Old Aug 18, 2012, 10:06 PM
OICUFly12 is offline
Find More Posts by OICUFly12
Eek! I see RC People!
Utah
Joined Oct 2009
Yes, Mike your Goblin looks great. Wish I could see you maiden it. Hope to see you fly it soon.
OICUFly12 is offline Find More Posts by OICUFly12
Old Aug 19, 2012, 08:41 AM
J_Arner is offline
Find More Posts by J_Arner
Limbo with 30,000V...
J_Arner's Avatar
United States, UT, Roy
Joined Apr 2008
Originally Posted by crgonzalez08 View Post
now passing to dlg business the plain I ordered from soaringusa is on hold, so i cancelled the order, and im gonna shoot for a better one ....... (hopefully a stobel, but keep it a secret!) or get a good deal on a used one. I figured if i have to wait, I will wait for something good
hope to see you guys tomorrow
J_Arner is offline Find More Posts by J_Arner
Old Aug 19, 2012, 08:42 AM
J_Arner is offline
J_Arner's Avatar
Joined Apr 2008
Mike, that Goblin is a fantastic looking bird!
Old Aug 19, 2012, 08:25 PM
BlenderBoy is offline
Find More Posts by BlenderBoy
Fly, crash, repair, repeat....
BlenderBoy's Avatar
United States, UT, West Jordan
Joined Sep 2011
Thanks guys, should be flying it next weekend!
BlenderBoy is offline Find More Posts by BlenderBoy
Old Aug 19, 2012, 08:49 PM
crgonzalez08 is offline
Find More Posts by crgonzalez08
Carlos G.
crgonzalez08's Avatar
United States, UT, Centerville
Joined Aug 2008
try to doit sunday, so I can see it for sure!
crgonzalez08 is offline Find More Posts by crgonzalez08
Old Aug 24, 2012, 07:26 PM
Utah
Joined Oct 2009
Mike,
You flown the Goblin yet?
Old Aug 24, 2012, 08:05 PM
BlenderBoy's Avatar
Joined Sep 2011
Finishing up the wiring and programming after dinner.
If all goes well, I will be there in the morning to do the maiden
Old Aug 25, 2012, 03:28 PM
BlenderBoy's Avatar
Joined Sep 2011
Flew the goblin today, flys like a dream.
It sure is an attention whore though, just begging to be picked up, drooled on, and stared at
Old Aug 25, 2012, 03:58 PM
Utah
Joined Oct 2009
It was great seeing your Goblin and watching it fly, Mike. The mechanics of it are quite impressive. It's almost unbelievably quiet in the air. Definitely enjoyed it!
Old Aug 25, 2012, 05:27 PM
Carlos G.
Joined Aug 2008
Nice looking bird! Any chances of been around tomorrow?
Old Aug 25, 2012, 07:57 PM
BlenderBoy's Avatar
Joined Sep 2011
Thanks Phil.
Carlos, I don't think I'll make it out tomorrow. Maybe next Sunday, I'll let you know.
Old Aug 27, 2012, 09:18 AM
J_Arner is offline
J_Arner's Avatar
Joined Apr 2008
She's a looker Mike! Can't wait to see her fly... when that might be, well I have no idea. I'm out of town again this next weekend.
Old Aug 29, 2012, 09:26 AM
BlenderBoy's Avatar
Joined Sep 2011
Putting my 550 up for those interested, take a look...
http://www.helifreak.com/showthread.php?p=4240193
Old Aug 31, 2012, 08:13 AM
Utah
Joined Oct 2009
Yipee! I had Richard look at my engine/clutch hub assembly yesterday. He thought there was just a little bit of a bur on the engine's shaft. He took a file to it and low and behold the hub slid quite nicely onto the engine. Yea! With that out of the way, I got more of the build done last evening.
Here are the engine, clutch hub and clutch parts.
The clutch hub is now installed.
The clutch is now installed.
Engine fan shroud parts. Should have included the engine mount in this pic as well.
Left fan shroud and hex mounting posts.
Hex mounting posts installed.
Engine and engine mount parts.
Engine installed on mount.
Engine and fan shroud parts.
Engine installed in fan shoud.
Engine assembly and frames.
Engine assembly loosely installed in frames.
Engine assembly mounting screws.
Engine mount mounting screws installed.
Fan shroud mounting screws installed.
Hard to tell, but I installed the engine mount incorrectly. There are mounting holes on the engine mount for the bottom frame plate. I didn't realize it until I tried to install the bottom frame plate. I had to remove the engine assembly from the frames to install the engine mount correctly and put everything back in the frames again. Sorry, no pics of the correctly installed engine assembly. It was getting late, at that point, and I totally spaced taking pics of the frame plate and landing gear installation. Here's a couple pics with the bottom plate and landing gear installed.
A view from the left.
A view from the right.
Only the head, main shaft and main gear left to install. After that, there's a big loctite project as nothing has any loctite on it yet, then it's on to the electronics.
Getting closer!
Old Aug 31, 2012, 12:19 PM
J_Arner is offline
J_Arner's Avatar
Joined Apr 2008
Looking good Phil!, can't wait to hear how she flies.
I met Mike out at the field and got to see the Goblin in action, man what a sweet setup that is. I also pulled out the old Raptor and put a flight on to show Mike what the tail was doing. He thinks it could be binding in the linkage somewhere, after lubing that up I went to take off and had no tail control . Luckily I found that out on the ground, so no damage. Had drained the flight pack .
Just took a look at the Gaui NX4 and ... I want one, but I want a lot of things haha.
Also intrigued by this one : http://yardbirdhelicopters.com/products/
New Product Copterx new rotor heads x 2 PHIL.H Scale Helicopters 4 Feb 26, 2010 10:24 AM
Sold HUGHES 500 fuse, BeltCP, scale rotor heads, parts darmar Aircraft - Electric - Helis (FS/W) 4 Nov 23, 2009 08:51 PM
Video Bad rotor heads right out of box (CB100 & CB180 from www.ehirobo.com) altronpower Electric Heli Talk 2 Nov 11, 2009 07:25 AM
Discussion Bad rotor heads right out of box (CB100 & CB180 from www.ehirobo.com) altronpower Micro Helis 9 Nov 10, 2009 03:54 PM
Are real heli rotor heads similar to model heli rotor heads? smste2 Micro Helis 6 Jul 11, 2004 01:15 PM
