Richard Whitcomb designed the supercritical wing, which is flat on top and cambered on the bottom with a small cusp on the underside near the trailing edge. It almost looks like the beginnings of a small step. The purpose of the flat upper surface was to reduce the sonic boom. He was also the inventor of the coke bottle fuselage. ~ Dick |
This seems interesting...
Just found this video that was posted this month...seems that the small step improves the L/D
Does anybody know if the Applied Aeronautics group at UIUC has ever tested a KF airfoil section as part of their low-speed airfoil program? They've tested a lot of airfoils specifically at the request of RC modeling groups.
http://www.ae.illinois.edu/m-selig/uiuc_lsat.html Near the bottom of that page is the following text: Quote:
Canada, ON, London
Joined Nov 2010
The success of the KF airfoil at low Re numbers might have nothing to do with the theory posited by Kline and Fogelman. Wind tunnel tests done with a corrugated airfoil modelled after a generic dragon fly mid-span section show the entrainment of vortices behind the corrugations at Re = 34,000. The corrugated airfoil had higher drag at low AoA, but a higher stall AoA, and higher L/D since the airfoil attained a higher coefficient of lift before stall. The step on the KF airfoil might cause the favourable attributes frequently cited for these airfoils by the entrainment of a vortex(s) in the manner observed for this corrugated airfoil.
If this is true then there is room for a lot of work to determine the Re number range for which the the effect can be used without undo drag; best leading edge shapes; cord lengths for corrugations; relative height of the corrugations; best shapes for the bottom of the airfoil etc. It would be wonderful if somebody with a wind tunnel at their disposal could do some systematic testing - one variable at a time! |
Sounds like a great project for a retired engineer type!
Interesting comments, but I think the KF theory is just that: entrained vortices that increase lift at high AoA, and mitigate stall severity along with increasing drag somewhat. And the work by Viking with multiple steps seems to further correlate with the "corrugations" idea. |
Latest blog entry: OSE One Sheet Edge 540 Video
USA, ME, Ellsworth
Joined May 2008
"..But what about the KFm1?..."
That is the one that proves that Bernoulli's principle should not be applied to flight, only to the flow of liquids. Other than that we are all still wondering what the heck is going on there...Jack |
Others may disagree, and that's perfectly fine, however I've yet to see any sensible explanation as to how a step on the bottom of an airfoil could prevent flow separation on the top of the airfoil ... After all, the air flowing over the top of the wing has no 'idea' what the bottom of the wing looks like
Canada, ON, London
Joined Nov 2010
I managed to find that article: http://www.public.iastate.edu/~huhui...orrugation.pdf
Definitely worth a read. |
Canada, ON, London
Joined Nov 2010
I think that you are right on this Jetplane. In the range of Re. #'s where separation occurs before transition to a turbulent boundary layer I suspect that there would be little if any difference in performance between a flat plate and an otherwise similar Kfm1.
That's an interesting read. It does show very well the benefits of turbulation at low Re numbers, but I suspect they structured the test in a way that was very biased toward gaining favourable results for their corrugated airfoil idea. For instance:
Steve |
| Thread Tools | |
| Discussion ** Kline-Fogleman (KFm) Airfoils - Building/Flying Discussion ** | jackerbes | Foamies (Scratchbuilt) | 6030 | Yesterday 01:54 PM |
| Discussion ** Kline-Fogleman Airfoiled Flying Wing ** | Tony65x55 | Foamies (Scratchbuilt) | 3938 | Apr 08, 2012 06:07 PM |
| Cool Here is my KFm-5 DLG GLider (Kline-Fogleman) | dougmontgomery | Foamies (Scratchbuilt) | 149 | Feb 16, 2011 12:12 AM |
| Video Kline Fogleman Airfoil on a flying wing | Tony65x55 | Electric Plane Talk | 3 | Jan 30, 2009 07:37 PM |
| Idea Per Dick Kline, Kline-Fogleman test | dougmontgomery | Hand Launch | 49 | Apr 13, 2007 02:13 AM |
