Joined Jul 2012
(Which would be why the NASA report said the KFm1 acted somewhat like a flate plate airfoil) |
Here was our thinking at the time we filed for a patent. We only wanted to patent a step or discontinuity, not an entire profile. The reason was that we knew it worked in so many different ways we couldn't patent them all. Our patent drawing showed a flat upper surface with a sharp leading edge and a step on the bottom 50% back from the leading edge. Why on the bottom? Because we knew that the step on top showed higher L/D than the step on the bottom. We also believed that when an aircraft goes from subsonic to supersonic the characteristics reverse themselves. Thus, we showed it on the bottom wanting to pick up the higher numbers supersonicly. Inspite of the sharp leading edge and the step on the bottom, the KF airfoil still refused to stall out beyond 50 degrees AOA, while other NASA airfoils were all losing lift much earlier. There is a diagram that shows this in the book Fluid Dynamics by Frank White which was published in 2004. This is basically what led to how things on the KF evolved. Our purpose was to patent just a step which would trap a vortex and provide greater stability and stall resistance. |
Joined Dec 2012
67degree aoa
I went to look at the information posted from that page of Fluid mechanics, Dick...
In part, it's misleading... In reference to the X-29 'flying' at a high, 67degree aoa... Hogwash! I watched the vid of the x-29 in action and reviewed some of the specs... They have control surfaces ALL OVER that aircraft, and are controlling it by computer ! Oh.... HUGE thrust ! It's possible to fly a brick with enough thrust! In the vid I watched, it's obvious the canard is in what we might consider to be an acceptable aoa... and they've also got strake flaps on it, at the rear of the craft. ...probably close to vectored thrust! No doubt they were able to garner much valuable information from sensors placed on the aircraft while they were bashing it about the sky, but they were NOT flying that wing! lol I wouldn't doubt it was much more than an impediment for much of what was going on. ....they were seeing how far, and what they could do with those fancy swept forward wings stuck on the sides of the fuselage! IF I had any sort of specialized training I'd really be able to shred that part of the presentation in the book... just because something made it into print does NOT mean it is gospel ! There's most likely a ton of literature out there from the Flat Earth Society. :-) IMO, with NO scientific background or certification of competence, support for the KF step would most likely be found in data compiled on turbulators. KF step is a full - length turbulator. Perhaps there may be support in the work of Rutan. Best rc EDIT!!! I really mangled that statement! What I meant to say was, IMO, (I have NO scientific background or Certification of Competence), KF theory is probably related to turbulators. ..that part was meant to be my own personal limitation... |
Joined Jul 2012
The idea that the KF step could possibly be acting as a turbulator was the primary reason I chose a thick airfoil in my wind tunnel test. Also when I did the wind tunnel testing of the KFm4 airfoil, I did not find that it had a huge improvement in terms of stall angles as that book claims. Rather I found it stalled perhaps 4 or 5 degrees above the control airfoil. |
40% seems to be the preferred position for a KF step.
Turbulators are usually deployed further forward. My theory is that for 'our size' wings we need to consider the airflow, not around the airfoil itself, but the airflow over the boundary layer. The boundary layer and flows adjacent to it form a Virtual Wing Section which is variable and adaptive. On a full-size wing the boundary layer is a small fraction of the cord. In 'our' size it has much more significance. This theory can help to explain how wing-sections that literally would not get off the ground in full-size aviation work OK for us. I am referring here to horrors like the thick, sharp edged purely rectangular "wing sections" that some guys chop out of foam and fly quite successfully. In the case of my little test glider the airflow over the boundary layer of the rear part on the Ca section was probably very similar to the airflow over the boundary layer of the turbulent air behind the step. |
Joined Jul 2012
btw, I made a mistake, I meant the KF airfoil should act as a vortex generator (slight difference, similar effect)
But anyway, wouldn't the success of the barn door wings be more mainly due to the amount of power/weight ratio the RC community has access to so that the R/C plane can power through the relatively high amount of drag? |
Joined Jul 2012
Reason is that my report for high school is still being submitted so I don't want to release the data until later.... The only thing I did do was post a video of my tests |
Joined Dec 2012
Yes, I'd have to agree with that, W.... I think.... what many rc fellows fly today resembles the equivalent of the GeeBee racer. and I've also watched those awesome vids of fellows hanging on their props, tail tapping!!! Wowee! What fun they are! I really should study turbulators more... I'm aware they exist, and that's about it. For lift, my preference would be a retractable leading edge slat and Junkers styled flaps... and as you mentioned with scale, I am not aware of how a fixed leading edge slat could be practical on an inexpensive model craft. (There's apparently someone up in Alaska installing slats on SuperCubs) All told, the KFm airfoil step is a wonderful opportunity to experiment ! rc |
Joined Dec 2012
may we watch your vid? :-)
I've said so in some prior post... much of my knowledge of turbulators comes from an AOPA article on Rutan's Boomerang. You may wish to see if it is available. There was also a bit of hush-hush mention of Rutan's crew quietly discussing "Thrust inducing vortices". You might find that particularly interesting???? rc |
Joined Jul 2012
It's nothing too special. Just showing airflow around the airfoil. But if you look closely, you can see a big blob of smoke shedding and then reforming rapidly, which I assumed were the vortices shedding and then reforming. |
If you've seen any of the vid capture of my Longhorns transitioning from horizontal flight to prop hanging then you'd see the effects of P/W ratio. A purely flat plate wing can produce "lift" by simply deflecting the apparent wind downward. The KF wings produce actual lift at lower airspeeds and lower AoA. Obviously we're still trying to noodle out what's happening, but the net effects are visible to the most casual of observers. You can't deny that KFs offer lift. Drag, too, but let's not discount the lift.
| Thread Tools | |
| Discussion ** Kline-Fogleman (KFm) Airfoils - Building/Flying Discussion ** | jackerbes | Foamies (Scratchbuilt) | 5874 | Today 10:02 PM |
| Discussion ** Kline-Fogleman Airfoiled Flying Wing ** | Tony65x55 | Foamies (Scratchbuilt) | 3938 | Apr 08, 2012 06:07 PM |
| Cool Here is my KFm-5 DLG GLider (Kline-Fogleman) | dougmontgomery | Foamies (Scratchbuilt) | 149 | Feb 16, 2011 12:12 AM |
| Video Kline Fogleman Airfoil on a flying wing | Tony65x55 | Electric Plane Talk | 3 | Jan 30, 2009 07:37 PM |
| Idea Per Dick Kline, Kline-Fogleman test | dougmontgomery | Hand Launch | 49 | Apr 13, 2007 02:13 AM |
