Old Jun 18, 2012, 08:49 PM
DonJuan is online now
Find More Posts by DonJuan
Registered Plane Abuser
DonJuan's Avatar
Illinois
Joined Jul 2005
My rudder servo was getting stuck first day out of the box. I got that fixed and now my elevator servo is getting stuck. I've spent more time fixing this thing than flying it. So before this thing turns itself into a bunch of little foam pieces I'm gonna try to get my money back.
DonJuan is online now Find More Posts by DonJuan
Old Jun 18, 2012, 09:05 PM
JoshB is offline
Find More Posts by JoshB
Novice in training
JoshB's Avatar
United States, NC, Statesville
Joined Aug 2011
After seeing all these issues with the Beast I think I'm going to just sell mine before something happens.
JoshB is offline Find More Posts by JoshB
Old Jun 18, 2012, 09:20 PM
turboparker is offline
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
I assume you're talking about the Beast 3D? If so, when did you buy the plane & how many flights are on it?
Joel
turboparker is offline Find More Posts by turboparker
Old Jun 19, 2012, 12:09 AM
JoshB is offline
Novice in training
JoshB's Avatar
Joined Aug 2011
Yes the 3D with the gyro system. I got it in January. It was what I bought with my Christmas gift card I got. I flew it for about 5 minutes the other day. Thats the only flight on it.
Old Jun 19, 2012, 12:12 AM
WSEN is offline
Find More Posts by WSEN
McCarthy, Alaska
Joined Jun 2004
Fear is a horrible thing.
WSEN is offline Find More Posts by WSEN
Old Jun 19, 2012, 07:00 AM
kalmon is offline
Find More Posts by kalmon
Parkzone junkie
kalmon's Avatar
United States, MI, Grand Traverse
Joined Oct 2008
It is starting to look like that bad batch of servos that have been plaguing the CC also found their way into that last container of B3Ds as well.
-Brian
kalmon is offline Find More Posts by kalmon
Old Jun 19, 2012, 07:39 AM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
I hear you.
NitroCharged is offline Find More Posts by NitroCharged
Old Jun 20, 2012, 06:24 PM
Joined Jul 2009
Static RPM testing - Thunder Power G6 325 mAh 65c 2s 'Babbelbatt'
Finally got a chance to do some static RPM testing with the Thunder Power G6 325 mAh 65c 2s 'Babbelbatt'. The pack only has 5 cycles on it. If they're anything like the Hyperions, they'll take 50-70 cycles just to break-in, so performance aught to improve somewhat. Nevertheless, it still provides the best thrust-to-weight ratio of the group. I didn't test it on the 2300Kv/5043 combo, given that I only saw a 100 RPM difference between a Hyp 180 & Hyp 240 during my previous tests.
Static RPM testing
RPM taken under natural light with a calibrated optical tach, 20 sec into each run on a freshly-charged pack.
Elevation: 910 ft AMSL
Temp: 70 F
Motor: 3000Kv
Prop: GWS 5030
-------------- Weight (g) --- RPM ---- Thrust (g)* - Speed (MPH)**
Hyp 450 ----- 25.28 ------- 12980 ----- 161 ----------- 36.90
THP 325 ---- 20.80 ------- 12800 ----- 156 ----------- 36.36
Hyp 320 ----- 18.80 ------- 12600 ----- 151 ----------- 35.80
Hyp 240 ----- 14.46 ------- 12240 ----- 142 ----------- 34.80
*Calculated using the GWS prop spreadsheet
**Calculated pitch-speed. Prop slippage and in-flight unloading not taken into account.
Joel
Old Jun 20, 2012, 09:12 PM
DonJuan's Avatar
Illinois
Joined Jul 2005
JoshB, I can see other people are flying this thing without having problems. If you got yours in Janurary you might be OK. I just got mine, and as I said it was bad out of the Box. Horizon is going to send me a completely new board to replace the one I have. I'm willing to give it a try. Of course if I end up with the same problems I'm having now they will have lost a customer forever.
Old Jun 21, 2012, 09:33 PM
grovey is offline
Find More Posts by grovey
Just wanna fly!
grovey's Avatar
United States, TX
Joined Apr 2008
Video time again
Still trying to learn how to hover, I think I may need some more elevator authority, or perhaps more power?
I have another video, but for some reason I am getting artifacts on my videos during the rendering process. I need to figure out why.
UMX Beast 3D 6/21/2012 Part 1 (5 min 3 sec)
grovey is offline Find More Posts by grovey
Old Jun 21, 2012, 09:44 PM
turnerm is offline
Find More Posts by turnerm
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
Originally Posted by grovey View Post
Video time again
http://www.youtube.com/watch?v=vjUrOucs9aU
Nice flying again! The Beast isn't the easiest plane to learn to hover on. It has enough elevator authority and enough power, both stock out of the box... But just barely. I'm sure the power out ability is WAY MORE than sufficient on the 3s setups these guys are running. I plan on trying it soon.
But with a stock (or mostly stock) setup you have to be quick on the sticks to both keep it in hover and to exit out gracefully. Once it starts coming out of hover there's usually not an easy way back so you're better off getting comfortable with flying out in whatever orientation it falls into. This is easier said than done but with (lots of) practice you'll get it. And once you've got it everything else just starts coming around too (KE flight in both directions, inverted harrier, etc).
Keep up the practice though... It's looking good!
turnerm is offline Find More Posts by turnerm
Old Jun 21, 2012, 09:55 PM
grovey is offline
Just wanna fly!
grovey's Avatar
United States, TX
Joined Apr 2008
Thanks Turnerm!
I will definitely be practicing more yeah and you are right, when I come out of hovering, I have to think quick, and have to fly inverted if necessary.
I am getting more comfortable, but KE is still daunting, I got a long way to go there.
Old Jun 21, 2012, 10:00 PM
turnerm is offline
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
Thanks Turnerm!
A good simulator is perfect for practicing KE and inverted harriers.
Old Jun 21, 2012, 10:12 PM
grovey is offline
Just wanna fly!
grovey's Avatar
United States, TX
Joined Apr 2008
I do need to spend more time on the sim. I have Realflight 6 on my windows machine, and for some reason the models have no textures, making it difficult to judge orientation. I may need to run windows on a virtual machine on my Mac and see if that will run the simulator better.
Old Jun 21, 2012, 11:14 PM
JoshB is offline
Novice in training
JoshB's Avatar
Joined Aug 2011
I might just try it and see how it does. I tried to make it fail like I have read some on here doing and it seems to be fine right now. It might be ok like you said. Guess I will know after several more flights. I mainly bought it to learn how biplanes flew since I got a Ultimate so maybe it will last long enough to get me some experiance with a bipe before I jump to the bigger one.
Discussion ParkZone Ultra Micro T-28!!! THE Owners Thread!!!! RM_Sparks Micro Ready-to-Fly 10699 Today 06:46 PM
Official Parkzone P-51 Owners Thread - Part 2 monitor Parkflyers 2602 Jun 15, 2014 04:51 PM
Discussion UM beast, Now your talking qman Micro Ready-to-Fly 102 Dec 22, 2010 10:39 AM
Discussion The first OFFICIAL Parkzone Sukhoi SU-26XP BNF by ParkZone Owners thread skyjet Micro Ready-to-Fly 2 Mar 19, 2010 03:00 PM
Official Parkzone P-51 Owners Thread monitor Parkflyers 913 Oct 04, 2005 09:02 PM
