Old Jun 29, 2003, 06:02 PM
Cubby Boy is offline
Find More Posts by Cubby Boy
Lift is Good!
Cubby Boy's Avatar
Goshen, Indiana, United States
Joined Nov 2002
What rate to charge lipoly cells?
Looks like I am going to get a pack of 1200 3s3p lipoly cells (3600 mAh)
What is the recommended charging rate for this pack? I can go up to 2.5 amps on my triton.
How about discharge rates?
I suppose I set my discharge and charge voltage to 11.1.
Right?
Thanks!
Cubby Boy is offline Find More Posts by Cubby Boy
Old Jun 29, 2003, 06:13 PM
Pjotrrr is offline
Find More Posts by Pjotrrr
Me likes Depron...
Pjotrrr's Avatar
Amsterdam Schiphol, Netherlands
Joined Mar 2003
Hi again,
You don't need to discharge the Lipo's because they don't have any "memoryeffect"
Charging is always no more then 1 C , thus 1200 mA for the E-Tec 1200's
Peter
Pjotrrr is offline Find More Posts by Pjotrrr
Haldor is offline
Find More Posts by Haldor
EDF Head
Haldor's Avatar
Stavanger, Norway
Joined Feb 2000
Termination voltage is 4,2V/cell.
LiPo's will take 1C charge just fine (3,6Ah in this case so 2,5Ah is no consern)
Discharge, they state 90% capacity at 5C (=16A)
I'm flying a model with 2s3p E-Tec1200's, static amps around 15, flighttimes 35-40minutes.
Haldor is offline Find More Posts by Haldor
Old Jun 29, 2003, 06:16 PM
Pjotrrr is offline
Me likes Depron...
Pjotrrr's Avatar
Joined Mar 2003
The packs are 12,5 V when fully charged but I don't need to set the voltage on my Orbit charger, do you use the Lithium Ion program on your Triton?
Old Jun 29, 2003, 06:42 PM
FlightofSong is offline
Find More Posts by FlightofSong
Why yes, I DO work for GP
Danville Vermilion, Illinois, United States
Joined Oct 2002
For the triton, use the nominal voltage for the setup, so yes, 11.1V (3.7*3) is correct.
I don't have any experience in the matter of parallel charging, but I've read that to be totally safe against cell imbalance, you should charge at 1C for the individual cells , rather than for the pack. in this case, 1.2A. This is a raging debate, however, and 1C for the pack is probably fine.
FlightofSong is offline Find More Posts by FlightofSong
Old Jun 29, 2003, 06:50 PM
Lift is Good!
Cubby Boy's Avatar
Joined Nov 2002
I got a guy from Illinois and Norway telling me different stuff on the charging rates
Do I charge it at 1C per cell or per pack?
I assume that Haldor is correct since he actually has pack that he has been charging (and that it would be nice to be able to charge it at 2.5 amps)
Old Jun 29, 2003, 06:52 PM
Lift is Good!
Cubby Boy's Avatar
Joined Nov 2002
Oh, how do I treat a new pack?
Slow discharge and then charge at C/10 like a would NiMH?
Old Jun 29, 2003, 06:54 PM
Lift is Good!
Cubby Boy's Avatar
Joined Nov 2002
On the discharge settings I need to chose voltage.
Choices are: 12v, 9v, 6v and 3v.
Which one if for me?
Old Jun 29, 2003, 07:24 PM
davidleitch is offline
Find More Posts by davidleitch
Tragic case
davidleitch's Avatar
Sydney Australia
Joined Feb 2002
Haldor's advice is very sound.
I charge my 3S2P pack (2.4 Ah) at 2.4 amps on a Schulze , no problems to date.
so far, wonderful batteries.
davidleitch is offline Find More Posts by davidleitch
Old Jun 29, 2003, 07:44 PM
Haldor is offline
EDF Head
Haldor's Avatar
Stavanger, Norway
Joined Feb 2000
Yes on both If you charge a single cell you charge it at 1C (=1,2Ah)
As your pack has three cells in parallell the capacity is 3x so 1C is now 3,6Ah.
9V is a fair cut-off voltage for discharging.
Old Jun 29, 2003, 07:48 PM
OzzieFlyer is offline
Find More Posts by OzzieFlyer
Melbourne Australia
Joined May 2003
Oh..so 1C per Cell then. So I could charge my 2s pack at 2.4V...I was wondering why it was taking so long to charge at 1.2amps.
OzzieFlyer is offline Find More Posts by OzzieFlyer
Old Jun 30, 2003, 11:01 AM
Haldor is offline
EDF Head
Haldor's Avatar
Stavanger, Norway
Joined Feb 2000
Ozzieflyer, you're confused
Assume Etec1200's:
If you have 2cells in 2s1p config 1C = 1.2Ah
If you have 4cells in 4s1p config 1C = 1.2Ah
If you have 4cells in 2s2p config 1C = 2.4Ah
The amount if cells in series does not matter in this regard, only the amount of cells in parallell.
If you have 2s1p and charge at 1.2Ah (1C) total charge time will be around 1h45mins because the current ramp down when the pack reach full. Thats the way LiPo needs to be charged.
Old Jun 30, 2003, 11:09 AM
Lift is Good!
Cubby Boy's Avatar
Joined Nov 2002
Thanks Haldor
Now, how do I treat a new lipoly pack? The same that I would a new NiMH or Nicad pack?
Sloooow charge?
Old Jun 30, 2003, 11:51 AM
WJ Birmingham is offline
Find More Posts by WJ Birmingham
WJ Birmingham's Avatar
St. Louis Metro
Joined Apr 2003
Charge it at .8a (1200 mAh pack) for the first 1/2 hour, then hit it with 1.2a from then on out.
*edit*
You might find this page informative: http://www.aircraft-world.com/prod_d...ets/lipoly.htm
WJ Birmingham is offline Find More Posts by WJ Birmingham
Old Jun 30, 2003, 01:56 PM
Dave Hederich is offline
Find More Posts by Dave Hederich
Walled Lake, MI, USA
Joined Feb 2000
New lithium cells need no special treatment different from used lithium cells. Simply use the same charger settings whether the cells are new or used.
Dave Hederich is offline Find More Posts by Dave Hederich
what rate to charge 3s 2100mah TP 11.1v packs ? McDanger Batteries and Chargers 4 Nov 16, 2005 07:12 PM
LiPo's - what rate to charge at? John Webb Batteries and Chargers 6 Jul 04, 2003 06:40 PM
What is safe charge rate for 2000 Nimh Panasonics ? Al P Electric Plane Talk 5 Jul 18, 2001 01:22 AM
what is max rate to charge NiMH? atsiang Electric Plane Talk 4 May 25, 2001 07:36 PM
For 9.6V 1600ma NIMH battary what is the charge rate and charge time? clchen Electric Plane Talk 7 May 06, 2001 10:06 PM
