Espritmodel.com Heli Air
Old Oct 28, 2010, 11:15 AM
KK4OCZ
webdr's Avatar
United States, GA, Sandy Springs
Joined Jul 2009
Originally Posted by merlin703 View Post
Cool, how many runs have you had with the lipo? Have you been able to monitor temperature when put under stress?
I too have used a 2s lipo for testing. theres really no stress thats put on it as the 380 brushed motor just doesnt draw much power. Id say it gets warm and thats it.
Just make sure you dont drain your lipo down below 3.2 v per cell. theres no lipo cutoff on this esc.
matt
webdr is offline Find More Posts by webdr
Old Oct 28, 2010, 02:10 PM
North Central TN USA
Joined May 2006
Just received mine and am wondering if there is supposed to be a set screw in the prop hub. I have an empty threaded hole.
420TEE is offline Find More Posts by 420TEE
Old Oct 28, 2010, 02:29 PM
KK4OCZ
webdr's Avatar
Joined Jul 2009
check the other side. there are two grub screw holes in the prop hub, only one side has a grub screw.
Old Oct 28, 2010, 02:53 PM
Beaver Dam.Wi.
Joined Jan 2003
merlin703
I had 3 runs with the boat. I do not expect many more as the weather
is quickly getting cooler in Wisconsin. No I have not monitered stress temperature.I did do a break in of the brushed moter before running
I suspect this extra power may shorten the life of the brushed moter,
So i will likely convert it over to brushless sometime this winter.
harrisdouma is offline Find More Posts by harrisdouma
Old Oct 30, 2010, 09:39 PM
Love anything RC
merlin703's Avatar
Alexandria, Virginia
Joined Mar 2008
Thanks for the info. Let us know which brushless motor works best for you. I will try the lipo option. I guess I will try to match up the weight or the originals and not go over too much.
Originally Posted by harrisdouma View Post
merlin703
merlin703 is offline Find More Posts by merlin703
Old Nov 01, 2010, 09:55 AM
High Dynamic Thrust
stoneenforcer's Avatar
United States, FL, Mt Dora
Joined Feb 2007
hmmm...
maybe a 3200kv with a 4x4.75 on 4s??
stoneenforcer is offline Find More Posts by stoneenforcer
Old Nov 02, 2010, 08:09 AM
Retired for now
Bonita Springs,Fl.
Joined Sep 2007
Nice boat and a great review of it and it's performance. I noticed that the prop is pulling instead of pushing as in most airboats. What's up with that? Pete
norgale is offline Find More Posts by norgale
Old Nov 05, 2010, 10:22 AM
Damp and Dizzy member
Brooks's Avatar
Bozeman, Montana, United States
Joined Aug 2003
It is hard to find pusher props in hobby stores, so often airboat guys mount the engine so it pulls. Apparently, simply mounting a puller prop backwards (curved side to the engine) does not do the trick for pushers, though I don't know why.
For glowplug engines, some carberators work better one way; since most engines are made for airplanes, it's often easier to mount the engine per puller-airplane practice. This would not be a factor for a brushless electric motor, but might be a factor for a brushed motor since brushed engines are timed to optimize one direction of revolution.
Brooks is offline Find More Posts by Brooks
Old Nov 13, 2010, 04:58 PM
Joined Jan 2009
http://pantanalclube.blogspot.com
I did not imagine that I had a Swamp airboat to buy therefore I made mine. I Saw one day the opening of the CSI Miami and was with will to have one… I look to mine blog http://pantanalclube.blogspot.com
paulo santos is offline Find More Posts by paulo santos
Old Jan 10, 2011, 12:03 PM
KK4OCZ
webdr's Avatar
Joined Jul 2009
Fun on the snow w/ the Alligator and a turnegy brushless and 3-cell lipo.
Mini Alligator airboat on the snow (2 min 24 sec)
Old Jan 10, 2011, 04:35 PM
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
Summer AND Winter fun!
Kmot is offline Find More Posts by Kmot
Old Jan 10, 2011, 08:35 PM
Joined May 2006
Webdr- Neat. What model motor did you use? Mine with the stock setup won't move in snow. It should be evil in the water.
Old Nov 10, 2011, 06:42 PM
More Motors, More Fun... :-)
nioa's Avatar
Phoenix, AZ
Aquacraft Mini Alligator Tours Brushless Motor Conversion
Hi, here is another brushless motor conversion for the Aquacraft Mini Alligator Tours Air Boat. Please see my blog for the conversion.
nioa is offline Find More Posts by nioa
Old Nov 11, 2011, 02:49 PM
Richmond VA
Joined Jan 2011
A friend of mine got one of these for his son ,I was driving it when he hit me right in the middle of the cage with the boat he was driving. It broke the cage and sent two pieces flying that wern't even glued in all the way. I should point out that the "one piece cage" is misleading , or rather a straight up lie. The cage is a molded piece on the front connected by dowles (and if lucky glue) to another molded rear cage section....besides all that it worked after the crash and for the price I would buy it,in fact I told him out of guilt I would buy it from him if he wanted to get his son a new one.
wheresmegrog is offline Find More Posts by wheresmegrog
Question AquaCraft Gator Airboat Monstermanhbf Dock Talk 5 Jul 08, 2010 03:02 AM
Wanted AquaCraft Alligator Tours Airboat HyperHelis Boats (FS/W) 1 Nov 12, 2009 09:54 PM
Discussion Aquacraft Scale Airboat hpiguy Scale Boats 24 Jul 02, 2008 07:46 PM
Sold AquaCraft AirForce airboat layback2 Boats (FS/W) 0 Feb 09, 2007 03:52 PM
For Sale aquacraft airboat punkrockd Boats (FS/W) 2 Dec 20, 2006 05:05 PM
