Old Jan 18, 2012, 07:46 PM
electricrc68 is offline
Find More Posts by electricrc68
The Sweet Aroma of Fuel
electricrc68's Avatar
United States, PA, Downingtown
Joined May 2011
Originally Posted by Endlesslag View Post
I mean don't take them for granted, and do make sure to double check the charge settings, but they probably wont catch fire, maybe smoke a bit at absolute worst.
On a different note it might be worth trying to find a parallel charging cable or board for these batteries, then you can charge a few of them at once.
yeah i know not to take them for granted. im not sure if i can find a parallel charging cable that uses a XH style cable.
electricrc68 is offline Find More Posts by electricrc68
Old Jan 18, 2012, 07:49 PM
Endlesslag is offline
Find More Posts by Endlesslag
Fly it like you STOL it!
Endlesslag's Avatar
United States, FL, Daytona Beach
Joined Jan 2011
Found one..only two, but he makes one with four with the balance taps only
http://www.rc-connectors.com/index.p...roducts_id=263
Endlesslag is offline Find More Posts by Endlesslag
Old Jan 18, 2012, 07:55 PM
Joined May 2011
cool thanks! the e-flite one and the above one should both work with the AC6 with no problems right?
Old Jan 18, 2012, 07:56 PM
Endlesslag's Avatar
Joined Jan 2011
Yep. Either/or. If you are willing to do a bit of soldering or wiring you could make a monster parallel cable, but 2 or 3 should be more than enough for most days, especially if you get batteries chargable at 5c.
Old Jan 18, 2012, 08:03 PM
erkq is online now
Find More Posts by erkq
United States, CA, Sebastopol
Joined Dec 2010
This is what you want!
http://www.progressiverc.com/paralle...beast-umx.html
erkq is online now Find More Posts by erkq
Old Jan 18, 2012, 08:04 PM
Joined May 2011
okay thanks. i also saw this cable where it looks like it has two connections for 1s lipos. would it make a difference if i used a true 2s lipo over 2 1s lipos?http://www.horizonhobby.com/products...beast-EFLU4068
Old Jan 18, 2012, 08:09 PM
Endlesslag's Avatar
Joined Jan 2011
Originally Posted by erkq View Post
Ooooohhhh....preeeetttyy
Lol makes my hacked up cable look ugly
Old Jan 18, 2012, 08:22 PM
erkq is online now
Joined Dec 2010
Here's what to use. Lower resistance. Smaller. Lighter.
http://www.rc-connectors.com/index.p...roducts_id=251
Old Jan 18, 2012, 08:23 PM
gatorb8 is offline
Find More Posts by gatorb8
Registered Offender
gatorb8's Avatar
United States, FL, Gulf Breeze
Joined Apr 2008
yup! that's the one!
gatorb8 is offline Find More Posts by gatorb8
Old Jan 18, 2012, 08:30 PM
Joined May 2011
okay cool thanks. i may just get 2s lipos.
Old Jan 18, 2012, 08:38 PM
skarface is offline
Find More Posts by skarface
Fly low or fly home.
skarface's Avatar
United States, PA, Dover
Joined Aug 2011
depends what kind of single cell lipo you have.
http://www.horizonhobby.com/products...wg-EFLB1802S20
Thats a 2 cell 180mah 20c. If i get 2 of these (http://www.horizonhobby.com/products...-THP1601SL25UM) and put them on that cable it will be like a 2s 160mah 25C lipo. If you had 2 of these (http://www.horizonhobby.com/products...-THP2401SL25UM) It would be a 2s 240mah 25C lipo. But then if you add 2 of the 240's then you have to think about the extra weight and make sure your cg is still gonna be good.
Someone correct me if im wrong about the c rating still being 25C when they are on a y-harness
Now when i get my umx beast 3d (or if i do) i would put 2 1s 160mah 25c thunder power lipo's on it because it is 20 less mah than the 180mah but its 5C more. Plus i already have 2 160mah thunder power's.
Also im sure some people use 2 190mah mini aviations
skarface is offline Find More Posts by skarface
Old Jan 18, 2012, 08:45 PM
Joined May 2011
okay cool thanks. yeah i am thinking about it. right now i may just get a 2s lipo, but i have so many 1s lipos that it may just be better to go with that route....of course i need to make sure that it will work in the other UMX planes.
Old Jan 18, 2012, 09:00 PM
tracknoob is offline
Find More Posts by tracknoob
Diverted by planks
tracknoob's Avatar
South Florida
Joined Dec 2010
It is indeed a sweet piece of gear. Here I am doing four Miniaviation 210s at a time, with room left for two more!
tracknoob is offline Find More Posts by tracknoob
Old Jan 18, 2012, 09:42 PM
RealGambler is offline
Find More Posts by RealGambler
Way to many airplanes!
Canada, QC
Joined Oct 2009
I think I showed the first ever UMX parallel adapter here:
Now, I use PCBs.... Assembly is much faster. You can usually get them made in speciality places, but if you check with colleges and universities, you may get lucky and have them made for VERY cheap. I find it's much better overall.
Since there's two ports on my recently aquired CellPro charger, I can now charge 16 batteries at once!
Beat ya!
RealGambler is offline Find More Posts by RealGambler
Old Jan 18, 2012, 09:51 PM
turboparker is online now
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
El,
In this app, the HH series harness is approximately 10% down on thrust as compared to a 2s pack. Glenn's (RC Connectors) harness is only down 2%. The HH harness weighs 1.2g, while Glenn's weighs 0.56g.
A lightweight, high-quality 2s pack will provide the best performance, but Glenn's harness is very close in terms of thrust. The noticeable performance hit when running a pair of 1s cells on Glenn's harness is the extra weight. Aside from the harness itself, consider the additional connectors, wire, and shrink-wrap.
That said - Hyperions are the only single cells that are really worth using on the harness.
Joel
turboparker is online now Find More Posts by turboparker
Discussion ParkZone Ultra Micro T-28!!! THE Owners Thread!!!! RM_Sparks Micro Ready-to-Fly 10699 May 26, 2016 06:46 PM
Official Parkzone P-51 Owners Thread - Part 2 monitor Parkflyers 2602 Jun 15, 2014 04:51 PM
Discussion UM beast, Now your talking qman Micro Ready-to-Fly 102 Dec 22, 2010 10:39 AM
Discussion The first OFFICIAL Parkzone Sukhoi SU-26XP BNF by ParkZone Owners thread skyjet Micro Ready-to-Fly 2 Mar 19, 2010 03:00 PM
Official Parkzone P-51 Owners Thread monitor Parkflyers 913 Oct 04, 2005 09:02 PM
