The V1 Beast's ESC has a lower current rating than the ESC in the newer UMX ships. The V1 brick may handle the voltage, but it is not likely to handle the increased current of a 3s setup. If you are not already doing so, put a 5043 prop on our V1 & get some good packs - such as Hyperion 180s or the new Turnigy Nano 180s. This will dramatically improve the performance over the stock prop and/or pack. Joel |
Latest blog entry: Eflite UMX Sbach 3D on 3s - 2300Kv/5043...
I'm trying to find out if I can use regular CA or if I need foam safe CA?
And yes I have used the search and can't find anything on it. I had my first mishap with my Beast. It was windy gusting to 20mph + and the wind quit blowing with me on final approach. She dropped very quickly and have a small tear in the bottom wing. What a bummer, just had a great flight and learned to knife edge. |
Dizzy,
I don't use foam safe ca anymore on foam repairs. Very brittle joints. This stuff is amazing! Can be used like a contact cement for fast field repairs as well. http://www.filadelfosrc.com/index.ph...id=146:foamtac rc
uk
Joined Mar 2010
2nd Beast 3d is here, would'nt you know, after about 5 days of no beast 3d and no wind i find myself with a new beast 3d and loads of wind argh bloody argh and its cold outside lol.
I think i might pass the 3s craze this time round ![]() My prayers go out to the dead bricks. I've allways wondered this, whats the easist way to change to the control surfaces for more handling, how do you take the rods from out of the horn holes? I've never been happy teh way i do it. |
It's one of those skills that you get better at with practice. My favorite method: I use two small long needle nose pliers. Like the one in this set: http://www.harborfreight.com/6-piece...set-31675.html I grab the control rod close to the horn with one. I lightly flex the control horn with the other plier. It's a quick twist and flex motion. If I made vids, you would see just how fast and easy it is to do.rc
uk
Joined Mar 2010
That's the way i do it, i find it very tricky, these little buggers are so little and light and my fingers are so fat. |
I'm not all than happy with my method, either - but I have yet to damage anything by doing it this way. I hold the pushrod with my fingers while I carefully twist the free end of the control horn with a needle-nose pliers. I then use my fingers to remove the pushrod. To reinstall, I twist the horn 90 degrees with the pliers & use my fingers to insert the pushrod. Joel |
uk
Joined Mar 2010
| Thread Tools | |
| Discussion ParkZone Ultra Micro T-28!!! THE Owners Thread!!!! | dkintx | Micro RTF | 9008 | Today 12:50 PM |
| Official Parkzone P-51 Owners Thread - Part 2 | monitor | Parkflyers | 2601 | Oct 15, 2012 05:41 PM |
| Discussion UM beast, Now your talking | qman | Micro RTF | 102 | Dec 22, 2010 10:39 AM |
| Discussion The first OFFICIAL Parkzone Sukhoi SU-26XP BNF by ParkZone Owners thread | skyjet | Micro RTF | 2 | Mar 19, 2010 03:00 PM |
| Official Parkzone P-51 Owners Thread | monitor | Parkflyers | 913 | Oct 04, 2005 09:02 PM |
