Canada, QC
Joined Oct 2009
Here's my clue: "and glide down to a perfect landing" Gliding with no power for landing with a T-28 is easy... With the Beast, not so! |
United States, CA, Sebastopol
Joined Dec 2010
United States, SC, Charleston
Joined Aug 2011
How does landing the 3D Beast compare with landing the V1 Beast? I have the V1 and find she's a sweet flyer and a pussycat to land...unless I'm flying her in tricky wind conditions. Even then, once I get her safely down into ground effect, no problem. Is the 3D Beast the same? How do they compare?
On another note: I figured out how to consistently get KE spins with the B3D! Also the Lomcevak. Although the Lom is not consistent and requires a bit of luck and a PERFECT entry. All of this was done on a normal neutral CG, nothing crazy aft. instructions for the KE spin: 1. Enter a Vertical climb 2. When you have enough altitude, reduce power so that the climb rate slows to about 3-4mph (basically High alpha full elevator level flight speed, but now in the vertical direction) 3. Give Snap roll inputs, cross controlled rudder-aileron and full up elevator. --If your speed was right and you didn't move the throttle much you'll get a rather slow snap roll that should completely halt your vertical speed. 4. about 2/3 of the way through the snap roll reverse the elevator and increase the throttle a bit. --this takes some feel and trial and error. 5. the plane will enter a really violent inverted snap/spin. After about 1-2 rotations it should tip up on edge and start the KE spin. 6. As it enters the KE spin relax the aileron and rudder a bit. I was able to get 4-5 very good, pivoting about the trailing edge of the wings, spins. Like almost everything else B3D recovery was release controls and almost immediate nose drop and fly out. -Brian |
I can understand where you are coming from too, I was one of those people who said it couldn't be done! I had tried hundreds of times and never got it to go. Finally today I was flying my CC, enjoying some nice relaxing scale slow cub flight. I landed and took the B3D up. I was still in a "cub mode" mindset though so I was just doing some lazy circuits and then decided I'd do a little acro. But I had the throttle way down and after a dive for speed I pulled up into a vertical at about 50% power and did a snap and was going to try and hover, Because I had the power lower than I normally would the snap didn't finish the rotation, I added full down(negative) elevator trying to bring the nose back up. The little beast did a really nice looking though unintentional lomcevak! After that I just repeated what I did at a higher altitude and held the inputs, couldn't get the lomcevak again, but the KE spin developed quite nicely. Try it, just remember use less throttle than usual. -Brian |
upline to: left 3 o'clock , right 7:30(full lower left corner) then left: 2:30 o'clock, right 11(upper left) I'm using a 3000kv and a 5030, for power reference and was using a MA210 pack that was about 1/8" showing the rest under the cowl on the battery tray. -Brian |
| Thread Tools | |
| Discussion ParkZone Ultra Micro T-28!!! THE Owners Thread!!!! | dkintx | Micro RTF | 9062 | Today 12:44 AM |
| Official Parkzone P-51 Owners Thread - Part 2 | monitor | Parkflyers | 2601 | Oct 15, 2012 05:41 PM |
| Discussion UM beast, Now your talking | qman | Micro RTF | 102 | Dec 22, 2010 10:39 AM |
| Discussion The first OFFICIAL Parkzone Sukhoi SU-26XP BNF by ParkZone Owners thread | skyjet | Micro RTF | 2 | Mar 19, 2010 03:00 PM |
| Official Parkzone P-51 Owners Thread | monitor | Parkflyers | 913 | Oct 04, 2005 09:02 PM |
