Old Mar 15, 2013, 11:46 AM
AIR SALLY is offline
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
try nitroplanes site they have spare parts for it there.or at least they did.
AIR SALLY is offline Find More Posts by AIR SALLY
Old Mar 15, 2013, 02:03 PM
Nukiwi is offline
Find More Posts by Nukiwi
Now, what does this button do?
Nukiwi's Avatar
Christchurch. NZ
Joined Dec 2009
Thanks, looked there, but no.
Any other ideas?
Nukiwi is offline Find More Posts by Nukiwi
Old Mar 15, 2013, 08:13 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
i was going to make a fiber glass mold to make them out of fiber glass..but mine is cracked so i need a new one to make the mold with.
Old Mar 15, 2013, 10:19 PM
jpflyer is offline
Find More Posts by jpflyer
USA, TX, Corpus Christi
Joined Oct 2001
Nose ring
Originally Posted by Nukiwi View Post
I note a few guys have mentioned a plastic nose ring for this model.
Mine does not! Am I missing something, or is one available?
(& if so, please point me in the right direction!)
TIA.
Oh, I am also missing the instructions, so if anyone can post them, I would be much obliged.
The red version did not have the plastic ring, only the silver version. I could use one as the nose of mine has a ding or two. I also have the instructions. They are on a poster size single side single sheet that measures about 24 inches by 12 inches, and I have no way to scan that into something I can post, sorry.
jpflyer is offline Find More Posts by jpflyer
Old Mar 16, 2013, 08:32 PM
Nukiwi is offline
Nukiwi's Avatar
Christchurch. NZ
Joined Dec 2009
Thanks for the info. (Still not found a store with it listed in the spares)
However, a kind soul has just sent me a scan of the instruction sheet.
Any pointers to a "nose ring" gratefully received.
Old Apr 02, 2013, 09:03 PM
Nukiwi is offline
Nukiwi's Avatar
Christchurch. NZ
Joined Dec 2009
Got a "nose ring" via the importer. (Thanks guys)
Started to assemble & went with twin servos for the elevator + a carbon rod up the fin for a bit more strength.
Old Apr 02, 2013, 09:44 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
good idea on the C/F rod ....mine when it got close to 100 mph would roll uncrotroled ...so you had to fight it and back off the power ..we assumed it was the tail twisting .,we had rudder and the servo cutout could have weak'n it a bit
Old Apr 02, 2013, 10:01 PM
FireHawx is offline
Find More Posts by FireHawx
FireHawx
FireHawx's Avatar
United States, NV, Reno
Joined Oct 2011
That is exactly how I lost mine!! At the bottom of a dive it just rolled over and went strait in. Many times in high speed passes/turns, it would want to turn out or roll??
FireHawx is offline Find More Posts by FireHawx
Old Apr 02, 2013, 11:23 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
yeah we saw it the first flight when Corsair nut was ringing it out ......i never went there again ,still have mine but it looks like a real mig ruff. it flies well and with the same power as my Venom F-86 it would fly circles around it .a bit harder to land though .you have to touch down just right or it starts bouncing ,and the nose gear would snag our matt runway and tear the gear out .
Old Apr 03, 2013, 10:04 AM
N827TM is offline
Find More Posts by N827TM
Mansell Models
N827TM's Avatar
United States, UT, Layton
Joined May 2004
I wish I could get more speed out of my mig. I think it is slow. I am running 5s and a cyclone power 2800kv motor on a het 6904 fan. The speed of my mig is neck to neck with the venom f-86 flying on stock power.
Tom
N827TM is offline Find More Posts by N827TM
Old Apr 03, 2013, 10:44 AM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
did you mod the inlet like i did ? there are pics in here some where
Old Apr 03, 2013, 06:12 PM
RugFlyer is offline
Find More Posts by RugFlyer
"LiPo-Blaster"
RugFlyer's Avatar
Duluth, GA
Joined Apr 2009
Actually mixing in spoilerons and elevator took all the bounce out of my buddies Mig on landings, he greases them every time.
It's Very Fast! I have a video I'll upload shortly.
Setup:
HK Alloy DPS 70mm 10-Blade EDF
6S / 3300 to 4000 mAh Lipos.
-Rick
RugFlyer is offline Find More Posts by RugFlyer
Old Apr 03, 2013, 11:44 PM
N827TM is offline
Mansell Models
N827TM's Avatar
Joined May 2004
AS,
I think the intake is my problem. I did not do the mod. I might tear into it and complete the mod. I did do the elevator mod though. I have a 9g servo on each elevator. I also added a scale rudder too. Overall it is a sweet jet. I just wish it had more speed and vertical.
Tom
Old Apr 04, 2013, 08:11 PM
FireHawx is offline
FireHawx
FireHawx's Avatar
Joined Oct 2011
I only ran 4S 2W18 and an Eflite rotor with great speed/vertical!! You can run the Cyclone 3300 on 5S and that will have some GO! I run that in my Habu2.
Old Apr 27, 2013, 07:55 PM
RugFlyer is offline
"LiPo-Blaster"
RugFlyer's Avatar
Duluth, GA
Joined Apr 2009
Well, after being partially assembled then set aside for a year & a half my Mig-15 is ready for maiden.
Thanks to all who have contributed to this Mig15 Thread so I could get this bird properly airworthy!
Mods:
*Split flaps
*Split/Dual rudder
*CS10 fan / Mounted in E-Flight Delta V-15 housing w/BL-32, 2150kv 6S Motor
*Lowered Battery Tray accommodates 6S/3300-4000mAh Lipos
*Lowered & Strengthened Front & Main retract mounts
*Digital Servos
*Extended Intake splitter(AirSally)
*ESC mounted bottom of fuse
*Carbon Fiber Spars in Main wing, Horizontal & Vertical stab for reinforcement
*Elevator guide tube reinforcement on vertical stab
*Main exposed wing spar in air stream placed in aluminum aerodynamic foil
*60mm exhaust efflux tube (w/slight DownThrust) out of poster board for better Woosh sound than Mylar
*Sapac Viper-Jet Thin profile aluminum ball bearing wheels/tires
*Detailed cockpit w/hatch lock
I'll have the maiden as soon as this rainy weather subsides.
-Rick
Discussion Hobby Lobby EPO Mig 15! Jason Cole Foamy EDFs 509 Apr 24, 2015 09:53 AM
Video Hobby Lobby Mig-15 EPO Jet Jason Cole Electric Plane Talk 46 Jan 30, 2012 04:51 PM
Discussion First edf - hobby lobby mig 15 epo? rjp0325 Electric Ducted Fan Jet Talk 4 Sep 02, 2010 01:45 PM
Discussion First edf jet - hobby lobby mig 15 epo? rjp0325 Electric Ducted Fan Jet Talk 0 Aug 15, 2010 07:40 PM
Discussion airframe/ foam only kit for a 55-70mm fan MIG 15 or F-86 Sabre? STANG KILLA SS Foamy EDFs 0 Jan 31, 2009 10:23 PM
