This thread is privately moderated by maguro, who may elect to delete unwanted replies.
Old Aug 24, 2010, 06:57 PM
A Useless Geek is offline
Find More Posts by A Useless Geek
just Some Useless Geek
Chicagoland
Joined Oct 2008
This is substantially the same message I got from him, so he hasn't changed his mind about this stuff.
A Useless Geek is offline Find More Posts by A Useless Geek
Old Aug 24, 2010, 11:28 PM
Freddie B is offline
Find More Posts by Freddie B
Addicted to building...
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
jackerbes,
Thank you for posting the Rich Thompson (KAOS2) data and article. I had read that with great interest a while back. That is one of the best posts done on KFm airfoils in my opinion. Although many will argue the validity of his testing as subjective, there was a whole lot of work and effort put into that! I don't think I've seen anything quite as extensive on the KFm threads, subjective or not.
I know this is the kind of thing that this Theory/Science thread needs, and more. Lab equipment, wind tunnels, etc are not in the grasp of most RC modelers, so I will enjoy any data shared with at least an honest attempt to show results from some controlled experiments.
Heck I don't have enough time to build 8 different wings right now for the same airframe, let alone do the article, graph, and all thar Mr. Thompson did. Hat's of there to that test program.
Given that wind tunnels and other equipment has existed for many years before I was born, still many full scale birds proved their worth, or failure, after all the testing and the first test pilot took it to the air. Hope some good RC test pilots share their real world flight data, if at least it has some real thought, and specifics to the reporting.
Fred
Freddie B is offline Find More Posts by Freddie B
Old Aug 25, 2010, 08:15 AM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
I have to agree with you about the quality of that study. It stands out as clearly the best effort to date in my mind. If anyone feels a need to impugn that effort I invite them to put their money where their mouth is and better it.
To be able to see some lift to drag data and compare it to the subjective results from studies like Thompson's would really be interesting.
I went part way through the KF Flying Wing thread (I think of it as the Zagnutz thread) and made a list of posts and documents that I thought might be of historical and technical interest to the K-F airfoil. I am attaching that list as a text file if someone wants to look at it. You can copy and paste the the links there to see the posts or documents.
There is some interesting stuff there from the Zagnutz thread discussions in the early days.
Jack
jackerbes is offline Find More Posts by jackerbes
Old Aug 25, 2010, 10:15 AM
viking60 is offline
Find More Posts by viking60
High Altitude Flyer
viking60's Avatar
Fairplay, South Park, CO
Joined Sep 2005
I have my own thoughts & concerns about steps / discontinuities which are too far back & too tall messing with airflow over ailerons and producing far too much drag on a wing. I've written about this before, but testing the concepts means building & flying. So I decided to build up a new KFm3 variant test wing to which 'extender' panels could optionally be temporarily added & removed behind each of the discontinuities/ steps.
I just finished up this new 48" span wing shown in the photos below to this point yesterday. It started at 10" chord in the center, and 8" at the wing tips. That's about 3 square feet of wing area. The hot melt glue did the trick for a fast build-up. I also used balsa aileron stock that I had on hand. The upper forward surface's Bluecor material was shaped / curved by rolling it over a ~4" tube before the wing went together to give it the shaping I wanted; the filler strip just behind the leading edge also helps produce the airfoil shaping of the leading edge.
The fixed forward / primary step is at about 38% of chord, while the fixed rear / secondary step is at 64% in the center, tapering to 56% of chord at the wing tips. Ailerons start just outside of the prop arc in the center, and end 1-5/8" in from the wing tips. I'll set the aileron servo today & start test flying it if all goes well.
I laid out this wing so that I could temporarily add and remove filler strips behind each of the steps to see how they affect the handling / performance of this wing. I can also mount a variety of wing tip plates / structures to see how they affect the handling. It's all very interesting, & all fun!
(I like Rich Thompson's comments at the end of his article about the value of subjective evaluation, and about the 'feel' of an aircraft in the hands of an experienced pilot. The cameras just don't pick up on a lot of what the pilot experiences as far as aircraft response to their control inputs while flying... that's the 'rest of the story'.)
I'll post updates as the flight evaluation progresses.
VIKING
viking60 is offline Find More Posts by viking60
Old Aug 25, 2010, 11:07 AM
lake flyer is offline
Find More Posts by lake flyer
lake flyer's Avatar
Joined Nov 2005
From the chart it looks like Clark Y or symetrical are the best . Especially when you consider the weight to strength ratio and the torsional rigidity , which were left off the chart .
lake flyer is offline Find More Posts by lake flyer
Old Aug 25, 2010, 11:20 AM
maguro is offline
Find More Posts by maguro
OpenTX University Staff
maguro's Avatar
United States, DE, Bear
Joined Apr 2007
Viking,
That's a great start. I like your curved airfoil surface. I use the same basic technique on my KFM wings. Do you planr to do any quantitative testing along with the qualitative testing?
Some yarn tufts on one wing, and a keychain video camera would provide a lot of data. Add a video camera on the ground so angle of attack and airspeed can be estimated would be of great value in combination with your evaluation of the performance obtained.
Roger
maguro is offline Find More Posts by maguro
Old Aug 25, 2010, 01:22 PM
grenadapult is offline
Find More Posts by grenadapult
Foam Fighter and a Bloody Mick
grenadapult's Avatar
Hermann, MO
Joined Jul 2008
This thread is great news. Instead of just talking about how awesome the KF airfoils are, we will prove it, and push the boundaries. I'll gladly put some lufts on my 60" twin boom KFm3 and post the video here. I can stick my keychain cam on the center of the wing pointing toward the tip. Should work great.
Flight of theBoomBox part 1 (10 min 1 sec)
grenadapult is offline Find More Posts by grenadapult
Old Aug 25, 2010, 01:28 PM
jhtitan is offline
Find More Posts by jhtitan
jhtitan's Avatar
Washington MO
Joined Jul 2008
Originally Posted by maguro View Post
I've been thinking that we are going to need some aircraft designed for our testing purposes. The have to be easy to build, and capable of carrying any data recording equipment we might put aboard. There will have to be different types of aircraft as well. A high wing for trainer/cargo aircraft, and a mid-wing for aerobatic/high speed/high alpha performance.
The high wing is not hard to design with replaceable wings, but a mid-wing aircraft will need wings that are easily built and attached, without being too complicated. Existing designs that can be bent to our purpose are easier than designing from scratch. Does anyone have recommendations?
Roger
It is another of Tony65x55's designs but the Piranha would be a good one to test mid wing airfoils on, I built one a while back with both KFm3 and 4 wings for it but I had a bad landing cause me to abort testing before I got to try the KFm3.
I love this thread and am subscribed.
I would like to offer up my CNC machine and meager CAD/CNC skills for testing purposes if you find a need for them. I can duplicate designs with more than a fair amount of accuracy, I also have a larger UAV style plane I am working on with a KFm3 airfoil that wouldn't be hard at all to swap out other airfoils on. It is a high wing style aircraft with a 60" wing. currently made from 9mm EPP on the wing.
I have video of it on youtube under rcFFBloodyMicks channel if anyone is interested.
I will keep watching this thread, PM me if I can help with anything.
Jon
jhtitan is offline Find More Posts by jhtitan
Old Aug 25, 2010, 01:32 PM
viking60 is offline
High Altitude Flyer
viking60's Avatar
Joined Sep 2005
Viking,
That's a great start. I like your curved airfoil surface. I use the same basic technique on my KFM wings. Do you plan to do any quantitative testing along with the qualitative testing?
Roger
Yes, as I mentioned in the other thread a couple of weeks ago, I have a keychain video camera that is set for close-up focus, which will work well with the yarn tufts or fluorescent orange thread taped to the wing's surface in various areas. (Newegg & DHL have taken a ridiculous amount of time to deliver the class 6 microSD card I ordered for this camera way too long ago... I'm STILL waiting...)
I want to get a close look at the circulating vortexes behind the steps, as well as the affects of the steps on the airflow. Hopefully this video technique will show this well enough. I'm particularly interested in what's happening in the wing tip areas on various wings.
(Later, I'll re-post the observations of the very noticeable drag reduction on the Soarbird4 wing achieved by eliminating the upper (KF sytle stepped) layer in the very outer end of the elliptically up-swept wingtip. It would have been neat to video the before-and-after on that morphing experiment right on the wing, but the excess material was cut away & thrown away... ah, well)
This on-wing video camera technique, along with significantly placed thread / yarn tufts should allow us to get a good look at what's happening... so for those of us on a shoestring budget who certainly can't afford a wind tunnel, we can optionally just put the little inexpensive camera where it's most helpful.
VIKING
Old Aug 25, 2010, 02:27 PM
Dickeroo is offline
Find More Posts by Dickeroo
Dickeroo's Avatar
Joined Dec 2006
I am amazed at the creativity and problem-solving that's going on here.
What is so exciting is the solutions that people come up with and do it without expensive equipment. Finding ways around barriers and solving problems is for me the greatest kick you can get. Once the barrier is overcome, then it looks so easy and simple to someone else, but not until the creativity and problem-solving brain kicks the door in with the solution. I love it.
Dickeroo is offline Find More Posts by Dickeroo
Old Aug 25, 2010, 03:43 PM
maguro is offline
maguro's Avatar
Joined Apr 2007
I am considering using a page from Burt Rutan's book and creating a sting to measure lift, drag, and moment that can attach to my car or truck. Anyone tried this yet? Have a design that might work?
Roger
Old Aug 25, 2010, 04:28 PM
Dickeroo is offline
Dickeroo's Avatar
Joined Dec 2006
This is a page from Frank White's book: Fluid Mechanics
Here it shows the Kline Fogleman profile from our patent drawing with a flat upper surface, sharp leading edge and a step on the bottom at 50%. Our original intention was only to patent a step, not an entire airfoil configuration. The reason was we knew that it worked right side up or upside down. And, that when the step was on top it produced higher L/D. The reason we put it on the bottom was because we knew that when an aircraft goes from subsonic to supersonic the L/D characteristics reverse themselves. Therefore, we showed it on the bottom in the patent drawings. We learned this from smoke tunnel testing done at Notre Dame by Dr. John Nicholaides back in 1971. It was part of the segment shown on CBS 60 Minutes with Morley Safer in 1973.
Interestingly enough, the KF on the bottom showed that it resisted stalling out beyond 50 AOA. The experts didn't seem to care or even wonder how this was possible. Go figure.
Old Aug 25, 2010, 04:51 PM
maguro is offline
maguro's Avatar
Joined Apr 2007
Dick,
Notice something else. Every other curve has pretty much the same slope. This is typical of most airfoil lift curves. They only change around the stall. The KF airfoil has a parabolic shape not a straight line till stall. Very interesting.
I want to plot some lift curves for KFM1 through KFM4 airfoils at a few typical model airspeeds. That data would really be interesting to see.
Roger
Old Aug 25, 2010, 05:26 PM
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
Roger
I remember photos of Burt Rutan putting airplanes on his vehicle and racing across the California desert to do testing. So I think this is a great idea! Good enough for trend and record setting, full scale airplane design testing, good enough fo us!
which book do you have, and who is the publisher?
Fred
Old Aug 25, 2010, 09:28 PM
23t23dS is offline
Find More Posts by 23t23dS
Singapore
Joined Oct 2008
If you are an Aeronautical Engineering student looking for a good project, let me recommend this one.
[/LEFT]
[/CENTER]
I am an AE student and I this is one of the projects I intend to tackle.
I am hoping to get access to the school's wind tunnel to run a few KF wing segments in.
At the same time, building a large RC aircraft with an interchangable wing set-up would also have to be done to for "real world" data, perhaps with an Eagletree on board.
23t23dS is offline Find More Posts by 23t23dS
Discussion ** Kline-Fogleman (KFm) Airfoils - Building/Flying Discussion ** jackerbes Foamies (Scratchbuilt) 8046 Feb 09, 2016 03:46 AM
Cool Here is my KFm-5 DLG GLider (Kline-Fogleman) dougmontgomery Foamies (Scratchbuilt) 151 Apr 21, 2014 10:08 AM
Discussion ** Kline-Fogleman Airfoiled Flying Wing ** Tony65x55 Foamies (Scratchbuilt) 3945 Apr 08, 2014 11:40 AM
Video Kline Fogleman Airfoil on a flying wing Tony65x55 Electric Plane Talk 3 Jan 30, 2009 08:37 PM
Idea Per Dick Kline, Kline-Fogleman test dougmontgomery Hand Launch 49 Apr 13, 2007 03:13 AM
