Old Jan 06, 2012, 08:20 PM
snjbird is offline
Find More Posts by snjbird
3D... the only way to fly!
snjbird's Avatar
Kissimmee
Joined Apr 2010
I had a aileron failure on mine, it locked up and caused a crash, it was around the 15th flight?
Have any of you guys been moving the servo wires to get more throw out of the ailerons, and elevator?
snjbird is offline Find More Posts by snjbird
Old Jan 06, 2012, 08:22 PM
freesex is offline
Find More Posts by freesex
freesex's Avatar
Joined Aug 2011
your guys didn't get it, is wasn't because of broken elevator, my elevator was intact, and I ready reforced it with CF rods.
freesex is offline Find More Posts by freesex
Old Jan 06, 2012, 08:24 PM
tracknoob is offline
Find More Posts by tracknoob
Diverted by planks
tracknoob's Avatar
South Florida
Joined Dec 2010
Servo it must be then... those gears can strip or come loose, crud can get on the open resistive strips, the metal fingers can lose contact...I've even had the little retaining nut come loose...
tracknoob is offline Find More Posts by tracknoob
freesex is offline
freesex's Avatar
Joined Aug 2011
your guys didn't get it, it wasn't becuase of broken elevator, My elevator was physically intact. actually I just did the CF rod enforcement yesterday.
pugsam is offline
Find More Posts by pugsam
LiPo-Sucker & Airframe EMT
pugsam's Avatar
Charlottesville, Virginia, USA
Joined Aug 2010
At the same time I did the elevator reinforcement, I did a very, very radical mod which had no physical effect, but made me feel good!
I used a red Sharpie to touch-up the control horn push-throughs on top of the lower wing.
Now, they're red -- instead of plastic white......pretty closely matching the rest of the wing!
I took a photo. But it doesn't show anything! The horn push-throughs are now almost invisible!
pugsam is offline Find More Posts by pugsam
Old Jan 06, 2012, 08:25 PM
Diverted by planks
tracknoob's Avatar
South Florida
Joined Dec 2010
heh heh
I did the same thing, but my red Sharpie wasn't a perfect match... still blended well, though.
Old Jan 06, 2012, 08:26 PM
airpower is offline
Find More Posts by airpower
Have fun
airpower's Avatar
United States, CA, Mission Viejo
Joined May 2007
I didn't see a need to increase aileron throw, it rolled pretty fast but was still smooth.
FS, look at your control horn, sometimes they kinda crease the area around it and get loose making a lot of slop in the control. Maybe your cf became loose, it's worth checking. The heat shrink on the control might've come loose, a million things.
airpower is offline Find More Posts by airpower
Old Jan 06, 2012, 08:29 PM
livonia bob is offline
Find More Posts by livonia bob
Heli collector
livonia bob's Avatar
United States, MI, Livonia
Joined Apr 2009
This was a problem with the V1's so I'm not surprised that it's also a problem with the V2's..
livonia bob is offline Find More Posts by livonia bob
Old Jan 06, 2012, 08:30 PM
Diverted by planks
tracknoob's Avatar
South Florida
Joined Dec 2010
Forgot about that one! On my UM T28, had a loose rod into that sleeve on the rod, right from the factory, and sometimes it would stay put but other times it would slip. Drove me crazy until I saw what it was.
Old Jan 06, 2012, 08:37 PM
RealGambler is offline
Find More Posts by RealGambler
Way to many airplanes!
Canada, QC
Joined Oct 2009
C'mon, give me a break here! I simply adjusted the rudder so it's perfectly straight. It was on my V1 Beast, so why shouldn't it be straight on the V2???? It's done already, so I'm leaving it straight for now. Will see if I like it or not after. There was a serious going left angle on mine for sure (but not anymore.... )
Now, about that elevator needing some "help": That's another thing that was ok on the V1 Beast too. In fact, that's about the only area that still look brand new on my old Beast So that would be the gyro vibration that would weaken the elevator? Not doing anything about it for now, but will watch it for sure!
This bring my last point. On my original Beast V1, the only mod that I think was mandatory, was a little carbon fiber rod on the lower wing, going straight through the fuselage. (lower wing was not that crash resistant). I'm very tempted to do it right away on my new Beast 3D. Nobody had a the lower wing ripped on them already on the V2?
RealGambler is offline Find More Posts by RealGambler
Old Jan 06, 2012, 08:44 PM
kjkimball is offline
Find More Posts by kjkimball
Custom airplanes and boats
Zellwood, FL
Joined Aug 2010
We have hundreds of flights on V1 and V2 Beasts and have made zero airframe mods. We fly off concrete and off grass. Just about all landings on grass.
kjkimball is offline Find More Posts by kjkimball
Old Jan 06, 2012, 08:46 PM
pugsam is offline
pugsam's Avatar
Joined Aug 2010
I think that the elevator might LOOK (and be) perfectly intact when you examine it on the ground, but in the air it fails to provide full authority -- because the connecting strip between the elevator's left and right sides is so narrow.
After tracknoob posted a few days ago, I check my Beast's elevator. It looked absolutely fine. However, try holding the left side of the elevator (where the horn is), and at the same time gently wiggle the right side.
If yours is like mine was, there's way too much flex! That's what the CF reinforcement can fix......If......it stays secure and doesn't come loose.
Old Jan 06, 2012, 08:49 PM
airpower is offline
Have fun
airpower's Avatar
Joined May 2007
Had a lower wing rip on my v2, it was a bad crash. Showing off to the crew doing fast slow rolls at head level, gave rudder wrong direction. Repaired with glue, as good as ever(I also bought another b3D, just in case). I mean, I would do it if you knew you were gonna crash a lot. I used to crash my ums all the time until I started treating them like real planes, instead of like aero aces!
Old Jan 06, 2012, 09:14 PM
Canada, QC
Joined Oct 2009
Can you define "a lot"? The way I fly, crashing is not a possibility, it's simply a question of time! Will do the maiden and a few flights without it, but somehow, I think I'll add one sooner or later.
P.S.: I gave back a little bit of left rudder. (about half of what was on my Beast originally). Two adjustements already, and not flown it once yet!
Old Jan 06, 2012, 09:25 PM
makg is offline
Find More Posts by makg
ISP Supervisor
makg's Avatar
United States, AK, Fairbanks
Joined Jan 2006
You need right rudder, not left.
makg is offline Find More Posts by makg
Discussion ParkZone Ultra Micro T-28!!! THE Owners Thread!!!! RM_Sparks Micro Ready-to-Fly 10710 Yesterday 08:25 AM
Official Parkzone P-51 Owners Thread - Part 2 monitor Parkflyers 2602 Jun 15, 2014 04:51 PM
Discussion UM beast, Now your talking qman Micro Ready-to-Fly 102 Dec 22, 2010 10:39 AM
Discussion The first OFFICIAL Parkzone Sukhoi SU-26XP BNF by ParkZone Owners thread skyjet Micro Ready-to-Fly 2 Mar 19, 2010 03:00 PM
Official Parkzone P-51 Owners Thread monitor Parkflyers 913 Oct 04, 2005 09:02 PM
