Old Aug 24, 2010, 10:16 AM
Mr. UD is offline
Find More Posts by Mr. UD
Mr. UD's Avatar
Deutschland, BY
Joined Oct 2007
Build Log
EPP SU-39 (modernized SU-25 Frogfoot) formerly: lets play "guess the plane"
...who can identify my new project?
Mr. UD is offline Find More Posts by Mr. UD
Old Aug 25, 2010, 05:56 AM
denispeters is offline
Find More Posts by denispeters
denispeters's Avatar
Joined Apr 2006
edf?
denispeters is offline Find More Posts by denispeters
Old Aug 25, 2010, 06:20 AM
powertool is offline
Find More Posts by powertool
powertool
Australia, VIC, Warrnambool
Joined Aug 2010
a cool room
powertool is offline Find More Posts by powertool
Old Aug 25, 2010, 06:23 AM
Mr. UD is offline
Mr. UD's Avatar
Deutschland, BY
Joined Oct 2007
Yupp - will have two 55mm EDFs; already asked the moderator to move the thread to EDF-Fomies - been building pushers for so long that I forgot that there are others too
BUT: the end of the tail has a circular cross-section with a diameter of 40mm - almost perfect for a pusher!
...guess now you know what Im building.
Already got the first problem: how to install the EDFs removable and without a step in the duct?
Old Aug 25, 2010, 08:09 AM
Joined Apr 2006
so if edf fails because of weigh problems you still have the pusher option.........
Old Aug 25, 2010, 02:08 PM
Mr. UD is offline
Mr. UD's Avatar
Deutschland, BY
Joined Oct 2007
Main parts are cutted out and test-fitted
Old Aug 25, 2010, 11:07 PM
Joined Apr 2006
........that looks promising.............
Old Aug 26, 2010, 08:24 AM
Smokescreen38 is offline
Find More Posts by Smokescreen38
Checking CG is for NERDS!
Smokescreen38's Avatar
Joined Jun 2005
Lookin great!!
Awesome work, Mr. UD.
Smokescreen38 is offline Find More Posts by Smokescreen38
Old Aug 26, 2010, 11:48 AM
splitpilot is offline
Find More Posts by splitpilot
splitpilot's Avatar
trying to catch Mr. FrSky... It flyes
Joined Jan 2005
I ws about to sat a beer cooler!!!
Nice project!!!
splitpilot is offline Find More Posts by splitpilot
Old Sep 08, 2010, 12:09 PM
Mr. UD is offline
Mr. UD's Avatar
Deutschland, BY
Joined Oct 2007
Finally after comming back from italy I had a few hours to proceed:
-carfed and sanded the right nacelle parts and testfitted the EDF - looks promissing!
Surprisingly the choosen method turned out to be ideal: after 10min. of carving out the raw curvature I needed only another 10min. to sand the inlet and nozzle with a 30mm tube and 30grain, finaly with 80 grain abresive paper. The result is so smooth - I'm not sure wether I shall use plastic sheet or not
(cant belive that the project was on hold for about 2 years because I had doubt wether I can make nacelles without hot wire )
EDFs will be glued into the fuselage-side part of the nacelle - the rear-outward part (40mm wide, 150mm long EPP nozzle) will be only spot-glued in place for maintenance
Old Sep 09, 2010, 11:51 AM
Mr. UD is offline
Mr. UD's Avatar
Deutschland, BY
Joined Oct 2007
Carved and sanded the outside of the right nacelle today:
Old Sep 11, 2010, 12:30 AM
Mr. UD is offline
Mr. UD's Avatar
Deutschland, BY
Joined Oct 2007
...made the EDF-bulkhead. Its made of two layers 3mmplywood and a 15x15x1mm alumminium-angle which supports the wing-brackets:
Old Sep 16, 2010, 07:19 AM
Mr. UD is offline
Mr. UD's Avatar
Deutschland, BY
Joined Oct 2007
...glued the fuselage parts together yesterday and made slots into the fuselage sides for the engine-bulkhead. Today I will carve the forward fuselage and the left nacelle...
....had to give back my borrowed camera - so no pics at the moment
Old Sep 18, 2010, 12:21 AM
Low Pass is offline
Find More Posts by Low Pass
Some epoxy & it flies again...
Low Pass's Avatar
Santa Cruz, California
Joined Sep 2008
subscribed
Low Pass is offline Find More Posts by Low Pass
Old Sep 18, 2010, 01:05 AM
ac_rite90 is offline
Find More Posts by ac_rite90
up up and away
United States, LA, Concordia Parish
Joined Mar 2008
If those are the 53mm 5000 kv from hk, I hope you are using a 60 amp esc. They pull 50 plus amps. Make sure your your lipo is atleast a 30c rating.
You know there is a scratchbuild edf forum now. You could of started a build log there.
subcribed too.
ac_rite90 is offline Find More Posts by ac_rite90
Discussion Well, I guess when you set the house on fire... jhspring Electric Warbirds 61 Sep 14, 2010 03:35 PM
For Sale Bunch of planes....Lets make some deals on these planes... terrywolfpack Aircraft - Electric - Airplanes (FS/W) 11 Aug 19, 2010 08:40 PM
Contest Let's Play Guess the Candidate! Miami Mike Life, The Universe, and Politics 11 May 09, 2007 07:30 AM
Discussion Lets play 'guess the advertised capacity' Nethole Batteries and Chargers 36 Oct 24, 2006 01:27 PM
Guess the Plane! AirVenture Scale Kit/Scratch Built 14 Jan 14, 2002 09:30 AM
