USA, ME, Ellsworth
Joined May 2008
"..focus your testing on Tony's 4 airfoils or Dick's 8 airfoils that they have provided..."
I have had questions before as to how to get the airfoils to be smoothly shaped and rounded and exactly as they are seen in the second figure with nine airfoils and not in the first figure (tony65x55's image) as line drawings showing the foam layers. That second image was generated by HopalongX (IIRC) when we were getting the Building/Flying thread started. In case it is not clear to anyone, the airfoils in that newer image are slightly artistic or stylized renditions of typical build results of the various airfoils. Tony's original image showed the foam layers and actual build details more realistically (spars are seen, etc.). New builders often got a little wrapped around the axles on the details and in trying to copy what they saw there in the original figure. But I think it is fair to say that time has proven that Tony's drawing is not a building plan, just a helpful projection of how to build. In the original figure I consider the airfoil presentations to be inaccurate or impractical for the following reasons: 1 - The curves on the top surfaces and the leading edges show shapes that are not usually or realistically attained with the material most are using. 2 - The spars are not realistically scaled relative to the foam thickness, 3 - The spar placement and center panel width in the KFm4 is not realistically going to produce a flyable wing, 4 - At least one of the specifics, the 9-12% thickness on the KFm4, has been reduced to 7-9% in the newer figure as the 9-12% wing simply did not fly as well, And there are probably other things like that there too. So the airfoils in the newer figure were intentionally drawn in a less specific manner and the intention is that the build attain the outer wing profile however the builder's material and techniques dictate while building the wing to generally meet the step locations and wing thickness mentioned below the figure. For the more scientific testing here, it might be a good idea if the participants agree to a set of line drawings for the outer wing profiles with more precisely defined step location, heights, and wing thicknesses. And it might even be a good idea that the line drawings be based on the arrangements of the materials most often used and the profile that would actually occur. That would be that foam thickness is just about 1/4", spar thicknesses and widths be that of commonly used balsa, basswood, or other materials, leading edges be more realistically like those actually produced (two layers stacked and rounded, the factory folded edge, etc.). The point of all this is that the wings being tested be more similar in shape and configuration from one tester to another. Or not? I'm not even sure yet what the goals of the testing will be. Will it be to see how the ribbons flutter? And what produced the "best" flutter? Jack |
Jack, I agree with you about the airfoil shapes. The airfoils depicted in the "KFm Family of Airfoils" are stylized representations and not depictions of what we would ever build. They do however give one the idea of how a streamlined version of a KFM airfoil might look. Consider it modern art.
The way I see it, there are two schools of KFM construction: 1) Basically flat surfaces possibly with a rounded leading edge, 2) curved upper surfaces that attempt to mimic accepted airfoil shapes. This may include tapered trailing edges such as Viking60 uses. Since both are very commonly used, both should be tested. The more I think about, the more I agree with you, that we should publish our test plans, including the planned design and construction of the wing. This will allow others to provide input, and possibly use the same design/construction for additional testing. The value of any test will come down to how well it is documented. Part of the documentation should include detailed diagrams/photos of the construction of the wing being tested. The documentation should provide enough information, that another person can duplicate the experiment, or carry it further. Roger |
Jack wrote: " And it might even be a good idea that the line drawings be based on the arrangements of the materials most often used and the profile that would actually occur. That would be that foam thickness is just about 1/4", spar thicknesses and widths be that of commonly used balsa, basswood, or other materials, leading edges be more realistically like those actually produced (two layers stacked and rounded, the factory folded edge, etc.).
The point of all this is that the wings being tested be more similar in shape and configuration from one tester to another. " This is where I would like to offer a different viewpoint as 'food for thought'. I don't want to step on any toes here, or dampen anyone's enthusiasm... I just want to add in some observations from my perspective. And from that perspective, letting the dimensions of commonly available materials dictate the shaping of airfoils seems counter-intuitive and counter-productive. How much MORE performance can we achieve by allowing ourselves to think ouside of that box? The Short Of It: From all of my scratch-building of glider & sport aircraft wings since the early 1980s, and through all of my own KF foamie wing builds over the last ~4 years, I've developed this perspective: The shaping of the forward 25% (to 50%) of the wing's airfoil (or lack of shaping) can have a very profound affect on a wing's ability (when the power is turned off) to cleanly generate lift, it's ability to penetrate wind, and it's ability to glide efficiently and cleanly in the power-off glide mode. Oh yes, it's easy to overcome drag by simply adding excess power, and this is the most often recommended design approach these days on this discussion forum for the typical RC foamie.... And there are aircraft designed for different flight performance tasks - super slow flight, or heavy lifting, or 3D aerobatics, as examples, where minimizing drag and achieving optimum glide & wind penetration performance is not necessarily the priority. But I would like to suggest that you can learn a whole lot more about a wing's actual performance when the power is turned off. I do all of my test flying at 10,000 feet ASL, with ~16% lower air density. And I occasionally fly at locations well above 12,000 feet. Some aircraft which are said to fly fine at sea level are real 'pigs in the air' when you try to fly them up here... The Goldberg Cub, with it's classic Clark Y airfoil, is an example of this which comes to mind... when flown at a float fly I CD'ed at Kite Lake up at 12,000, it was shown to be a terribly stall-prone wing- not at all fun to try to fly, & one which experienced repeated dunkings. (Yet it flew 'fine' at 5000 feet ASL, according to it's owner.) Recent test initial summary: My most recent KFm3 type wing build was started with a very fat rounded leading edge... a nice easy place to start when building... It flies OK with power on, but when the power was turned off and it's trying to glide, it was too draggy & had a very narrow range of angle of attack (adjusting balance and elevator trim setting) where it would glide somewhat decently. Next, I took the heat iron to it and began to heat-form the wing's leading edge, shifting the airfoil's L.E. entry point lower and lowering the upper surface's profile for the forward 15% of the airfoil. I also worked in the lower L.E. surface with the heat iron, giving it more of what is referred to as 'Phillips Entry'. (Refer to the MH32 airfoil which I previously used for the Me163-e Komet build for an idea of what I was starting to work toward with this reshaping.) After these airfoil shaping modifications, it glides far more efficiently, and it is far less 'touchy' as far as the elevator trim / angle of attack for optimum glide. I'll do further testing with the new sleek fuselage with the folding prop once I get my work schedule cleared again- (busy times!) So what does this have to do with KF stepped structures, you ask? Just this: the KF steps can only influence the airflow aft of those steps.... but that airflow dynamic starts from just in front of the wing's leading edge, and there is so much potentially happening forward of where the stepped structures are implemented. It's difficult to evaluate possible added drag affects from step placement & height when you start with too much drag from the forward wing structure's shape! Bottom line: If you try to define a 'universal' testing approach where you restrict yourself to only use the profile of the rounded Bluecor / FFF panel fold as your leading edge, you may be starting with a 'drag penalty' and an inefficient leading edge shape/ contour, making it far more difficult to evaluate the drag-increasing or drag-reducing affects produced by the various configurations of KF type stepped discontinuities which you are attempting to evaluate. So for some testing purposes, I am inclined to start with a better-performing airfoil shape for the area forward of the stepped discontinuities. I'll post reports once I get back to doing further flight evaluations with the new low-drag fuselage. VIKING |
Joined Jun 2009
OK, well I guess we are definitely on the opposite end of the spektrum, when it comes to testing out stepped (KF) airfoils.
![]() ![]() Dick Kline's patent uses the word "step-like" in the description to discribe his airfoil. This thread is titled "Kline Fogleman...". When I put the two together, I came up with a place to have a general discussion on stepped airfoils and to hopefully take it to another level. These basic sections have been built over and over. At what point do we move foward? Building 10oz. planes over and over, to me does nothing for the science of KF airfoils. We know they can fly. I'm going to breifly give an example of foward movement when it comes to advancing the science of KF airfoils. You may or may not have seen my Horten wing. I'm not going to go into any great details right now. I'm simply using it to relay a point of foward movement. Some of you may also disaprove of the modifications that was made to the KFm4 airfoil. The wing was designed around the basic KFm4 airfoil section and was an experiment with a modified step design to control airlow over the wing. It was also a test to remove the myth that flying wings need wing washout, dihedral, reflex... to maintain adaquate control. Well, it's flying without all that. Even after nine months and it was all done with a stepped airfoil. F.Y.I. The design modification I used on the Horten wing will not benefit light weight wing designs. It likes to go fast. Wind or no wind. Let's get the basic data and move foward with our designs. Also, if you need data from fast, heavy, wind penetrating KF designs. I can help in that category. ![]() ![]()
The whole idea here is to advance our knowledge of KF airfoils, not limit design options. Viking takes the KF step and applies airfoil refinements to it. WJSFLYWING you modified the KFM4 to your advantage.
No one wants you to stop what you are doing, far from it. The important thing is to document the builds, so others can duplicate your work (Viking I know you do this in spades). Conduct specific tests, collect data, make some modification, repeat. Once you are done with the particular series of tests, report your findings with as much quantifiable data as possible. I hope this thread will help us advance our knowledge of KF airfoils and how we can best use them. It would be nice if we could advance the knowledge of how/why KF airfoils work, but without a wind tunnel I don't know how much we can do here. Roger |
wjsflywing, and viking60,
Wow all good points. Looks like this is prime time for both of you, and others to test different aspects of what makes the KFm airfoils optimum. No need for everyone to concentrate on the same tests all at once. viking60, The forward of the step issue makes great sense, and testing with refined leading edge design, compared to 'standard, whatever shapes, would be very interesting data as you have explained on your recent KFm3 build. I would trust most data prepared by someone that took the time to show these differances, no matter how 'subjective' others may call it. I could see some graphics designed to refine the current 'art' showing KFm wing configurations after it is all refined wjsflywing, You design modifications that improve fast, heavy, wind penetrating KF designs, is a great addition. I live in the most unfriendly wind area I have ever been. Mid-West USA, great plains, no natural wind breaks, hundreds of miles of open range creates some nasty weeks on end of blowing fury. This would interest me and all my flying pals extra special. Even scienctists argue all the time over even faily simple things. They often do not believe anything unless you can prove it, but that proof has to be proof they agree with. Get the point. Any testing and results is furthering the KFm airfoil knowledge base and welcome with open arms. We may all have to deal with some arguing scienctists, forever! I'll always remember Burt Rutan likes to refer to NASA as Nasta! Too boggled down in pure science to make strides like Burt has over simple things he's observed, like a shuttle cock, leading to Spaceship One, and winning the Ansari X-Prize ($10,000,000.00 US isn't bad either). Fred |
--Norm |
I squat corrected. Norm, are you saying that the trailing edge wedge might be a useful feature to test out on R/C planes? The Google search you pointed to mentions this device in a number of patent references, but there don't seem to be any current aircraft manufacturers using it. Even Boeing and M-D apparently aren't using the thing, and they were supposed to be its main proponents.
If I read that first patent proposal correctly, the wedge was used as a tuning mechanism to correct manufacturing or aging defects. I'm not sure that has any real application to what we're doing; my foamies contain nothing but manufacturing anomalies. Heh. |
| Thread Tools | |
| Discussion ** Kline-Fogleman (KFm) Airfoils - Building/Flying Discussion ** | jackerbes | Foamies (Scratchbuilt) | 5905 | Yesterday 05:33 PM |
| Discussion ** Kline-Fogleman Airfoiled Flying Wing ** | Tony65x55 | Foamies (Scratchbuilt) | 3938 | Apr 08, 2012 06:07 PM |
| Cool Here is my KFm-5 DLG GLider (Kline-Fogleman) | dougmontgomery | Foamies (Scratchbuilt) | 149 | Feb 16, 2011 12:12 AM |
| Video Kline Fogleman Airfoil on a flying wing | Tony65x55 | Electric Plane Talk | 3 | Jan 30, 2009 07:37 PM |
| Idea Per Dick Kline, Kline-Fogleman test | dougmontgomery | Hand Launch | 49 | Apr 13, 2007 02:13 AM |
