This thread is privately moderated by maguro, who may elect to delete unwanted replies.
Old Nov 17, 2011, 09:43 AM
dave1993 is offline
Find More Posts by dave1993
RC beginner
New York
Joined Oct 2008
Originally Posted by rdeis View Post
Mathematically, though, isn't stall is when Cl drops to zero, (which generally occurs when flow separation occurs?)
i dont think stall occurs on separation but rather happens long after separation begins. in fact maximum lift coincides with quite advanced separation as seen in the diagram below from a well respected aerodynamic text. stall occurs at critical angle of attack only after separation is virtually complete. imo it is the actual separation that is responsible for kf characteristic slow flight and friendly stall.
dave1993 is offline Find More Posts by dave1993
Old Nov 17, 2011, 10:14 AM
Dickeroo is online now
Find More Posts by Dickeroo
Dickeroo's Avatar
Joined Dec 2006
The VortexCell Project
Does anyone know whatever became of the VortexCell2050 Project?
Dickeroo is online now Find More Posts by Dickeroo
Old Nov 17, 2011, 10:36 AM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
I looked at that when it came up a year or so ago and while there was this site:
http://www.vortexcell2050.org/index.php
I was not a member and could not get into the "members area" so if any results are there, they require a member's login to be accessed. Like a lot of developmental sciences, it looks like a boondoggle to me. And that is much like the KF foil has appeared to be to those that are not using it in modeling.
When I look at the details of the Vortexcell2050 wing thicknesses and the size and shape of the vortex cavities (in the pdf files that Dick posted) I really lost interest in it. What they were studying would have been very impractical to build in FFF or similar sheet foam materials. It might have lent itself to molded foam wings or something like that.
The chord to thickness ratios on the VortexCell2050 wings was sort of bizarre, looked like a cartoon.
Jack
jackerbes is offline Find More Posts by jackerbes
Old Nov 17, 2011, 12:31 PM
JetPlaneFlyer is offline
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
The neat thing about Kf is that the Cl doesn't do that, but rather ralls off gradually.
No, technically stall is the point where Cl reaches it's maximum and begins to fall, so in fact it's as far from zero Cl as it's possible to get.
As i mentioned a few times previously, any proper testing that's been done on models shows a quite conventional stall, as shown in the tufting tests linked in my last post.
JetPlaneFlyer is offline Find More Posts by JetPlaneFlyer
Old Nov 17, 2011, 12:38 PM
Aberdeen
Joined Mar 2006
That's true, separation starts before the wing fully stalls. Stall is the point where separation extends to such an extent that the lift produced by the wing decreases with increasing AoA rather than increases, but it is separation that causes stall and separation is ALWAYS a bad thing. In addition to reducing lift separation also massively increases drag.
Planes use all sorts of devices to prevent stall, turbulators, vortex generators, leading edge slats, boundary layer suction, flap blowing; these are all methods of preventing separation and if you can prevent separation you prevent stall.
Old Nov 17, 2011, 12:54 PM
rdeis is online now
Find More Posts by rdeis
AMA 353531
rdeis's Avatar
United States, CO, Colorado Springs
Joined Aug 2003
OK. So proper description of the benefit then, isn't that they don't stall or that they stall late, but merely that stall behavior is very benign.
In flying terms it doesn't feel so much like stall, but more like a mush. Yes?
rdeis is online now Find More Posts by rdeis
Old Nov 17, 2011, 02:18 PM
Aberdeen
Joined Mar 2006
Yes, i think that's the benefit most seem to report, a very gentle and benign stall.
I'll be able to make some first hand comments once i get my KF winged Elf discus launch glider in the air...
Steve
Old Nov 17, 2011, 07:15 PM
springer is online now
Find More Posts by springer
treefinder
springer's Avatar
SE MI
How close are you?????
springer is online now Find More Posts by springer
Old Nov 17, 2011, 07:57 PM
Whiskers is online now
Find More Posts by Whiskers
Build straight - Fly twisty
Whiskers's Avatar
Australia, QLD, Little Mountain
Joined Feb 2010
Originally Posted by Cap_n_Dave View Post
Not sure what you mean by this.
If the purpose of the test is to examine properties of KFm sections/wings at "model airplane Reynolds Number(s)," then the person conducting the test must ensure the Reynolds Numbers match (i.e. the Reynolds Number of test section/wing matches "model airplane Reynolds Number(s)").
What I mean is this:
The test sections can have a cord dimension similar to that of a medium sized model.
That is, a full-sized wing section.
The air can be puffed down the tunnel at speed similar to the airspeed of foamie models.
So no 'scale effects' are involved.
Of course, if we tried to test little models of our models the situation would be very different.
Whiskers is online now Find More Posts by Whiskers
Old Nov 17, 2011, 09:33 PM
rdeis is online now
AMA 353531
rdeis's Avatar
Joined Aug 2003
Or, said a different way- test measurements can be made at appropriate reynolds numbers so that the data is not skewed by "scale effects" resulting from using full-scale-like reynolds numbers?
Agree.
Old Nov 17, 2011, 09:34 PM
rdeis is online now
AMA 353531
rdeis's Avatar
Joined Aug 2003
Looking forward to that, I need a DLG myself and the Kf price is hard to beat...
Old Nov 18, 2011, 12:35 AM
Aberdeen
Joined Mar 2006
Very close. life has been hectic of late so not much time to do any building but all i need to do is glass the wing join. I could probably have got away without the glassing if not for the error with the bottom spar cap, but as it is the glassing is essential otherwise the wing would rip-off under DLG launch stress.
Weather permitting i should fly it this coming weekend.
Steve
Old Nov 22, 2011, 01:26 AM
rpage53 is offline
Find More Posts by rpage53
Boffin
rpage53's Avatar
Victoria, BC, Canada
Joined Apr 2001
The project wrapped up this year with inconclusive results. A passive flow control (i.e. a step alone) didn't work. Active flow control could work but only at a single angle of attack. I think they are being quiet while they try to find money to do more research.
Rick.
rpage53 is offline Find More Posts by rpage53
Old Nov 22, 2011, 07:29 AM
Dickeroo's Avatar
Joined Dec 2006
Thanks, Rick
Rick.
Appreciate your input.
Dick
Old Nov 24, 2011, 02:42 PM
rpage53 is offline
Boffin
rpage53's Avatar
Joined Apr 2001
I should add that the Vortex team feel they are on the right track, they just need more work, and have been giving a lot of oral presentations in Europe. I haven't noticed any published papers but I haven't been searching.
Rick.
Discussion ** Kline-Fogleman (KFm) Airfoils - Building/Flying Discussion ** jackerbes Foamies (Scratchbuilt) 8237 Today 06:39 PM
Cool Here is my KFm-5 DLG GLider (Kline-Fogleman) dougmontgomery Foamies (Scratchbuilt) 151 Apr 21, 2014 09:08 AM
Discussion ** Kline-Fogleman Airfoiled Flying Wing ** Tony65x55 Foamies (Scratchbuilt) 3945 Apr 08, 2014 10:40 AM
Video Kline Fogleman Airfoil on a flying wing Tony65x55 Electric Plane Talk 3 Jan 30, 2009 07:37 PM
Idea Per Dick Kline, Kline-Fogleman test dougmontgomery Hand Launch 49 Apr 13, 2007 02:13 AM
