Old Aug 23, 2010, 09:15 PM
rifme is offline
Find More Posts by rifme
You glass em; I'll bash em!
USA, FL, Panama City
Joined Jul 2010
Airtronics RDS8000 8 Ch 2.4G Mode2 w/1-Tx/1-Rx Only RDS8000
Anyone out there familiar with this system? The price seems very reasonable to me. I have an Airtronics 5 channel that works just fine, except for the fact that it doesn't have the capabilities that I need for DLG flying. I should have done a bit more investigating before I bought. Se la vi! :-(
rifme is offline Find More Posts by rifme
Old Aug 24, 2010, 12:09 AM
like.2.fly is offline
Find More Posts by like.2.fly
Mike M.
like.2.fly's Avatar
United States, UT, Eden
Joined Jan 2010
I've been flying my DLG on the RDS-8000 and 8ch Rx for a couple of months now, almost every day (yes, DLG is very addictive!). No issues at all. Seems like a rock solid system. The Tx can do pretty much everything you need, although it lacks a couple of handy features. You can program the 2-position gear retract switch for a launch preset if you are right handed thrower, but it isn't spring loaded. You just have to remember to flick it off right after launch. If you forget, or are late doing it then your plane will loop. I also haven't figured out how to do snap flaps yet for coupling in small amounts of camber change when moving the elevator. Basic programming is straight forward and easy, but some of the custom mixing can get a little confusing. It works though. A serious competition flyer will want the more capable SD-10G, but the RDS-8000 isn't a bad one to start with.
like.2.fly is offline Find More Posts by like.2.fly
Old Aug 24, 2010, 09:44 AM
gshort72 is offline
Find More Posts by gshort72
Greg Short
gshort72's Avatar
USA, NC, Clayton
Joined Jul 2008
I agree, I have one, because it came with 2 receivers. I used it for a little while untill my sd-10g came in. It works for basic programming, but was a little shy on mix availability for my taste. I repleced the 2 pos. gear switch with a spring loaded toggle and it works great. You can have the TX for $50 if you want it.
gshort72 is offline Find More Posts by gshort72
Old Aug 24, 2010, 01:18 PM
rifme is offline
Joined Jul 2010
Sounds good to me! How do I go about paying you and getting it here?
Old Aug 24, 2010, 02:32 PM
gshort72 is offline
Greg Short
gshort72's Avatar
USA, NC, Clayton
Joined Jul 2008
pm sent
For Sale Used Futaba FP-R 138DP 8 Ch RX W/Ch 42 Crystal & RX Battery Futaba NR-4QB Postalflyer Aircraft - General - Radio Equipment (FS/W) 1 Sep 01, 2010 09:46 PM
Sold Airtronics RDS8000-FHSS 2.4ghz Tx/Rx HNS505 Aircraft - General - Radio Equipment (FS/W) 0 Aug 02, 2010 10:02 AM
Sold Airtronics SD-10G 10-ch 2.4G Tx w 2 Recievers 5ch & 7Ch Mikey 68 Aircraft - General - Radio Equipment (FS/W) 7 Apr 28, 2010 05:55 PM
Sold **NEW** Airtronics RDS8000 2.4G Mode2 Tx bigslopegrin Aircraft - General - Radio Equipment (FS/W) 3 Feb 04, 2010 12:13 PM
Sold Airtronics RDS8000 New In Box 2.4G Mode2 w/1-Tx/1-Rx Only elecwings Aircraft - General - Radio Equipment (FS/W) 1 Feb 02, 2010 02:23 PM
