Old Aug 18, 2010, 08:49 PM
bill34207 is offline
Find More Posts by bill34207
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
Build Log
Aeromarine 1/8 Miller American hydro
My Miller American hydro arrived via UPS today. To be honest I'm a little disappointed in the quality for the price. It's going to take quite a bit of sanding along the seam lines and the hatch doesn't fit all that well either. I'll deal with it though.
When I ordered it a couple of weeks ago had planned to fit it with my 1527/1.5Y on 10s but am now leaning towards one of the new Leopard 5692's I'm thinking the 1340 kv on 6s 2p. There's enough room in the very front opening for a single 6s pack and I should be able to slip 2 more 3s packs in on either side of the motor to keep the weight forward.
Didn't accomplish a whole lot this evening. Just cut the opening for the strut and installed it to check for fit.
bill34207 is offline Find More Posts by bill34207
Latest blog entry: Freewing 80 mm Mig 21 Fishbed
Old Aug 18, 2010, 10:36 PM
scorpion1 is offline
Find More Posts by scorpion1
I feel the need for speed!
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Nice.........thats gonna be a real hog.............!! That big leopard should move it out well.
scorpion1 is offline Find More Posts by scorpion1
Old Aug 20, 2010, 07:31 PM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
Thanks Scorp. I suppose it will eventually make a nice hydro but I'm really disappointed in what I got for the $$ spent. I really expected more from a big name company like Aeromarine.
I drilled the holes for the turn fin mount last night and found there was only a thin layer of glass and about a 1/8" piece of ply to hold it. Got aggravated and stopped for the night.
This evening I fixed that problem. First made myself a paper pattern of the back of the sponson, then cut a piece of balsa to match it. I taped that to a bent clothes hanger and slid it inside to check for fit. (you sure can't get your hands in there) After getting a good fit with the balsa tranferred that pattern to a piece of 1/4" aircraft ply and using the hanger again coated the ply with a thick mix of 30 minute epoxy and milled fiberglass. Worked it into position and held pressure on it with a piece of aluminum bar stock until it cured.
After the epoxy cured re-drilled the holes through the added ply and tapped them to match the bolts. A little thin CA into the holes to harden the threads and ran the tap through again once it had cured. (then repeated the process again). I've done the same on retract mounts in my jets and it makes "threads of steel".
Old Aug 20, 2010, 09:12 PM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
Got "most" of the rough sanding on the seams done.
I guess now I understand why anybody that has an 1/8 scale wants a fortune for it.
Man I wish they built something this size in china. You could probably pick up a pre painted maybe even with hardware for a $100 less. Are you listening Hobby King?
That's all for me tonight. I don't have to work tomorrow or wouldn't have got this far. I'm still an old man and needs my sleep.
Old Aug 20, 2010, 09:46 PM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Old Aug 21, 2010, 06:05 AM
osprey21 is offline
Find More Posts by osprey21
osprey21's Avatar
Palma Sola,Fla.
Joined Oct 2006
Wow... I'd be "a little dissapointed" as well - that hatch is inexcusable IMO. I think I'll sit on my wallet a bit longer and see how it turns out.
osprey21 is offline Find More Posts by osprey21
Old Aug 21, 2010, 06:19 AM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
For my persistant pm'er. I'm not looking to debate whether all the "light hydros" have the strut behind the boat instead of underneath it and certainly not going to do it via pm's.
My UL-1 has the strut behind and works well. However... I'm building this for oval competition and not to run around doing figure 8s or drag races in a backyard pond. I did a lot of research in the NAMBA rule book before starting this project.
Find yourself a NAMBA rule book. Check section 21, page 3 paragraph 9. "The propeller drive dog may extend one drive dog length beyond the transom"
If the strut were placed on the back of the transom it would take a REALLY BIG drive dog to be within one drive dog's length. So, even if you do know better I'll continue on with it my way. The strut allows for more adjustment than you might think as well.
Old Aug 21, 2010, 06:30 AM
sailr is offline
Find More Posts by sailr
Land O' Lakes, FL
Joined Aug 2003
Yeah, but shipping would be $300!
sailr is offline Find More Posts by sailr
Old Aug 21, 2010, 06:33 AM
sailr is offline
Land O' Lakes, FL
Joined Aug 2003
Bill, my 5692 motor came in if you want to get one in your hands. What are we going to use for motor mounts? We should get together. It's time for me to address the issue on my 1/8th Hydro I'm building.
I also noticed you mounted your strut amidships. I often see the strut mounted off center to the right (starboard) on right hand circle burners. Anyone?
Old Aug 21, 2010, 09:24 AM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
Morning Chris & Jim. I see that I lured a couple of people from the OSA forums over. Wish that Ray & Hugh would drop by since they both have more experience in the scale unlimited hydros than we do.
I'm still trying to decide whether to put the rudder on the port or starboard side and would welcome their input. I went with centerline on the strut because I didn't have a clue about how much offset would be beneficial and it will make it easier to line up the motor.
In the meantime, after finishing sanding the seams I pulled the strut back out and added a few layers of cf weave.
Last edited by bill34207; Aug 21, 2010 at 09:37 AM. Reason: spelling. I really need to learn to proof read. :D
Old Aug 21, 2010, 09:27 AM
785boats is offline
Find More Posts by 785boats
RELAX. You'll live longer
785boats's Avatar
Brisbane- Australia
Joined Jul 2007
Nice build you've got going there Bill.
But Sailr is right. It's common practice to move the whole driveline off to the right about 3/16"-1/4" to counter the propwalk. That way you don't need any left rudder trim to track straight. That saves a lot of drag.
I did that with the Campbell shovel I just finished & the rudder is set at neutral for a straight run.
Cheers.
Paul.
785boats is offline Find More Posts by 785boats
Old Aug 21, 2010, 09:52 AM
sailr is offline
Land O' Lakes, FL
Joined Aug 2003
On the big 1/8th scales, I'm thinking 1/2" offset? My rudder is going on the right (starboard) side. That's the way you're turning. You don't want to be pulling the rudder up out of the water if you happen to lift the left sponson going around a turn! That's my way of thinking anyway. Not sure it's correct.
You're probably fine with that centered strut. Hugh said if in doubt, just center it and then trim the boat. I happen to agree with the offset. I'd rather not have to trim the rudder as that just slows you down.
Remember, the 101/th scales have all this reversed as they run counter clockwise!
How big is the Campbell roundnose?
Cheers.
Paul.
Old Aug 21, 2010, 10:00 AM
nick30head is offline
Find More Posts by nick30head
nick 30
nick30head's Avatar
Joined May 2009
i have a miss t-plus hull to work on so i may try your idea of mounting the stru tinside but need to open the hatch area more to be able to work on it properly
nick30head is offline Find More Posts by nick30head
Old Aug 21, 2010, 10:26 AM
785boats is offline
785boats's Avatar
Brisbane- Australia
Joined Jul 2007
Jim
The roundnose is only 24" long
Here's todays maiden run.
http://www.rcgroups.com/forums/showt...1286857&page=3
Cheers.
Paul.
Old Aug 21, 2010, 10:47 AM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
Cheers.
Paul.
Thanks Paul. Now that's what I like. Somebody that will give me some dimensions to shoot for. I haven't peeled back my masking tape yet (still waitng for the Zpoxy to finish curing) but if it flowed down enough to fill the holes may try the 1/4" offset even though the plans sheet that came with it shows it centered.
Jim, I think you may be thinking in 1/10 scale mode for counter closkwise turns on the rudder placement. Running clockwise in 1/8 you're more likely to lift the right (starboard) sponson in a turn. (I think)
Question 1/8 scale Atlas Van Lines Hydro markcouty Scale Boats 5 Oct 04, 2010 02:01 AM
Help! Futaba GY401 in a 1/8 scale hydro H1RC Beginner Training Area (Heli-Electric) 11 Aug 18, 2010 12:02 AM
Wanted 1/8 scale hydro markcouty Boats (FS/W) 7 Jul 02, 2010 10:34 PM
For Sale 1986 Miller American viperjody Boats (FS/W) 0 Nov 29, 2009 01:27 PM
Sold FS MILLER AMERICAN 1/8 Scale FE Hydroplane ARTR K.R.Joye Boats (FS/W) 0 Jul 18, 2006 06:14 AM
