Old Jul 16, 2012, 07:05 PM
BlenderBoy is offline
Find More Posts by BlenderBoy
Fly, crash, repair, repeat....
BlenderBoy's Avatar
United States, UT, West Jordan
Joined Sep 2011
I've been out to antelope island a bunch of times. There are some really cool places we could fly off some big drop offs.
BlenderBoy is offline Find More Posts by BlenderBoy
Old Jul 20, 2012, 09:15 PM
crgonzalez08 is offline
Find More Posts by crgonzalez08
Carlos G.
crgonzalez08's Avatar
United States, UT, Centerville
Joined Aug 2008
Any body planning in going to the airfield tomorrow ( south Davis)
crgonzalez08 is offline Find More Posts by crgonzalez08
Old Jul 20, 2012, 09:55 PM
OICUFly12 is offline
Find More Posts by OICUFly12
Eek! I see RC People!
Utah
Joined Oct 2009
Finally got the 550 running, so yes I will be out there. Sunday too.
OICUFly12 is offline Find More Posts by OICUFly12
Old Jul 21, 2012, 09:05 AM
BlenderBoy's Avatar
Joined Sep 2011
Sunday for me, I'm still in moab until tonight.
Old Jul 24, 2012, 09:39 PM
Carlos G.
Joined Aug 2008
Mr. Phil, was wondering what battery size do you run on your outrage 550?
Old Jul 24, 2012, 10:49 PM
Utah
Joined Oct 2009
6s 5000
Old Jul 28, 2012, 02:18 PM
Utah
Joined Oct 2009
Mike, you left 15 minutes too soon. One of Kenny's batteries on his 700 went up in flames. He had just finished his flight and was answering a question when he heard a pop followed by hissing. I was too far away, but Kenny saw three inch flames coming out the side of his heli. No real damage to the heli. Here are some pics of the battery.
Old Jul 28, 2012, 04:38 PM
BlenderBoy's Avatar
Joined Sep 2011
Oh man that sucks!
What is that in the right of the battery, part if the frame?
Old Jul 28, 2012, 05:16 PM
Utah
Joined Oct 2009
Those pics include two batteries, but the battery that popped is split into two parts. The other stuff between the two parts is just velcro.
Old Jul 28, 2012, 10:28 PM
J_Arner is offline
Find More Posts by J_Arner
Limbo with 30,000V...
J_Arner's Avatar
United States, UT, Roy
Joined Apr 2008
Dang, that's a bummer. Any damage to the heli?
J_Arner is offline Find More Posts by J_Arner
Old Jul 28, 2012, 11:41 PM
Carlos G.
Joined Aug 2008
ohhhh man.......................! thats to bad. Any body planning in going to the field tomorrow?
Old Jul 29, 2012, 01:19 AM
Utah
Joined Oct 2009
Jim, no damage to the heli. Both Kenny and I will be out there, Carlos. Go early, it was quite windy today and will likely be windy on Sunday. Will bring that other 6S heli out too.
Old Jul 29, 2012, 09:45 AM
Utah
Joined Oct 2009
So the Velocity 50 N2 build started last night. I built the head. Here are some pics from that portion of the build.
Here's where you start; the box.
Oh look! I managed to open it.
Diagram #1, seesaw parts.
Diagram #1, seesaw parts installed.
Diagram #2, flybar cage parts.
Diagram #2, the flybar cage is built.
Diagram #2, the flybar cage and flybar installed.
Diagram #3, washout base and lower mixing arm parts.
Diagram #3, washout base and lower mixing arm installed.
Diagram #3, swash parts.
Diagram #3, swash parts installed.
Diagram #4, head and main shaft parts.
Diagram #4, head and main shaft parts installed.
Diagram #5, upper mixing arm parts.
Diagram #5, upper mixing arm parts installed.
Diagram #5, main grip arms and upper mixing arms.
Diagram #5, upper mixing arm installed on main grip arms.
Diagram #5, main grips and their thrust bearings.
Diagram #5, main grips and their arms.
Diagram #5, main grips with their arms installed.
Diagram #5, head, grips and spindle parts.
Diagram #5, head grips and spindle parts installed.
Diagram #5, final set of head link parts.
Diagram #5, final set of head link parts installed. Did you catch the error I made when I installed the seesaw? Fixed in this pic. Had to take the head apart to fix it.
Next up... The Frames!
Old Jul 30, 2012, 12:40 AM
Utah
Joined Oct 2009
I had time to get another step done with the build of my Velocity 50 N2.
Parts for Diagram #12 in manual.
Installation of elevator A-arm frame bearing.
PEM hardware.
PEM hardware installed.
Front frame doubler and landing gear mount hardware.
Front frame doubler and landing gear mount installed.
Rear frame doubler and landing gear mount hardware.
Rear frame doubler and landing gear mount installed.
Fuel tank dampers. I did not install them. They slipped out of their locations too easily. Guess I could have glued them in, but I'm just going to wait until I install the tank.
Gyro tray hardware.
Gyro tray hardware installed. This is not where I will be installing the gyro, so I'm mounting it slanted downwards.
Next I'll install more right side frame hardware.
Old Jul 30, 2012, 12:56 AM
Carlos G.
Joined Aug 2008
Nice job! It looks really nice!
New Product Copterx new rotor heads x 2 PHIL.H Scale Helicopters 4 Feb 26, 2010 11:24 AM
Sold HUGHES 500 fuse, BeltCP, scale rotor heads, parts darmar Aircraft - Electric - Helis (FS/W) 4 Nov 23, 2009 09:51 PM
Video Bad rotor heads right out of box (CB100 & CB180 from www.ehirobo.com) altronpower Electric Heli Talk 2 Nov 11, 2009 08:25 AM
Discussion Bad rotor heads right out of box (CB100 & CB180 from www.ehirobo.com) altronpower Micro Helis 9 Nov 10, 2009 04:54 PM
Are real heli rotor heads similar to model heli rotor heads? smste2 Micro Helis 6 Jul 11, 2004 02:15 PM
