Old Aug 08, 2012, 01:42 PM
BlenderBoy is offline
Find More Posts by BlenderBoy
Fly, crash, repair, repeat....
BlenderBoy's Avatar
United States, UT, West Jordan
Joined Sep 2011
I'll try and remember to bring my motor and clutch with me to the meeting so you can compare it.
BlenderBoy is offline Find More Posts by BlenderBoy
Old Aug 08, 2012, 03:39 PM
OICUFly12 is offline
Find More Posts by OICUFly12
Eek! I see RC People!
Utah
Joined Oct 2009
I might not be able to make it. It's looking like I'll be needed around here Thursday evening. If I don't make it, please bring it be on Saturday or Sunday.
OICUFly12 is offline Find More Posts by OICUFly12
Old Aug 08, 2012, 04:23 PM
BlenderBoy's Avatar
Joined Sep 2011
Don't think I'll be making it this weekend, big Dlg contest in orem Saturday and Sunday. I prolly won't even make the meeting tomorrow after all.
Old Aug 08, 2012, 09:00 PM
crgonzalez08 is offline
Find More Posts by crgonzalez08
Carlos G.
crgonzalez08's Avatar
United States, UT, Centerville
Joined Aug 2008
Looks like some sandpaper will do the trick, or maybe run a drill it the the hole in the hub. Now the heating idea will work too if you can install the screws from the to of the hub after is mounted on the engine.
Now you know that heat will expand the metal and cold will do the opposite! So I will try to stick the engine in your freezer for some time, but put in in a zipplock bag so you don't get moisture I your engine and then try to install your hub, it may work.
I'm back from NO so I will be at the meeting tomorrow
crgonzalez08 is offline Find More Posts by crgonzalez08
Old Aug 09, 2012, 08:35 AM
BlenderBoy's Avatar
Joined Sep 2011
I don't know how this ended up on my counter top, but I think I'll keep it
Old Aug 09, 2012, 08:59 AM
Utah
Joined Oct 2009
Oooooo... That looks great! When do you thing you'll maiden it?
Old Aug 09, 2012, 09:20 AM
BlenderBoy's Avatar
Joined Sep 2011
Shooting for next weekend. The pics do it no justice, this thing is a work of art!
Old Aug 09, 2012, 03:59 PM
Carlos G.
Joined Aug 2008
Hey Mike a forgot something in your kitchen, would you bring it to me to the meeting tonight please!
Old Aug 09, 2012, 05:35 PM
Utah
Joined Oct 2009
Yeah, that would be cool. I'm gonna make it after all, but I can't stay long.
Old Aug 10, 2012, 02:47 PM
BlenderBoy's Avatar
Joined Sep 2011
Lol, sorry next time
Old Aug 10, 2012, 07:20 PM
Utah
Joined Oct 2009
I will not be out at the field on Saturday. I got roped into family stuff I didn't sign up for. Good thing is I'll have plenty of time to work on my helis. The O550 is getting a new motor. Hopefully, the head parts for the F50 will arrive tomorrow so I can fix its head. I'll also continue work on the Velocity. Next up, the tail. Hope to post pics of the work I did on the frames later tonight.
Old Aug 10, 2012, 09:45 PM
Utah
Joined Oct 2009
As promised, here are some pics from the next part of the frame build, minus the engine/fan assembly.
I'll start with the fuel tank parts.
Now the assembled fuel tank.
All the left frame parts. Actually, I missed a few in this pic.
A-Arm flange bearing installed.
Left frame PEM parts.
PEM parts installed.
Govenor sensor mount parts.
Govenor sensor mount loosely installed.
Right trame, fuel tank and damper parts.
Fuel tank installed in right frame.
Left frame and fuel tank damper parts.
Right and left frame brought together.
Rear frame doubler parts.
Rear frame doubler parts installed.
Front frame doubler and canopy mounting post parts. Whoops! I already installed the frame doubler when I took this pic.
Front frame doubler and canopy mounting post installed.
Rear canopy mount parts.
Rear canopy mount installed.
Main mast bearing block mounting screws.
Main mast bearing block mounting screws installed.
Electronics tray mounting screws.
Electronics tray mounting screws installed.
Clutch assembly mounting screws.
Clutch assembly mounting screws installed.
Bell Crank Parts.
Bell crank ball links installed.
Pitch bell crank installed.
Aileron and elevator bell cranks installed.
At this point I am supposed to install the bottom frame stiffener and landing gear. However, the bottom frame stiffener bolts onto the motor mount which is not installed yet. I'm going to skip this part of the build and continue on with servo install.
Old Aug 12, 2012, 06:57 PM
BlenderBoy's Avatar
Joined Sep 2011
Almost there, just need to wire up the electronics.
Old Aug 12, 2012, 07:08 PM
Utah
Joined Oct 2009
Decided to skip the servo install and do the tail instead.
Tail rotor tail case parts.
Tail case torque tube gear. The gear must be glued into place or it slips out and the teeth strip.
Tail case torque tube gears installed.
Parts for the left side of the tail case.
Left side of tail case assembled.
Parts for the right side of the tail case.
Right side of tail case assembled.
Vertical fin parts.
Vertical fin assembled.
Tail rotor parts.
Parts for the left grip of tail rotor.
Left grip assembled.
Parts for the right grip of tail rotor.
Right grip assembled.
Pitch slider parts.
Assembled pitch slider.
Tail rotor and pitch slider.
Assembled tail rotor and pitch slider.
Tail rotor, tail case and pitch lever parts.
Pitch lever and ball link.
Ball link installed on pitch lever.
Pitch lever parts.
Assembled pitch lever parts.
Tail case and pitch lever parts.
Assembled tail case and pitch lever.
Tail rotor and tail case parts.
Completed tail rotor and tail case assembly.
There's quite a few images in this message. I think I'll complete the rest of the tail in another message.
Old Aug 12, 2012, 07:50 PM
Utah
Joined Oct 2009
Now for the forward torque tube assembly, tail boom and the final installation of the tail boom. I failed to take pics of individual parts here, so you will mostly see assembled parts.
Boom mount parts.
Boom mount mounting posts installed.
Torque tube gear installed in bearings.
Torque tube gear installed in boom mount.
Counter gear installed in boom mount.
Assembled boom mount.
Torque tube assembly parts.
Torque tube bearing support parts.
Bearings installed in supports.
Torque tube bearing supports installed on torque tube.
Torque tube shaft spline parts.
Torque tube shaft spline parts installed. I decided to only show one of these.
Tail assembly installed on tail boom.
Tail boom mount installed on tail boom.
Assembled frames and tail boom with boom support parts.
Parts for horizontal fin mount.
Horizontal fin mount installed on tail boom.
Horizontal fin parts. Gah! I forgot to take a pic of the completed assembly.
Frames, tail boom and tail boom mounting screws.
Tail boom installed into frames.
Tail boom support rod parts.
Completed tail boom installation.
New Product Copterx new rotor heads x 2 PHIL.H Scale Helicopters 4 Feb 26, 2010 10:24 AM
Sold HUGHES 500 fuse, BeltCP, scale rotor heads, parts darmar Aircraft - Electric - Helis (FS/W) 4 Nov 23, 2009 08:51 PM
Video Bad rotor heads right out of box (CB100 & CB180 from www.ehirobo.com) altronpower Electric Heli Talk 2 Nov 11, 2009 07:25 AM
Discussion Bad rotor heads right out of box (CB100 & CB180 from www.ehirobo.com) altronpower Micro Helis 9 Nov 10, 2009 03:54 PM
Are real heli rotor heads similar to model heli rotor heads? smste2 Micro Helis 6 Jul 11, 2004 01:15 PM
