Old Sep 18, 2010, 03:31 PM
Nitrouss is offline
Find More Posts by Nitrouss
Valdres, Norway
Joined May 2009
Originally Posted by wingspan100 View Post
Can you check how it is sparred?
What are they using for spars and how long are they?
I've seen wing fold up on large foamies before.
There's an alloy square from the root going almost all the way out to the tip. An 80 cm alloy tube joins the wing halves (see pics.) In addition u have the wing supports to the fuse. So i think the wing can take some G's. It's not a 3D machine anyway
The battery hatch is located behind the nose wheel. See pics in post #19
Got stuck with a minor problem when i was going to install the motor. The pre drilled holes in the motor wall didn't match the motor bracket. The holes were overlapping a bit. So i made 2 pieces of ply. One in front of the wall and one on the back. That way i got some fresh holes on both sides. The extra piece of ply in front also gave me the perfect gap between cowling and spinner.
Also got one of the wing halves finished. Control horn and servo horn didn't line up very well. Just bent the push rod, they are quite stiff, so i think it will be ok.
Nitrouss is offline Find More Posts by Nitrouss
Old Sep 18, 2010, 08:29 PM
wingspan100 is online now
Find More Posts by wingspan100
Lookout For The!Radio Silence.
wingspan100's Avatar
United States, AZ, Scottsdale
Joined Nov 2007
It's coming along nicely, Looking more like an airplane now.
wingspan100 is online now Find More Posts by wingspan100
Old Sep 18, 2010, 11:26 PM
I_Gotts_Ta_Fly is offline
Find More Posts by I_Gotts_Ta_Fly
GorillaGlue, Tape...I'm good
SillyCornValley, CA, USA
Joined Jun 2007
Would you have been able to simply flip the "E/Z connector," on the servo arm, to the other side? Will it hit the servo case?
Otherwise, it's looking good. I can't wait to see it in the air.
I_Gotts_Ta_Fly is offline Find More Posts by I_Gotts_Ta_Fly
Old Sep 19, 2010, 04:24 AM
Nitrouss is offline
Valdres, Norway
Joined May 2009
I was thinking about flipping the connector too, but i didn't find out before the servos were glued. Don't think the connector will hit the case.. Depends on the throws... Also used threadlock on the connectors, so it'll be tricky to fix with the servo glued...
Old Sep 19, 2010, 04:46 AM
Nitrouss is offline
Valdres, Norway
Joined May 2009
Found a video of the plane on youtube, for those who haven't seen it before.... :
Tian Sheng Giant EPO Cessna 182 Skylane with flaps 1.8m wingspan (4 min 13 sec)
Old Sep 19, 2010, 08:48 AM
Joined Nov 2007
That looks like a great flying airplane.
When it slows down, it looks more scale.
Old Sep 22, 2010, 06:57 PM
Curt S is offline
Find More Posts by Curt S
Insert witty comment here...
Curt S's Avatar
United States, PA, Dunmore
Joined Jun 2008
I'm surprised there isn't more of a buzz on this plane. It's seems like a great plane for slo flying and being a trainer. This is gonna be my girls secong plane. She like how my 27 percent extra looks in the air but like slow flying like her current trainer foamy.
Curt S is offline Find More Posts by Curt S
Old Sep 22, 2010, 10:28 PM
pldawg is offline
Find More Posts by pldawg
Spokane, WA
Joined Aug 2009
http://www.youtube.com/watch?v=rQkEeI39dsM
that video is funny, definitely sound dubbed over it but it looks like a fun plane to fly.
pldawg is offline Find More Posts by pldawg
Old Sep 23, 2010, 01:03 AM
Joined Nov 2007
If the sound was dubbed, I wonder if the speed was slowed down to make it look like a floater?
Old Sep 23, 2010, 02:39 AM
Nitrouss is offline
Valdres, Norway
Joined May 2009
1,9m span + 2,5kg = it has to be a floater
The plane is almost ready for maiden. Have a few more decals to put on... I'm at work now, but will post pics tonight. The building of this plane has been very much straight forward... With a few exceptions. Some minor issues, and one f...ing pain in the ass issue. Mounting the wing to the fuse is everything but easy. (not sure how to explain in english, but i'll try ) 4 bolts are used to attach the wing to the fuselage. These bolts have to enter the nuts which are hammered into a piece of ply. This ply is glued to the sealing inside the cockpit. If u push too hard when trying to get the bolt to enter the nut, the nut will fall out of the ply and down on the cockpit floor. Then u have to cut open the cockpit roof to get to the nut. I'll post some pics tonight, and u'll see what i mean...
Old Sep 23, 2010, 05:59 AM
kydawg1 is online now
Find More Posts by kydawg1
"Aircraftus Fragmentum"
kydawg1's Avatar
United States, MI, Detroit
Joined Mar 2007
I agree - she is NICE. Time to order..............
kydawg1 is online now Find More Posts by kydawg1
Old Sep 23, 2010, 08:15 AM
ZackJones is offline
Find More Posts by ZackJones
It's just a plane.
ZackJones's Avatar
USA, SC, Goose Creek
Joined Aug 2010
If you can get access to the blind nuts expoy them to the piece of ply. That should take care of the problem. Can't wait to see more pictures of your build.
ZackJones is offline Find More Posts by ZackJones
Old Sep 23, 2010, 08:47 AM
Nitrouss is offline
Valdres, Norway
Joined May 2009
I had to glue one of the nuts. Seems to work out fine for now. But if this problem goes on, i'm planning to replace the bolts and nuts with bigger ones. Will be easier to enter the nuts and it will be stronger. I don't want to struggle with this problem out on the field every time.
Old Sep 26, 2010, 03:42 PM
Joined Jun 2007
New (second) Source
Before anyone decides to order from Norway, check this place out and compare. It sounds like it comes with floats and landing gears. I believe it's the same plane and the color I prefer.
http://www.pw-rc.com/product_info.ph...8gtma982d2obk1
Old Sep 27, 2010, 12:08 AM
Joined Nov 2007
Good looking plane, this one is in Hong Kong.
Question Cessna 182 (980 mm, EPO) Art-Tech karosi Beginner Training Area (Aircraft-Electric) 3 Apr 27, 2010 02:38 PM
Discussion Bae Hawk Red Arrow,Flying Illusion by Tian Sheng 990mm hypstar Foamy EDFs 1 Feb 14, 2010 08:49 PM
Discussion 5ch EPO Cessna 182 with flaps RxR, incredible price BaracW Hot Online Deals 8 Feb 23, 2009 10:29 PM
Discussion Hobbycity's New Cessna 182 RTF 5Ch with Lighting & Flaps EPO anthodenn Parkflyers 1 Oct 22, 2008 02:09 PM
