Old Jan 21, 2012, 07:32 PM
ICU is offline
ICU
Find More Posts by ICU
ICU
Check out my Shapeways Shop
ICU's Avatar
Dallas,Tx.
Joined Apr 2007
Yes great flying RG. Was that with the stock prop?
I was able to get a few more flights in on the B3D today. First one was a baseline to get the feel for the B3D motor. The next was with the 5043 equipped V1 motor. And I had a lot more power. And after seeing RG's video there, it just has to be a weak B3D motor. Or the adapter I'm using for my batteries. Since I've gotten 9 flights on it I'll switch out the stock plug for the one I use and try it again next week.
ICU is offline Find More Posts by ICU
Old Jan 21, 2012, 07:36 PM
ICU is offline
ICU
ICU
ICU's Avatar
Dallas,Tx.
Joined Apr 2007
Boba,
If you don't want to go thru the trouble of making your own wheel pants I got the solution for you. While they are not foam. They are virtually indestructible.
Old Jan 21, 2012, 08:19 PM
turboparker is offline
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
Which adapter are you using?
Joel
turboparker is offline Find More Posts by turboparker
Old Jan 21, 2012, 10:10 PM
turnerm is offline
Find More Posts by turnerm
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
Originally Posted by RealGambler View Post
FINALLY!!!!! I got to fly my Beast 3D in almost no wind!!! I maidened it, and flew it until now, in heavy wind, so could not really see what it was capable of. Now I know. I was impressed before, but I'm blowned away now! Here's a video... The smoke in the beginning is not a lipo burning.... That's just me trying to survive in the cold!
http://www.youtube.com/watch?v=FsSPVZ-OIj8
Nice flying RG! She's a sweetheart of a plane isn't she?
turnerm is offline Find More Posts by turnerm
Old Jan 21, 2012, 10:19 PM
RealGambler is offline
Find More Posts by RealGambler
Way to many airplanes!
Canada, QC
Joined Oct 2009
Stock everything, and pretty new NanoTech batteries!!! (My stock of Hyperions are likely dying, since they are not good anymore in that kind of cold). So you really have a problem. Vertical is ok, not extreme, but getting out of hover is easy. Also curious about the adapter you're using...
RealGambler is offline Find More Posts by RealGambler
Old Jan 21, 2012, 10:27 PM
Canada, QC
Joined Oct 2009
Totally sold on the AS3X system now! I still had to fight a small breeze, but hover are definitively much easier than on the V1. Still find that hard to believe! And still trying to figure the whole concept behind the AS3X tech. It does thing that amaze me and yet doesn't make much sense. On Android phone right now, will explain later...
Old Jan 21, 2012, 10:43 PM
BobaFett1138 is offline
Find More Posts by BobaFett1138
Too much to do not enough time
BobaFett1138's Avatar
Wisconsin
Joined Sep 2010
thanks for the offer ICU, but I don't mind doing a bit of work by hand. Mine are heavier and rougher, but it's satisfying to do it yourself...
I'll remake these, but they actually came out nice.... (ignore the salt build-up on the bottom and the crappy paint-job, these were banged out in 20 minutes.)
BobaFett1138 is offline Find More Posts by BobaFett1138
Old Jan 22, 2012, 01:10 AM
snjbird is offline
Find More Posts by snjbird
3D... the only way to fly!
snjbird's Avatar
Kissimmee
Joined Apr 2010
Boba,
What are they?
And where do you get them?
snjbird is offline Find More Posts by snjbird
Old Jan 22, 2012, 04:11 AM
RemE is online now
Find More Posts by RemE
Tweaker
RemE's Avatar
Corona Del Mar
Joined Sep 2005
He designed them in CAD and "printed" them on a 3D printer, pretty amazing!
RemE is online now Find More Posts by RemE
Old Jan 22, 2012, 08:30 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Originally Posted by snjbird View Post
What are they?
Click on his user's name (ICU)and check out his blog.
There is a rather strong hint right under his user's name.
http://www.rcgroups.com/forums/member.php?u=148991
Charles
Old Jan 22, 2012, 11:20 AM
Dr.Crashenburn is offline
Find More Posts by Dr.Crashenburn
fly-crash-fix
UK, Powys, Newtown
Joined Jan 2010
y harness...
Hi all, i just ordered a new beast and have a question.
I have loads of batts from my t-28 so was thinking would it be possible to hardwire two female batt connectors to the wires from the beast, getting rid of the connector plus saving a bit of weight?
Sorry to bring up an old topic but i could do with a yes or no.
Thanks.
Dr.Crashenburn is offline Find More Posts by Dr.Crashenburn
Old Jan 22, 2012, 11:34 AM
Gary Hoorn is offline
Find More Posts by Gary Hoorn
Chesapeake Bay RC Club
Gary Hoorn's Avatar
USA, MD, Annapolis
Joined Feb 2005
Dr.Crashenburn,
Has been done many times already. If those T28 batteries are not at least 180mah you can expect short flight times with the B3D...
Gary
Gary Hoorn is offline Find More Posts by Gary Hoorn
Old Jan 22, 2012, 11:47 AM
fly-crash-fix
UK, Powys, Newtown
Joined Jan 2010
Thanks Gary got mostly 160's but at least i'll be up and running ,well ,flying.
Old Jan 22, 2012, 11:52 AM
Joined Jul 2009
Thanks.
It depends upon which UM cells you're using. Most of them are no where near good enough for this plane. They will be severely overloaded, due to the much higher current. You may lose 50% or more in power, and you may hit LVC early into the flight, due to severe voltage sag. Or, you may overheat the cells to the point where they catch fire. Definitely a bad idea. Unless your UM cells happen to be Hyperion 160s. They will handle the current, but performance will still be way down as compared to a quality 180 mAh or higher 2s pack. BTW - RC Connectors makes a low-loss series harness for the UM cells that weighs just under 0.5g. It's only down 2% in power as compared to a 2s pack made from the same cells: http://www.rc-connectors.com/index.p...roducts_id=251
See RCBabbel for plug & play 2s packs that allow this plane to perform at its best: http://www.rcgroups.com/forums/member.php?u=54990
Joel
Old Jan 22, 2012, 03:11 PM
fly-crash-fix
UK, Powys, Newtown
Joined Jan 2010
Thanks i`ll take it steady and see how she goes - better start saving for some hyp 180`s then
Discussion ParkZone Ultra Micro T-28!!! THE Owners Thread!!!! RM_Sparks Micro Ready-to-Fly 10476 Dec 12, 2015 09:58 AM
Official Parkzone P-51 Owners Thread - Part 2 monitor Parkflyers 2602 Jun 15, 2014 05:51 PM
Discussion UM beast, Now your talking qman Micro Ready-to-Fly 102 Dec 22, 2010 11:39 AM
Discussion The first OFFICIAL Parkzone Sukhoi SU-26XP BNF by ParkZone Owners thread skyjet Micro Ready-to-Fly 2 Mar 19, 2010 04:00 PM
Official Parkzone P-51 Owners Thread monitor Parkflyers 913 Oct 04, 2005 10:02 PM
