Old Jan 18, 2012, 06:53 AM
ChuckTseeker is online now
Find More Posts by ChuckTseeker
ChuckTseeker's Avatar
Adelaide Plains Australia
Joined Dec 2007
for those interested the Hyper Taxi maiden video is up
cheers chuck
http://www.rcgroups.com/forums/showt...7#post20459850
ChuckTseeker is online now Find More Posts by ChuckTseeker
Old Jan 18, 2012, 07:01 AM
d2tw4all is offline
Find More Posts by d2tw4all
United States, RI, Smithfield
Joined Dec 2011
Originally Posted by turboparker View Post
Tom,
It will work, but it won't be fun to fly at all. In fact, it may not even be safe - if you're talking about the toy-grade transmitters that come with the Champ, etc. First off, the toy transmitters are not full-range. The factory specs them for 300-foot range. They were never intended to be used with planes that fly as fast or as far away as these planes fly. Get more than a few hundred feet away, and all bets are off. At these speeds, it takes less than 6 seconds to cover 300 feet. Secondly, the resolution of the toy transmitters is very poor. The plane supports 1024-step resolution, but the toy transmitters have much lower resolution - which means that the control movements will be much coarser than they would be with, say, a DX5e or DX6i. With a responsive plane, coarse control movements are a bad thing. I highly recommend reconsidering your choice of transmitter.
Joel
Guys, totally get that a better tx is the ultimate way to go, I have a dx6i myself. In this case, my grandmother wants to surprise my uncle, who flies big scale RC, with a B3d, but he doesn't have ANY DSMX tech, everything he has is old school FM, nor does he have any lipo charging, so the beast 3d plus battery, plus charger, is already getting more than she wants to spend, let alone layering on a more expensive tx. I figured I'd give him the cheapie just so he can try it out and hopefully it will compel him to upgrade his tx to a dsmx module, or get a spektrum box. Ultimately if it's not going to work she just won't get him the plane. So given more back story, what do you think?
Tom
d2tw4all is offline Find More Posts by d2tw4all
Old Jan 18, 2012, 07:29 AM
storm2k5 is offline
Find More Posts by storm2k5
Joined Nov 2011
Originally Posted by airpower View Post
Storm, when in dual ail the gyro only operates the right aileron.
Oh yes, I know. What I'd like to know is if it compensates for the loss of control surface or if you end up getting just half the corrections.
storm2k5 is offline Find More Posts by storm2k5
Old Jan 18, 2012, 07:49 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
It should move the correcting (gyro controlled) control surface as much as required (up to servo trael limits) to correct the planes attitude.
I would try it on the ground first. Remove the prop for safety or use Throttle lock if you have it programmed.. Most planes can be flown by an experienced pilot with one alieron not working at all .
Charles
Old Jan 18, 2012, 07:51 AM
gatorb8 is online now
Find More Posts by gatorb8
Registered Offender
gatorb8's Avatar
United States, FL, Gulf Breeze
Joined Apr 2008
why not try DX4? it is full range and has expo
I've seen those given away free cause they were same price for RTF on mcpx for a while
I set mine up as a buddy box to my DX8 but haven't flown it yet
gatorb8 is online now Find More Posts by gatorb8
Old Jan 18, 2012, 08:31 AM
storm2k5 is offline
Joined Nov 2011
Charles
Yes I know (I even had a plane that only had one aileron by design )
I tested this on the ground and it seemed as if the control surface corrects the same amount as it would with 2 surfaces, so in other words I believe it will correct less (pretty much like you would half the gyro gain)
Old Jan 18, 2012, 02:27 PM
electricrc68 is offline
Find More Posts by electricrc68
The Sweet Aroma of Fuel
electricrc68's Avatar
United States, PA, Downingtown
Joined May 2011
Originally Posted by RCBABBEL View Post
ele,
Been using 2) of these inexpensive units almost daily, for over two years now.
http://www.hobbyking.com/hobbyking/s...idproduct=7028
rc
okay cool thanks. how about the thunder ac6 from hobbypartz? it comes with an AC power supply.
http://www.hobbypartz.com/thac6smbachw.html
although, the only thing im worried about most is the connector. im still trying to look for an adapter that i can use with one of the cheaper chargers. i would also be fine with just the regular celectra 2s charger + AC adapter since im only going to be in the micro scene of rc.
electricrc68 is offline Find More Posts by electricrc68
Old Jan 18, 2012, 02:55 PM
skarface is offline
Find More Posts by skarface
Fly low or fly home.
skarface's Avatar
United States, PA, Dover
Joined Aug 2011
or dx5
skarface is offline Find More Posts by skarface
Old Jan 18, 2012, 02:58 PM
turboparker is online now
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
It appears that the AC6 uses 'XH'-style balance connectors. Find out for sure - then talk to Glenn at RC-Connectors.com. He'll make a charge-adapter harness to match.
Alternatively, HH sells a charge-adapter harness that fits 'XH'-style balance-boards: http://www.horizonhobby.com/products...-efl-EFLA700UM
The #1 cause of early LiPo failure is over-discharge. With the aftermarket charger, you can quit guessing when your packs are discharged to 80%. You will be able to measure how many mAh it takes to recharge, and then set your flight-timer so that you always land at or before the 80% discharge point. This will maximize the performance & lifespan of your packs, which means the charger will pay for itself in a short period of time if you fly regularly. Also - modern, high-quality LiPo packs can be charged at 5c or higher without any reduction in performance or lifespan. At 5c, it only takes 12-15 minutes to recharge from the 80% discharge point. The stock charger only charges a 180 mAh pack at 1c - which takes nearly an hour. Charging a 240 pack with the stock charger takes considerably longer.
Joel
turboparker is online now Find More Posts by turboparker
Old Jan 18, 2012, 03:56 PM
kuczy is offline
Find More Posts by kuczy
The Earth got in the way!
kuczy's Avatar
United States, OH, Canal Winchester
Joined Feb 2007
I'm selling my V1 if anybody is interested.
Listed here
http://www.rcgroups.com/forums/showthread.php?t=1576874
kuczy is offline Find More Posts by kuczy
Old Jan 18, 2012, 04:05 PM
Joined May 2011
Joel
okay cool thanks. so that adapter should work with the AC6? thanks for the lipo info too.....but im still a little worried about using these 2s packs. i have only used 1s packs before and im worried about messing something up (incorrect charge setting, incorrect storage, etc.) and causing a fire.
Old Jan 18, 2012, 04:43 PM
Southern Pride
Any charger that uses standard banana outputs and JST-XH balancing connection will work with
http://www.progressiverc.com/jst-ph-...beast-umx.html
Set charger to 2S (7.4V) and proper charge rate.
Charles
Old Jan 18, 2012, 05:16 PM
Endlesslag is offline
Find More Posts by Endlesslag
Fly it like you STOL it!
Endlesslag's Avatar
United States, FL, Orlando
Joined Jan 2011
It'll be fine. these are still tiny packs. worry about a 6s 5000, not a 2s 240
Endlesslag is offline Find More Posts by Endlesslag
Old Jan 18, 2012, 06:02 PM
Joined May 2011
okay thanks. good to know that they aren't too big. theres no way that im ever going to be going near a 6s pack.
Old Jan 18, 2012, 07:16 PM
Endlesslag's Avatar
Joined Jan 2011
I mean don't take them for granted, and do make sure to double check the charge settings, but they probably wont catch fire, maybe smoke a bit at absolute worst.
On a different note it might be worth trying to find a parallel charging cable or board for these batteries, then you can charge a few of them at once.
Discussion ParkZone Ultra Micro T-28!!! THE Owners Thread!!!! RM_Sparks Micro Ready-to-Fly 10717 Today 02:25 AM
Official Parkzone P-51 Owners Thread - Part 2 monitor Parkflyers 2602 Jun 15, 2014 04:51 PM
Discussion UM beast, Now your talking qman Micro Ready-to-Fly 102 Dec 22, 2010 10:39 AM
Discussion The first OFFICIAL Parkzone Sukhoi SU-26XP BNF by ParkZone Owners thread skyjet Micro Ready-to-Fly 2 Mar 19, 2010 03:00 PM
Official Parkzone P-51 Owners Thread monitor Parkflyers 913 Oct 04, 2005 09:02 PM
