Old Jan 30, 2012, 12:48 PM
RealGambler is offline
Find More Posts by RealGambler
Way to many airplanes!
Canada, QC
Joined Oct 2009
Originally Posted by erkq View Post
When is someone going to try 3S on the AS3X board? I've transplanted one into a 3000kv equipped Sbach and want someone else to test for Magic Smoke before I toast my FrankenBach. The FrankenBach is such a wonderful plane I want someone else to fry theirs first!
Well, RCBabbel was supposed to do it this morning, but since we have not heard from him yet, maybe he is still picking up the pieces and will only report when the bag will be full....
RealGambler is offline Find More Posts by RealGambler
Old Jan 30, 2012, 01:21 PM
RCBABBEL is online now
Find More Posts by RCBABBEL
**I'm Battman**
RCBABBEL's Avatar
Twin Falls, Idaho
Joined Jan 2005
Hey guys,
Work got me again.
Had just enough time this morning for a few Hyp 3S 180 run ups.
AS3X system and servos are operating normally.
Batt is a snug fit.
Awesome power!
Beast 3D with 5030 prop:
Peak static RPM: 14,250
After 30 sec run time: 13,750
This is going to be fun!!
Got to run...
rc
RCBABBEL is online now Find More Posts by RCBABBEL
Old Jan 30, 2012, 01:40 PM
BobaFett1138 is offline
Find More Posts by BobaFett1138
Too much to do not enough time
BobaFett1138's Avatar
Wisconsin
Joined Sep 2010
Woah woah, 3S using the stock brick/motor? *drools uncontrollably* I MUST see a video of it flying! If you start making 3S packs you will have many customers........
BobaFett1138 is offline Find More Posts by BobaFett1138
Old Jan 30, 2012, 03:42 PM
Canada, QC
Joined Oct 2009
Originally Posted by RCBABBEL View Post
Hey guys,
Work got me again.
Batt is a snug fit.
Awesome power!
Got to run...
rc
Wooooooweeeeeee! With prop unloading in flight, minus the usual losses, that's should give you close to 40mph, on the Beast
So basically, other than not having LVC anymore (and you should not hit that anyway!) and carrying a few more grams, there's basically no drawback unless you don't want a speedy aircraft. I guess hot summer days may be a problem...
Old Jan 30, 2012, 11:22 PM
**I'm Battman**
RCBABBEL's Avatar
Twin Falls, Idaho
Joined Jan 2005
RG,
This stripped down Hyp 3S 180 has me way excited!
It's almost the exact same weight as the stock UMX Hyp 2S 240s.
http://www.rcgroups.com/forums/showp...&postcount=616
16.56g vs 16.76g
No additional weight.
No change in balance point.
Crazy power if you so desire.
Hovering an ultra-micro without extra power drives me nuts.
Hope to take her up tomorrow after work.
Bringing along a 5043 as well.
rc
Old Jan 30, 2012, 11:43 PM
freesex is offline
Find More Posts by freesex
freesex's Avatar
Joined Aug 2011
RG,
16.56g vs 16.76g
rc
16.76 g is awesome !!, my 3 X 1S hyperion 240mah + connector is 23G, but will give longer flight time as 3s setup draws extra amp
freesex is offline Find More Posts by freesex
Old Jan 31, 2012, 06:42 AM
bobly is offline
Find More Posts by bobly
Joined Sep 2010
I have no experience with different voltages being used for rc motors, but in general for the same watts of power produced, higher voltage would draw less amps wouldn't it? So sounds like you should be able to make more watts for the same or less amps with 3 cell.
bobly is offline Find More Posts by bobly
Old Jan 31, 2012, 10:01 AM
Gary Hoorn is offline
Find More Posts by Gary Hoorn
Chesapeake Bay RC Club
Gary Hoorn's Avatar
USA, MD, Annapolis
Joined Feb 2005
Roger,
Have you plugged in a 3S setup and counted the "beeps" from the ESC? In the video above it sounds like only 2 cells are being detected.
Gary
Gary Hoorn is offline Find More Posts by Gary Hoorn
Old Jan 31, 2012, 11:33 AM
freesex is offline
freesex's Avatar
Joined Aug 2011
Originally Posted by Gary Hoorn View Post
Roger,
Gary
interesting! I didn't notice that there were only 2 beeps. but 3 cells were connected in series, the electirc circuit wouldn't be complete if 1 cell was missing.
test flew B3D with my 3s setup this morning, AUW 82g, It handle extre weight very well, vertical performance was very solid! that's was the biggest improvement, hover and TR were easier bue to increased punch. not much faster though. will try different prop and motor setup on 3S, and keep you guys posted.
Old Jan 31, 2012, 01:18 PM
turboparker is offline
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
Bobly,
You are correct. Propped for the same wattage, a 3s setup will draw much less current than a 2s setup. Higher voltage is also more efficient, as it allows one do the same amount of work while drawing less current. Less current means lower I^2R loss, which, as the formula shows, exponentially increases efficiency.
Joel
turboparker is offline Find More Posts by turboparker
Old Jan 31, 2012, 02:15 PM
freesex is offline
freesex's Avatar
Joined Aug 2011
Oh, sorry, I was wrong. thank you guys for corectting me
Old Jan 31, 2012, 06:24 PM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Anyone interested in a HK nano tech 25C 2S 180 test?
Const. Dsc 1-3A
http://www.rcgroups.com/forums/showp...56&postcount=1
nano and Hyp. compared at 1.5 and 2A
http://www.rcgroups.com/forums/showp...60&postcount=4
Charles
Old Jan 31, 2012, 06:39 PM
brushless55 is offline
Find More Posts by brushless55
big ignore list
brushless55's Avatar
United States, CO, Longmont
Joined Nov 2011
excited on 3s setup, I decided to make a 3s connector myself. it was done within an hour. test run with 2300kv motor + 5043, seems to be fine. here are some pics and test run video.
http://www.youtube.com/watch?v=aCNIu...ature=youtu.be
Very cool man!
like the looks of your pack, here is mine..
started a while back on the UMX Sbach forums..
My Micro Beast V1 sounds like it winds out more than your though..?
on the V1 I am unable to go past 75-80% throttle with a 5030 prop as the esc is going into some protection mode, but soon as I throttle back and hit it again is spins right up..
brushless55 is offline Find More Posts by brushless55
Old Jan 31, 2012, 08:16 PM
snjbird is offline
Find More Posts by snjbird
3D... the only way to fly!
snjbird's Avatar
Kissimmee
Joined Apr 2010
Const. Dsc 1-3A
Charles
Charles they look pretty close on the compare graph... What kind of words do you have after doing the test?
I did throw mine on the scales, the Nano is a bit lighter. I will be interested to see how they hold up. From these test, do you have a guesstimate to cycle life?
snjbird is offline Find More Posts by snjbird
Discussion ParkZone Ultra Micro T-28!!! THE Owners Thread!!!! RM_Sparks Micro Ready-to-Fly 10699 May 26, 2016 06:46 PM
Official Parkzone P-51 Owners Thread - Part 2 monitor Parkflyers 2602 Jun 15, 2014 04:51 PM
Discussion UM beast, Now your talking qman Micro Ready-to-Fly 102 Dec 22, 2010 10:39 AM
Discussion The first OFFICIAL Parkzone Sukhoi SU-26XP BNF by ParkZone Owners thread skyjet Micro Ready-to-Fly 2 Mar 19, 2010 03:00 PM
Official Parkzone P-51 Owners Thread monitor Parkflyers 913 Oct 04, 2005 09:02 PM
