Old Jul 30, 2012, 02:50 PM
BlenderBoy is offline
Find More Posts by BlenderBoy
Fly, crash, repair, repeat....
BlenderBoy's Avatar
United States, UT, West Jordan
Joined Sep 2011
Sweet Phil. Maiden this weekend?
BlenderBoy is offline Find More Posts by BlenderBoy
Old Jul 30, 2012, 04:48 PM
OICUFly12 is offline
Find More Posts by OICUFly12
Eek! I see RC People!
Utah
Joined Oct 2009
I doubt it, but it should be flying by the club meeting next week.
OICUFly12 is offline Find More Posts by OICUFly12
Old Jul 30, 2012, 10:49 PM
Utah
Joined Oct 2009
Continuing with diagram #13, diagram #14 and one item from diagram #15.
Parts for diagram #13.
Canopy mount parts.
Canopy mount parts assembled.
Top main shaft bearing block parts.
Assembled top main shaft bearing block.
Forward canopy mount parts.
Forward canopy mount installed.
Frame spacer parts.
Frame spacers installed.
Main shaft bearing block parts.
Lower bearing block installed.
Mid bearing block installed.
Top bearing block installed. They combined one of the screws for the top bearing block with the rear canopy mount. Nice touch.
Diagram #14 parts.
Electronics tray parts.
Electronics tray installed.
Clutch parts.
Clutch assembled.
Clutch assembly and mounting parts.
Clutch assembly installed.
Elevator a-arm parts.
Elevator a-arm link installed.
Elevator arm installed.
Elevator a-arm assembly built.
Hard to see it, but the elevator a-arm is loosely installed in the frame.
Diagram #15, gyro tray parts.
Gyro tray installed.
Next post, I'll be working on installing the engine.
Old Aug 02, 2012, 05:50 PM
Utah
Joined Oct 2009
Hope you guys haven't already seen this vid.
3D Masters 2012 | Mikado (7 min 46 sec)
Old Aug 02, 2012, 07:39 PM
J_Arner is online now
Find More Posts by J_Arner
Limbo with 30,000V...
J_Arner's Avatar
United States, UT, Roy
Joined Apr 2008
Hadn't seen that one Phil, I did see the victory flight with the tail scrape auto
J_Arner is online now Find More Posts by J_Arner
Old Aug 02, 2012, 08:53 PM
crgonzalez08 is offline
Find More Posts by crgonzalez08
Carlos G.
crgonzalez08's Avatar
United States, UT, Centerville
Joined Aug 2008
that is a nice video phil, are you going to be flying your new heli like that????
Well Im on my way to New Orleans for 2 weeks, so I will see you guys on the 17.
I can't wait to go get some crawfish! mmmmmm
crgonzalez08 is offline Find More Posts by crgonzalez08
Old Aug 02, 2012, 09:22 PM
Utah
Joined Oct 2009
Have fun in New Orleans, Carlos. Have fun in Bridgerland, Jim.
Old Aug 05, 2012, 03:37 PM
BlenderBoy's Avatar
Joined Sep 2011
Looks good Phil
Old Aug 05, 2012, 03:38 PM
BlenderBoy's Avatar
Joined Sep 2011
What day is the club meeting, Thursday or Wednesday?
Old Aug 05, 2012, 04:23 PM
Carlos G.
Joined Aug 2008
since I'm taking a brake of this infernal heat in the big easy, I logged in to check for some new pics of the build or see whats going on there guys.............. Hey Mike meeting should be on Thr, I least thats what i think, cause usually is second thr of the month.
Have fun guys and stay cool, here is impossible!
Old Aug 05, 2012, 07:18 PM
BlenderBoy's Avatar
Joined Sep 2011
Cool, have fun in NO, bring me back some mud bugs!
Old Aug 06, 2012, 10:39 PM
Utah
Joined Oct 2009
Mike,
Did you have trouble getting the clutch hub installed on the engine when you built your velocity? There is no way the hub is going on my engine. The hub's hole for the engine's shaft is just too small.
Old Aug 07, 2012, 06:57 AM
BlenderBoy's Avatar
Joined Sep 2011
Nope, mine all matched up the same.
I did have a hard time tightening the bell housing on the shaft with the motor wanting to keep turning over, but they have a special took for that you can get to hold the piston in place without damaging it.
Maybe you need a different sized motor shaft for your motor?
Old Aug 07, 2012, 09:09 PM
Carlos G.
Joined Aug 2008
hey phil, why don't you post some pics of your clutch hub and engine just to get a better idea of your problem.
I had a problem one time where my hub has hitting on the bottom part of my clutch buy i fix the problem taking one of the washers off in the motor shaft.
Or your problem is with the hub been smaller than your engines shaft???? What engine are you installing?
Old Aug 07, 2012, 10:00 PM
Utah
Joined Oct 2009
So here are some pics of this part of the build and the issues I'm having. Before I show them, here is the link to the manual. Goto page 12 and in the lower right is the clutch hub and fan assembly instructions.
Clutch, clutch hub and fan parts.
Clutch hub and fan parts.
Fan installed on clutch hub.
In the final picture you can see the part of the hub that is facing the engine. It is the inner hole that is too small. The threaded portion of the shaft fits the hole, but the solid portion does not fit it. The hole and the engine's shaft are both 6.35 mm in diameter. Someone on helifreak suggested heating the hub before installing it on the engine. However, I can't see how I'm going to keep the fan from melting.
New Product Copterx new rotor heads x 2 PHIL.H Scale Helicopters 4 Feb 26, 2010 10:24 AM
Sold HUGHES 500 fuse, BeltCP, scale rotor heads, parts darmar Aircraft - Electric - Helis (FS/W) 4 Nov 23, 2009 08:51 PM
Video Bad rotor heads right out of box (CB100 & CB180 from www.ehirobo.com) altronpower Electric Heli Talk 2 Nov 11, 2009 07:25 AM
Discussion Bad rotor heads right out of box (CB100 & CB180 from www.ehirobo.com) altronpower Micro Helis 9 Nov 10, 2009 03:54 PM
Are real heli rotor heads similar to model heli rotor heads? smste2 Micro Helis 6 Jul 11, 2004 01:15 PM
