Old Aug 21, 2010, 04:58 AM
Harpye is offline
Find More Posts by Harpye
Build it again, Sam!
Harpye's Avatar
Germany
Build Log
Doughlas A1 H Skyraider 1:12 Video Built Threat
Ok guys, the decision is made!
After my attempt to document my way to build warbirds during my activities of the last ( Mig 3) Workshop, I recognized that I
-first did not have the right software to create HD Movies for youtube
-secondly was too busy to engage in real time support with the participants
-third is that youtube HD was not that far
Now I decided to build another bird form 6mm depron ... BIGGER
and more detailed.
And my target is t to make an over all video documentation as a guideline
for others which would like to follow....
Harpye is offline Find More Posts by Harpye
Old Aug 21, 2010, 05:01 AM
Harpye is offline
Harpye's Avatar
Germany
Specification
shortly to specify my target:
Douglas A1 H Skyraider
Scale 1:12
Wingspan 1,28 m
Weight if structure 700 / 800 Gram
Target is to install retracts if I only could find light 90 types
Old Aug 21, 2010, 05:03 AM
Harpye is offline
Harpye's Avatar
Germany
Proposal
The first step is allways the skin design..
I want to get a proposal before I decide to cut the first parts
It took ma rauound one day to define the coarse curves of the "Lady"...
should be rather a monster....
A1 H Skyraider Surface Model (9 min 15 sec)
Old Aug 21, 2010, 05:07 AM
Harpye is offline
Harpye's Avatar
Germany
Fuse - Inner Structure
Second is that I engage into the fuses inner structure
Necessities for this are:
-a defined accu position
-same for the servos , esc , RX
-third is to get a good structural connection between the wing and the fuse as the motor
A1 H Skyraider Inner Structure (9 min 59 sec)
Old Aug 21, 2010, 05:11 AM
Harpye is offline
Harpye's Avatar
Germany
Assembly of The Inner Structure
As soon as the struture is detailed and printed out I usually can't wait to get the first parts. So I performed a pre assembly test - changed some smaller things and set up the skeleton
A1 H Skyraider Inner Structure (10 min 0 sec)
Sorry about my poor lingual attemps, but as English is not my mother thoung
I have rather problems with concentrating on the built - at the same time as on explaining the steps I recently do... Hope you will understand ....
Old Aug 21, 2010, 05:13 AM
Harpye is offline
Harpye's Avatar
Germany
Fuse Tool Assembly
one of the main things of my method is the fuse tool which allows to create Skin shells for the fuse like they are made for a revel model....
Quite some effort but it pays as you will see in the next steps...
A1 H Skyraider Tool Fuse (5 min 9 sec)
Old Aug 21, 2010, 05:16 AM
Harpye is offline
Harpye's Avatar
Germany
Fuses Shells
Next step is usually to tightly wrap the fuses tool with a tape - armed sheet of Depron...
A1 H Skyraider Fuse Skin Shell (9 min 50 sec)
Old Aug 21, 2010, 08:17 AM
Harpye is offline
Harpye's Avatar
Germany
Fuse Shell Fixation And Cut - Trimming
Fixing the parts form with heat and afterwards cut - trimming the part from the tool
A1 H Skyraider Heating And Cutting of The 1st Fuse Shell (6 min 54 sec)
Old Aug 21, 2010, 08:50 AM
MIGl7 is offline
Find More Posts by MIGl7
MIGl7's Avatar
www.thunderbolt-gallery.com
Joined Mar 2007
Great stuff! Subscribed
Steve
MIGl7 is offline Find More Posts by MIGl7
Old Aug 22, 2010, 03:16 PM
Harpye is offline
Harpye's Avatar
Germany
Thanks Steve!!
Had some free hours and managed to manufacture the second shell ... little teaser for in between the videos...
And another one about hte cowling ( as soon a s YT finished calculation)
A1 H Skyraider The 1st Half Cowling (10 min 0 sec)
Old Aug 23, 2010, 12:20 PM
Harpye is offline
Harpye's Avatar
Germany
And one part more in the loose assembly
Of course there also would be a possiblilty to create the cowling as vac formed part or from composite .... but I decided to show you the variant related to my technique .... alternatives are your modification
Old Aug 23, 2010, 01:10 PM
Matt Halton is offline
Find More Posts by Matt Halton
Wannabe B-26 pilot!
Matt Halton's Avatar
Southwold, Suffolk, UK.
Joined Nov 2002
This is great, thanks for taking the time to share the techniques.
Very interesting
Matt Halton is offline Find More Posts by Matt Halton
Old Aug 23, 2010, 04:13 PM
Harpye is offline
Harpye's Avatar
Germany
As long as it helps some of you guys a step further, it is worth taking the effort once !
Euuuuh .... yes ... this technique also works for British warbirds..... :Beer !
Hj
Old Aug 25, 2010, 11:47 PM
SteveC68 is offline
Find More Posts by SteveC68
Oh Yeah!
SteveC68's Avatar
League City, Texas
Joined Sep 2006
Does the tape eventually get removed from the depron?
SteveC68 is offline Find More Posts by SteveC68
Old Aug 26, 2010, 12:13 AM
jmm6293 is offline
Find More Posts by jmm6293
Joined Apr 2009
A1 skyraider
U sir have the talent ...and patience I only dream of having..very nice work,c`ant wait to see the final product,a park size A1 has long been overdue,like others on RCG I was hoping that E-flite or Park zone would offer one..but hey,I can still dream.Will u offer it as a kit?
jmm6293 is offline Find More Posts by jmm6293
Discussion Powering 5V camera and 12 video transmitter with car DC12V to 5V 1000mah USB (1$) ganapati08 FPV Talk 9 Aug 13, 2010 02:16 PM
Discussion Need Plans for A1 Skyraider flying-inspecto Electric Warbirds 10 Feb 06, 2006 08:50 AM
FS: Ziroli plans - A1 Skyraider - new Pat Mattes Aircraft - Fuel - Airplanes (FS/W) 0 Nov 17, 2004 09:27 PM
A1-E Skyraider Madguns Scale Fuel Planes 11 Sep 26, 2004 10:54 AM
