
Who's going to the outlaw fun fly this weekend? I think Russ and I will be going Saturday.
New Product Copterx new rotor heads x 2 PHIL.H Scale Helicopters 4 Feb 26, 2010 11:24 AM
Sold HUGHES 500 fuse, BeltCP, scale rotor heads, parts darmar Aircraft - Electric - Helis (FS/W) 4 Nov 23, 2009 09:51 PM
Video Bad rotor heads right out of box (CB100 & CB180 from www.ehirobo.com) altronpower Electric Heli Talk 2 Nov 11, 2009 08:25 AM
Discussion Bad rotor heads right out of box (CB100 & CB180 from www.ehirobo.com) altronpower Micro Helis 9 Nov 10, 2009 04:54 PM
Are real heli rotor heads similar to model heli rotor heads? smste2 Micro Helis 6 Jul 11, 2004 02:15 PM
