Old Aug 22, 2010, 04:10 PM
Mr Bloppy is offline
Find More Posts by Mr Bloppy
SURREY!!! UK
Joined Apr 2010
3dhs edge 41" edge as second ish) plane?
so I'm getting a bit ahead if my self here but I can't help thinking about it... I have a hz super cub with e flite 480 and am going to cut alierons and flatten, clipped wing ect. at this point my brother will get the e flite mini pulse and I will have flown it a lot?
would it be possible for me to go for the edge?
thanks in advance..
Mr Bloppy is offline Find More Posts by Mr Bloppy
Old Aug 22, 2010, 06:38 PM
Doc Austin is online now
Find More Posts by Doc Austin
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
thanks in advance..
I think a better bet would be the 47" SHP. I moved from a Mini Pulse to an SHP and actually found it easier to fly, yet more capable.
Also, the 40" or 41" Edges with a sport set up would be really sweet too, just not quite as easy as the SHP.
http://docaustinsfreakshow.blogspot....nd-set-up.html
Doc Austin is online now Find More Posts by Doc Austin
Old Aug 22, 2010, 06:39 PM
Bama3Dr is offline
Find More Posts by Bama3Dr
Bama3Dr's Avatar
Moody, AL
Joined Jan 2006
If you're really comfortable with flying the cub I'd say go for it. Just make sure to set up your control throws REALLY low and give it a slightly nose heavy CG setting to make it a little more stable to start. If you can find Doc Austin's Blog he has an article about how to set up the Extra 300SHP for sport flying and that's the way you would want to set up this Edge to start with. I'll try to find you a link to his blog.
The Edge will be much different from the Cub that you're used to in that it will not have a tendency to "self right" itself. It will go where you point it. Just start out slow with it and I think you'll be fine.
-Dustin
Bama3Dr is offline Find More Posts by Bama3Dr
Old Aug 22, 2010, 06:40 PM
Bama3Dr is offline
Bama3Dr's Avatar
Moody, AL
Joined Jan 2006
I typed too slow and Doc beat me to it.
-Dustin
Old Aug 22, 2010, 11:55 PM
vienquach is offline
Find More Posts by vienquach
vienquach's Avatar
Chicago, IL
Joined Nov 2009
I'd take the Airfoilz Extra/Yak Full Fuse as the 2nd/transition plane. Quite inexpensive and very easy to fly ($100 Rx ready).
I agree that the SHP is easier to learn than the 40"/41" Edge. Larger size (wingspan, length) makes it more stable to gust and control input. But the Rx ready is about 3 times the Airfoilz.
Here is my learning curve:
1) 60" trainer, 4 flights in 2 weeks ==> crashed ==> repaired ==> retired (too boring)
2) Yak 55 Flight Flex, 50 flights in 4 weeks ==> 3 x repairs ==> retired (too small & flex)
3) Airfoilz Extra Full Fuse 260 ==> 140 - 150 flights in 7 weeks ==> 0 repair & still flying (hover, rolling harrier, etc) ==> will retire soon (a bit small)
4) TOC Yak 54 30%, DLE55 & HS7955 finished but has not maiden ==> might convert to electric.
5) Saving for the 3DH Extra SC 57" or EF Extra 300 58" ==> just the right size (visibility & wow factor)
vienquach is offline Find More Posts by vienquach
Old Aug 23, 2010, 01:11 AM
qman is offline
Find More Posts by qman
qman's Avatar
Wanaka, NZ
Joined Mar 2009
the edge 41" will be great for you, I was flying a PZ corsair and went to the 40" edge and found it easier to fly and land than the corsair.
they are just so much more predictable and do exactly what you tell them. and you have heaps of power to get out of trouble. and never noised over on landing and takes off in about 1m.
seriously, they are really easy to fly, just keep the rates low untill you get use to it.
If you can take off and fly and land any aileron plane you will be absolutely sweet with the 41" edge.
qman is offline Find More Posts by qman
Old Aug 23, 2010, 01:20 AM
qman is offline
qman's Avatar
Wanaka, NZ
Joined Mar 2009
dont be scared, if you are confident and moderately capable you will love the edge.
Old Aug 23, 2010, 02:28 AM
RC_Feen is offline
Find More Posts by RC_Feen
RC_Feen's Avatar
Culpeper, VA
Joined Oct 2005
In the same boat!
I'm in the same boat as far as currently flying a PZ Corsair and looking for my second-ish plane. I was planning on getting a PZ Extra 300 but now reconsiderring sence all the reports of issues with the wing. Not knowing what to expect, would the 47" SHP be a better alternative to the PZ Extra 300? Thanks!
RC_Feen is offline Find More Posts by RC_Feen
Old Aug 23, 2010, 07:48 AM
SURREY!!! UK
Joined Apr 2010
thanks for the response guys.
I'm trying to decide between the shp and edge... the shp will cost about 130 more than the edge (electronics, motor esc) so am trying to work out if its worth the extra 130?
thanks
Old Aug 23, 2010, 08:18 AM
sgomes is offline
Find More Posts by sgomes
Alameda, CA
Joined Dec 2006
Well, if you're interested in the opinion of a beginner - I have found the Edge to be the most compliant plane I have yet flown. I think this is owing to the fact that I have been learning on some pretty inexpensive models which simply have not been nearly as well designed and put together as the Edge.
I won't argue with the experts who precede me here and recommend the SHP, but if one follows the build process as outlined, balances the plane from the spar tube with a slightly nose down attitude as recommended, and begins with very low rates and lots of expo, it is difficult for me to imagine a plane any easier to fly than the 41" Edge.
Hope this helps, and good luck with your decision - I'm sure you will be happy with either.
Steve
sgomes is offline Find More Posts by sgomes
Old Aug 23, 2010, 08:34 AM
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
thanks
I certainly don't want to talk you out of the Edge because it's my best airplane, and I know you'de love it. I do think, however, with the SHP being bigger, it will fly smoother and more solidly, and the wind will effect it less. Bigger planes genewrally fly better.
Between the two, it is impossible to make a bad choice. I just think the SHP would be a better choice.
As far as the money, Andrew Jesky's rule is buy the biggest plane you can afford to crash.
Old Aug 23, 2010, 10:53 AM
stickybeatz is offline
Find More Posts by stickybeatz
stickybeatz's Avatar
USA, AZ, Phoenix
Joined Apr 2010
The 41" Edge is way easier to fly than the PZ 300. I don't know about the SHP yet tho... hopefully I can tell you after this weekend
stickybeatz is offline Find More Posts by stickybeatz
Old Aug 23, 2010, 11:12 AM
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
I trimmed one out for a guy this weekend and it was an ok plane, but it doesn't compare to the Edge at all. Not even close.
He's going to be one of the guys who will fly my SHP in the new Extra SHP sport report. We're going to let everyone who can solo fly that plane, and I might even put a newbie on a buddy cord with it.
I don't know about the SHP yet tho... hopefully I can tell you after this weekend.
I wish you luck, but you won't need it. You're goijng to be shocked at how sweet and easy that plane is.
Old Aug 23, 2010, 11:40 AM
USA, AZ, Phoenix
Joined Apr 2010
I'm really excited about it. I keep checking my email every 5 minutes looking for the "Your order has shipped" email.
Old Aug 23, 2010, 12:01 PM
TG43 is offline
Find More Posts by TG43
TG43's Avatar
Glens Falls, NY
Joined Apr 2010
I have a 41" Edge and 47" SHP. They are both a blast to fly. I prefer the SHP if it's windy (as Doc mentioned).
The Corsair is a great stepping stone to a 3DHS Extra or SHP in my opinion. That's basically the route my friend and I took (he got a corsair, I got a P-51, I struggled with the P-51 at first).
Here's another cool SHP vid http://www.rcgroups.com/forums/showpost.php?p=8569482
TG43 is offline Find More Posts by TG43
Sold 3DHS 41" EDGE - ORANGE - 99 Buck Huck 6L6Amp Aircraft - Electric - Airplanes (FS/W) 14 Aug 22, 2010 07:45 PM
Wanted 3DHS Edge 540 41" oilfield1 Aircraft - Electric - Airplanes (FS/W) 0 Aug 15, 2010 01:58 AM
