Old Oct 03, 2001, 08:42 PM
Gene Gold is offline
Find More Posts by Gene Gold
Chico, Ca. USA
Joined Jun 2001
Can anyone tell me ?? About this motor
How is this motor rated?? Kyosho Atomic Force 17x2, as a 400, 500 or 600 how is it rated? I would like to put into a plane just don't know which one..I am new to the Electric Field as you can tell so any help you can offer will help.. I also have a Master Airscrew gear box with it..Thanks for your Help, Gene Gold
Gene Gold is offline Find More Posts by Gene Gold
Old Oct 03, 2001, 10:13 PM
Chico, Ca. USA
Joined Jun 2001
Need Help with this Motor !!
I have a Atomic Force 17x2 Motor. Can anyone tell me how this motor is Rated?? Is it classified as a 300, 400, 500 Etc. I would like to put in a plane just need to know how is rated..Thanks for any help !!
Gene Gold genegold@pacbell.net
Old Oct 04, 2001, 05:13 AM
stuartaw is offline
Find More Posts by stuartaw
Berks, England
Joined Jun 2001
It's a 540 motor - a shortened 600.
It's identical to the Endo (Endoplasma), except has one extra winding, so needs a <b>slightly</b> bigger prop/lower gear ratio.
These motors a very effective for some purposes. If you search ezone for the Endo/Endoplasma you will see a <b>lot</b> of stuff about it recently, especially on the sports forum. Most of this applies equally to the Atomic Force.
You say have a gearbox. This is essential for either of these motors. A high ratio (4:1+) is best, but anything 2:1 or more can be used.
The current 'hot' topic is using Endoplasma on 10 cells at about 4.5:1 gear ratio with a 12x8 prop. The Atomic Force works very well in a similar setup.
Stuart
stuartaw is offline Find More Posts by stuartaw
Old Oct 04, 2001, 05:20 AM
stuartaw is offline
Berks, England
Joined Jun 2001
I've just answered the copy of this in the sports planes forum...
Old Oct 04, 2001, 10:27 AM
Chico, Ca. USA
Joined Jun 2001
Thanks Stuart
Thanks for your help!! I will check out the post for an airplane to put it in.. Do you have any ideas on the subject?? Again Thanks Gene
Old Oct 04, 2001, 03:32 PM
stuartaw is offline
Berks, England
Joined Jun 2001
Gary Wright's E3D is probably the best if you don't mind joining the end of what sounds like a very long queue for the kits. A load of people are using Modeltech Magic's (there's loads of stuff in the Sports forum about this). I'm using a Limbo Dancer which is almost identical to the Magic. Atomic Force, 10 cells, 5:1 gearbox, 14x7 APC prop. Incredible results from a cheap motor and an unmodifed IC ARTF plane.
Stuart
Discussion Newbie..can anyone tell me what this is please??? UKPilot Electric Plane Talk 6 Apr 18, 2007 09:05 AM
Can anyone tell me about this? randall1959 Aerial Photography 8 Aug 25, 2005 07:58 PM
Can anyone tell me about Ikarus Shockflyers? snowball1288 3D Flying 11 Mar 11, 2005 10:17 PM
Can anyone tell me about the Mabuchi 2n motor? jayboy Parkflyers 1 Jul 12, 2002 06:53 PM
Can someone tell me what this motor is for? Bonafidepirate Parkflyers 10 Jan 07, 2002 08:33 PM
