Old Aug 23, 2010, 12:39 PM
Joined Jul 2010
Gyrotor Pin tail come out.
Does anyone can put this pin back to the right place? I try many time but it is still come out. What does it is use for? Can I fix it by C.A. glue or any other choices?
jack_a is offline Find More Posts by jack_a
Old Aug 24, 2010, 12:36 PM
Michigan
Joined Sep 2003
That's the important bit...
If it won't stay in with a drop of CA, then you are kind of stuck. That "pin" is part of the sensor for the "heading lock" on that bird.
I had one and broke it in pretty much the same spot...
-McPhil
mcphil3 is offline Find More Posts by mcphil3
Old Aug 25, 2010, 02:49 AM
Joined Jul 2010
Many thanks mcphil3.
If this "pin" is a part of sensor for the headling lock then even I put it back to the right position, it will not work the same as before because this pin has broken from pole. Am I right?
Old Aug 25, 2010, 06:47 AM
Michigan
Joined Sep 2003
That is what happened to me...
-McPhil
Old Aug 29, 2010, 10:57 AM
Joined Jul 2010
Now I try without pin. It can fly even not so smooth as before.
Discussion Video TX,doesnt want to come out and play ! Donjuanzx9 Video Piloting (FPV/RPV) 3 Aug 18, 2010 04:58 AM
Discussion AR 500 rcvr pin out hook up Please! Swaneyjoe Power Systems 2 Oct 16, 2009 07:26 PM
Discussion GT power Software and USB Pin Out pedewrecker Electric Power Cars 0 Sep 06, 2009 11:01 AM
Discussion come out come out wherever you are (scott RC TEK) Eeeeky Mini Helis 14 Dec 05, 2006 06:34 PM
Question GWS A-10: Come out, come out wherever you are! Steve Wrona Parkflyers 4 Dec 30, 2001 02:36 AM
