Old Aug 20, 2010, 02:08 PM
DEISEL is offline
Find More Posts by DEISEL
OLD ROAD RACER
LAKEWOOD CO.
Joined Jan 2010
hyperion eos06061 help
I just purchased this charger it works great but have some questions.
What is the port on the left side for ? It looks futaba connector like.
When I was charging some nimh packs and there is a number in the third sceen which i do not under stand it goes from 1 to 5 .
thanks greg
DEISEL is offline Find More Posts by DEISEL
Old Aug 20, 2010, 03:35 PM
ggcrandall1 is offline
Find More Posts by ggcrandall1
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
Does the port look like it would take a servo plug? If so it is probably for a USB computer connection for downloading upgrades.
Glen
ggcrandall1 is offline Find More Posts by ggcrandall1
Old Aug 21, 2010, 03:15 PM
DEISEL is offline
OLD ROAD RACER
LAKEWOOD CO.
Joined Jan 2010
Thanks it does look like a servo plug. does any one have a any idea what the numbers stand for I have looked every where.
thanks greg
Old Aug 21, 2010, 05:34 PM
Harry D is offline
Find More Posts by Harry D
TLAR Aviation
Harry D's Avatar
Canada, AB, Edmonton
Greg, I have the 0606i and like it too.
As suggested above, that port is for data transfer to a PC. You will need to buy some extra bits and pieces (cables, interfaces, etc) to use it. I did buy those and it all works well enough but I haven't used it much. The 0606i firmware is not user upgradeable (as it is with some other Hyperion chargers) so the port is for data transfer only.
That third screen in the NiMH menu is for the charge/discharge cycling that can be done with the 0606i. It is documented in the manual, but not very clearly. See the attached marked-up manual page. The numbers (1 to 5) let you select the number of cycles you want. You can also set other things like charge and discharge currents and voltages, whether to charge first then discharge (or vice-versa), and so on.
I had never used this function but your question made me curious so I tried it. It all worked fine, once I got things figured out.
Incidentally, if you don't have the manual you can download it here: http://media.hyperion.hk/dn/eos/EOS0...)-B-MAN-EN.pdf.
Harry D is offline Find More Posts by Harry D
Old Aug 23, 2010, 05:03 PM
DEISEL is offline
OLD ROAD RACER
LAKEWOOD CO.
Joined Jan 2010
Thanks for the reply. I do have the manual but it was not clear as to what this was now I understand.
thank you
greg
Old Aug 23, 2010, 07:05 PM
Drivinfast247 is offline
Find More Posts by Drivinfast247
Michigan
Joined Sep 2009
I believe its the temp port. So you can monitor battery temps.
Drivinfast247 is offline Find More Posts by Drivinfast247
Old Aug 24, 2010, 03:39 PM
DEISEL is offline
OLD ROAD RACER
LAKEWOOD CO.
Joined Jan 2010
This seems to be a good charger. The manual sure could be better.
greg
Old Aug 25, 2010, 07:08 AM
Hughes500Bob is offline
Find More Posts by Hughes500Bob
Retired CFI Helicopter
Hughes500Bob's Avatar
Southeast PA
Joined Jun 2007
http://www.rcgroups.com/forums/showthread.php?t=1221424
See ^^^^ This thread.
Hughes500Bob is offline Find More Posts by Hughes500Bob
Old Aug 25, 2010, 09:21 AM
Harry D is offline
TLAR Aviation
Harry D's Avatar
As stated above, the 0606i firmware is not user upgradeable. That thread is not relevant.
Help! Hyperion Sniper 3D (original)-help needed. tbird911 3D Foamies 1 Aug 01, 2010 06:42 AM
Discussion Hyperion EOS 1210i Charger HELP! pda4you Batteries and Chargers 0 Jan 21, 2010 06:09 PM
Discussion Hyperion 50 amp opto Help sj3cub Power Systems 1 Sep 08, 2009 09:38 PM
Discussion Need help with Hyperion 190 dodge268 Electric Warbirds 2 Aug 31, 2009 08:32 PM
Help! Hyperion DUO II charger HELP! (not user training help :D ) Splix Batteries and Chargers 3 Apr 01, 2009 06:57 AM
