Old Aug 23, 2010, 05:45 PM
Dan203 is offline
Find More Posts by Dan203
Dan203's Avatar
Joined Mar 2007
4G6 ESC getting too hot?
A few weeks ago the motor went out in my 4#6S. Instead of buying a new stock one for it I took the black TurboAce out of my 4G6 and then bought an HP07-2 for it. After installing it I discovered it had a bad cogging issue. I did some reading and found that they recommend using the ESC from a CB100, instead of the stock one, when using this motor. I happened to have an extra CB100 ESC lying around so I threw it in there. The cogging went away so I thought all was good.
However now I think the ESC might be getting too hot. I've only flown it maybe a 1/2 dozen times since putting in the new motor, but I just noticed that the clear plastic around the ESC has shrunk so much that it actually split at one of the corners and the yellow plastic sleeve around the RX is rippled slightly on the side the ESC is stuck to. It doesn't feel hot to the touch, even right after a flight, but the signs point to it getting pretty hot during flight.
Is this normal? Is it something I should worry about?
Dan
Dan203 is offline Find More Posts by Dan203
Old Aug 23, 2010, 08:18 PM
Tom Z is offline
Find More Posts by Tom Z
RC Reviews & Tx Setup Guides
Tom Z's Avatar
United States
Joined Sep 2007
Dan
Sounds normal.
My esc ran HOT also. It shrunk the heat shrink on the esc like yours is doing.
It is the L2 CB100 esc.
It's best to remove the heat shrink from the esc and it will run cooler. Don't mount it
directly to the RX. It will melt the yellow heat shrink housing as I found out.
The HP07-2 motor is an amp hog and will make you esc run hot.
My canopy was even very warm due to the heat from the HP07-2 and esc.
Not to mention the battery was very warm and the battery connector
was hot.
The motor and esc combo produces a lot of heat but runs fine.
No problems yet.
Tom
Tom Z is offline Find More Posts by Tom Z
Old Aug 24, 2010, 12:30 AM
Dan203 is offline
Dan203's Avatar
Joined Mar 2007
OK glad to hear it's normal. I didn't want ti to like burst into flames on me or something.
Dan
Old Aug 24, 2010, 02:47 AM
Timewerx is offline
Find More Posts by Timewerx
Timewerx's Avatar
Joined Mar 2010
Try this mod if applicable
http://helifreak.com/showpost.php?p=...2&postcount=40
That is for the 10A L3 ESC (stock 4G6)
Timewerx is offline Find More Posts by Timewerx
Old Aug 24, 2010, 06:28 AM
Tom Z is offline
Tom Z's Avatar
United States
Joined Sep 2007
Dan
Also mount the 6 FET's up so they run cooler. Mounting them down
will reduce the air getting to them and they will run hotter.
A heat sink would be good to keep it cooler like Timewerx said.
I want to try it. A small piece of aluminum with thermal tape attached
to the 6 FET's should work great.
Tom
Discussion How hot is too hot for my 85A ESC? 717 Power Systems 7 Aug 20, 2010 07:18 PM
Rant Too Hot to Fly RC Man Electric Heli Talk 27 Jul 26, 2010 09:12 PM
Discussion How hot is too hot for the ESC and Brushless motor? JLH Racing Car Talk 85 May 31, 2010 10:21 PM
Discussion Cularis ESC getting HOT! Need Help. outngo Power Systems 13 Sep 12, 2009 06:01 PM
Discussion Esc Getting Way Too Hot jim florentine Flying Wings 4 Aug 05, 2009 11:50 PM
