Old Sep 25, 2010, 10:12 AM
scrubs is offline
Find More Posts by scrubs
scrubs's Avatar
Rio Rancho NM
Joined Dec 2004
Thanks for the comments guys.
UNGN,
Ah but sometimes those few extra bucks add up for an old retired guy like myself.
Paul,
Thanks for the info. Aside from plans up the wazoo I've got a goodly number of old kits laying around that would work. Just happen to have a PZ P51 motor from a FF project and a brick too.
bill
scrubs is offline Find More Posts by scrubs
Old Sep 25, 2010, 11:01 AM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
UNGN,
bill
A $17 5g 2S Brushless setup (motor+ESC+shipping) will outlast $60 worth of Mustang motors and deliver 2X the thrust for about 8g more weight, total (including the 2S battery).
With Mustang motor being what they currently are, I'm hesitant to recommend someone put them into a scratch built plane... at least until the quality gets better.
UNGN is offline Find More Posts by UNGN
Old Sep 25, 2010, 11:42 AM
scrubs is offline
scrubs's Avatar
Rio Rancho NM
Joined Dec 2004
I agree about the motor I've had one crap out already. But then again a 2 cell 10 gm $15 brushless I bought was DOA also. That was my first forray into brushless & made me hesitant.
bill
Old Sep 25, 2010, 10:29 PM
ckreef is offline
Find More Posts by ckreef
ckreef's Avatar
Danville, GA
Joined Aug 2010
I'm into this idea. Please give us a link and I'll order a setup (or 2) on Monday.
ckreef is offline Find More Posts by ckreef
Old Sep 25, 2010, 11:32 PM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
6A ESC
5g Outrunner
Plugs to make 2S Serial battery connectors and plug into brick.
Wire it like this:
Old Sep 26, 2010, 11:03 AM
ckreef is offline
ckreef's Avatar
Danville, GA
Joined Aug 2010
Thank You for the links and the nice diagram/picture. Going to order a setup later today. A couple of quick questions.
Does it matter if I use a 1N4001 or 1N4003 or 1N4005 ???
Any prop recommendations for this setup?? I was thinking either a GWS 4530 or GWS 5030
Old Sep 26, 2010, 11:12 AM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Any of those diodes will work. Both those props and the 5043, too will work fine. It depends on how much thrust or run time you want.
With a 60-70g plane, the motor is going to be at 1/3 throttle a lot.
Old Sep 26, 2010, 11:17 AM
scrubs is offline
scrubs's Avatar
Rio Rancho NM
Joined Dec 2004
I guess my question turned into hijacking Paul's thread. You might want to beef up the Comet construction if you go with a setup like this. 90 gms of thrust would certainly test those wing spars, LE & TE.
bill
Old Sep 26, 2010, 11:30 AM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
bill
Just because you have the power, doesn't mean you have to use it This is a good setup for 20-25" WS planes, not the 16" ones.
I found the 5g motor is a lot smoother than a Mustang motor gearbox and vibrates a lot less under power. Since the mounting flange of the gearbox is to resist motor toque, prop vibrations can cause it to rock back and forth, so the mount has to be strong in a few different directions.
The outrunner has motor torque and prop vibration along the same centerline so the mount can be a firewall on a bulkhead.
If it ends up with too much power, you can always limit the throttle % in the radio.
The way this plane is constructed, he could make a 5g power module that swaps right in place of the Mustang unit.
Old Sep 26, 2010, 10:21 PM
PaulBrad is offline
Find More Posts by PaulBrad
PaulBrad's Avatar
Independence, KY and Brandon, MS
Joined Jun 2000
Great discussion on the use of the 5g brushless motor in an airframe like the Stinson. I certainly agree that going brushless is the best long term solution. When I selected the P-51 power package I was looking to keep the single cell built in ESC set up of the radio brick. I was also interested in knowing if the P-51 motor/gear drive would handle the model adequately. I have been able to answer that question.
The comment about being able to easily swap out the brushed motor with a brushless is spot on. The slide out tray makes the motor change and going to a two cell battery pack pretty easy. I probably will not do that with this model as it has all the power it needs to be a happy flier. If the motors don't last then I may revise that decision.
Regarding the airframe strength, the Stinson is actually very robust in terms of handling aerodynamic flight loads. It could handle the thrust of the 5g brushless motor with no problem. The strut braced wings can take a lot of flight load. Flying the model in a scale fashion would certainly leave much of the available power in the can so to speak. Some of the stick and tissue war birds would be great applications for the motor. You would have the power to fly the aerobatics the full scale aircraft could handle.
Thanks again UNGN for your insight and the information on setting up the brushless motor with the AR6400 receiver brick.
Paul Bradley
PaulBrad is offline Find More Posts by PaulBrad
Old Sep 26, 2010, 10:48 PM
ckreef is offline
ckreef's Avatar
Danville, GA
Joined Aug 2010
I too really do appreciate that information as I now finally understand this setup. Something my noobie brain was lacking before now.
When reading through the reviews for that ESC someone posted that "yes it can run with 1S lipo!!!" . Would make a great test to try it out with a large Hyperion 1S lipo.
Old Sep 29, 2010, 12:29 AM
PaulBrad is offline
PaulBrad's Avatar
Joined Jun 2000
The wind spirits cooperated with me today and provided a nice dead calm evening. As a result I was able to get in two nice flights with the Stinson. The new motor is not showing any signs of stress so I guess the failure of the original motor was just one of those early mortality issues.
My wife was with me to run the video camera but she has limited experience following small model airplanes with the camera. She did her best but we did not get any useable footage. Hopefully I will get some presentable video sometime in the not to distant future.
I still have some trim tweaking to do with the model. The left wing panel has developed a very slight washout warp. That is causing the model to crab just a bit to the left. It is easily managed with a small amount of rudder input but does need to be addressed. Overall she is a very happy flier. In the dead calm wind conditions cruise was maintained at 1/3 throttle.
Paul Bradley
Old Sep 29, 2010, 01:13 AM
Prime_8 is offline
Find More Posts by Prime_8
Lawn dart pilot/builder
Prime_8's Avatar
N.L. Canada
Joined Jun 2010
great news.
too bad about footage .
Prime_8 is offline Find More Posts by Prime_8
Old Oct 02, 2010, 12:33 AM
PaulBrad is offline
PaulBrad's Avatar
Joined Jun 2000
The forces of nature are keeping me grounded as far as the Stinson goes. It has been very windy and the forecasters say that will continue for several more days. I hit the road Monday for nearly two weeks of traveling. There will hopefully be a few windows for flying during this two week period. If not then I should be able to get some video at KIEF in two weeks.
While watching the trees moving like a hurricane was passing through I decided to bite the bullet and get the dummy engine made up and installed on the model. I have received several very good suggestions in this thread for handling the restrictive geometry I gave myself with the disk that retains the slide out equipment tray. I finally decided to use the decal suggestion. My only deviation was the addition of a 3D simulated front crankcase. I found a really good head on photo on the Internet of the Lycoming 9 cylinder radial engine used in the SR-7. That photo got the background trimmed out and was then re-sized to the proper diameter. The rocker covers don't show as they are tucked away under the cowl. While not as good as something more three dimensional, it is an upgrade from the previous flat black disk. The photo was printed on white ink jet water slide decal paper. The simple geometry of the front disk made trimming the decal pretty easy.
Paul Bradley
Old Oct 02, 2010, 04:52 AM
Prime_8 is offline
Prime_8's Avatar
N.L. Canada
Joined Jun 2010
very cool man .
Discussion Comet 25" Stinson Reliant SR-7 PaulBrad Free Flight 36 Jun 14, 2010 11:02 AM
Build Log Stinson Reliant 18" Span 1/28 Scale Rubber Conversion ( ready for another trial) GJ60 Scale Kit/Scratch Built 127 Oct 30, 2009 06:42 PM
Yippee! Stinson Reliant SR-7 from Comet plans igo Foamies (Scratchbuilt) 10 Sep 20, 2007 10:02 PM
My Stinson Reliant SR-7 building Rembold Scale Kit/Scratch Built 24 Jan 08, 2006 01:48 PM
Another Estes Free Flight Conversion Question Cautrell05 Foamies (Kits) 4 Oct 20, 2004 03:17 AM
