Old Jan 22, 2012, 02:38 PM
I hate winter!
binaryclock's Avatar
Canada, ON, Barrie
Joined Jul 2011
I can't speak for the B3D, but for the v1 Beast hyperions are not required. The turnigy nano-tech 160s do a pretty good job and it's hard to notice the difference.
Don't get hung up on hyperions.. it's a lot of "hype." It's better to buy 50 batteries at $1 each than 10 batteries at $5 each.
binaryclock is offline Find More Posts by binaryclock
Old Jan 22, 2012, 02:59 PM
United States, CA, Sebastopol
Joined Dec 2010
Regarding th v1, with the stock prop, maybe. But with the 5043, DEFINITELY untrue. I'd rather have 10 batteries that give me sparkling performance than 50 that give me mush. It's as clear as night and day. Verticals go from barely, mushy, weak with the stock prop and stock battery to aggressive boring holes in the sky, supporting fast rolls as far as you can see with the 5043 and Hyperions. It's all what you're looking for.
erkq is offline Find More Posts by erkq
Old Jan 22, 2012, 03:15 PM
fly-crash-fix
UK, Powys, Newtown
Joined Jan 2010
Well i put an order in for 10 turnigy 160`s earlier today so that`s what i`ll use for now and as i`ll just be taking it easy for a while i reckon they`ll be fine, seems a lot of others are using them too.
Plus i can charge them with my existing leads without paying 6 odd pounds for yet another charge lead
Dr.Crashenburn is offline Find More Posts by Dr.Crashenburn
Old Jan 22, 2012, 03:19 PM
EDF Junkie
Pacific Northwest
Joined Oct 2007
That has not been my experience. Hyperions are a clear performance boost. I like my UM's much better after I started using them. I've tried the Hobbycity UM batteries and I have a lot of them sitting around unused. The larger Hobbycity batteries work great for me though.
NwRcFlight is offline Find More Posts by NwRcFlight
Old Jan 22, 2012, 03:21 PM
I hate winter!
Canada, ON, Barrie
Joined Jul 2011
I use the 5043 with turnigy nano techs and it's fine. Actually the hyperions are mush compared to the nano techs and they all have about the same amount of flights. Maybe I ran the hyperions harder than the nano-techs? not sure.. could be the case.
The hyperions seem to last a bit longer though. The nano techs will start to fall off around the 3 min mark.
Again, 50 batteries vs 10... if you aren't a pro or semi-pro, the choice is obvious for the most stick time.
This is based on v1 Beast, not B3D... B3D may be a total other ball park.. no idea about that one.
Old Jan 22, 2012, 03:31 PM
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
The only logical reason I can see for this would be the fact that hyperions maintain higher voltage longer during discharge and thus are easier to overdischarge than some others.
http://www.rcgroups.com/forums/showthread.php?t=1565033
No Nanos tested there but I have tested some in the past and was not impressed. I will test the 180 HK nanos if they ever ship them.
Charles
Old Jan 22, 2012, 04:16 PM
fly-crash-fix
UK, Powys, Newtown
Joined Jan 2010
I bought the b3d and after reading more it appears they need more power so it looks like i`ll have to buy better batts after all. And charge leads
Good job i don`t add up everything i spend on this hobby...might send send me over the edge...wibble
Old Jan 22, 2012, 05:41 PM
Flying addicted and lovin it!
Fish99's Avatar
Canada, AB, Edmonton
Joined Jun 2010
I bought Hyperion 180 single cells and using Joel (Turboparkers) example soldered my own home made 2 cell packs up and they work AMAZINGLY well on my V1 Beast. VERY noticeable improvement over the Stock Eflite lipo.
I have not tried the Nano's yet, and must say, I picked up 1 for my mCPX heli (single cell) and was impressed with the improvement over my stock Eflite lipos, so maybe it will be good.
I can say without hesitation the Hyperions are great lipos, and the V1 Beast (which is less power hungry) on GWS 5030 prop has unlimited vertical, can hover (within the skills of the pilot) and pull out vertical from the same, throughout the entire duration of my 6 min flights.
Just took some low and slow video and will try to edit it up and post a link soon. Nothing near as nice flying as RG or Joel, but WAYYYY too much fun. CG was way back and it sure does help with harrier and hover, but kinda makes standard flying and KE harder!
Marlin
Fish99 is offline Find More Posts by Fish99
Old Jan 22, 2012, 05:46 PM
I hate winter!
Canada, ON, Barrie
Joined Jul 2011
Yep the e-flite ones are garbage.
Old Jan 22, 2012, 06:49 PM
Southern Pride
1S Hyp. 120 and HK Nano 138 compared
http://www.rcgroups.com/forums/showp...8&postcount=21
Old Jan 22, 2012, 07:28 PM
I hate winter!
Canada, ON, Barrie
Joined Jul 2011
that's a flightmax, not a nano tech
Old Jan 22, 2012, 07:43 PM
3D... the only way to fly!
snjbird's Avatar
Kissimmee
Joined Apr 2010
I now have 4 cycles on my new Hyperion 240, and a 180. So far I feel they are not pulling as hard as the Nana Tech 180s are at 20 cycles. And the mini Aviation 210 is really strong at 15 cycles. But I admit, I don't have the equipment, or the skills to make any definitive claims, just noob observations.
snjbird is offline Find More Posts by snjbird
Old Jan 22, 2012, 07:51 PM
Way to many airplanes!
Canada, QC
Joined Oct 2009
At only 4 cycles, those Hyperions are not even broken yet.
RealGambler is offline Find More Posts by RealGambler
Old Jan 22, 2012, 08:28 PM
snjbird's Avatar
Kissimmee
Joined Apr 2010
Yes time will tell, but I have been playing with lipos in my helis for 5 years, and they don't ever get any stronger, the longer you run them?
Old Jan 22, 2012, 09:25 PM
Did you commit aviation today?
turboparker's Avatar
East Bethel, MN USA
Joined Jul 2009
Hyperions typically get stronger for the first 50-70 cycles, and then stabilize for the next couple hundred cycles or so.
Joel
turboparker is offline Find More Posts by turboparker
Discussion ParkZone Ultra Micro T-28!!! THE Owners Thread!!!! dkintx Micro RTF 9053 Yesterday 12:56 PM
Official Parkzone P-51 Owners Thread - Part 2 monitor Parkflyers 2601 Oct 15, 2012 05:41 PM
Discussion UM beast, Now your talking qman Micro RTF 102 Dec 22, 2010 10:39 AM
Discussion The first OFFICIAL Parkzone Sukhoi SU-26XP BNF by ParkZone Owners thread skyjet Micro RTF 2 Mar 19, 2010 03:00 PM
Official Parkzone P-51 Owners Thread monitor Parkflyers 913 Oct 04, 2005 09:02 PM
