Old Sep 20, 2011, 09:33 AM
slo-fly is offline
Find More Posts by slo-fly
certified crash instructor
Scottsdale Arizona
Joined Dec 2009
The beast kind of looks like a box kite when it's flying, tough to get orientation down at first but you get used to it.
slo-fly is offline Find More Posts by slo-fly
Old Sep 20, 2011, 09:39 AM
everynameistaken is offline
Find More Posts by everynameistaken
everynameistaken's Avatar
United States, RI
Joined Feb 2006
Thanks guys. I just wanted to make sure it was not just me. My eyes are not what they used to be. When I did lose orientation with the Beast I'd get it back within a second or so but sometimes a second is too much. I was just amazed though that it kept happening. As turnerm mentioned I was flying near dusk. Plus not setting the expo probably hurt too. For beginners I thought. Not so with the beast.
Tony
everynameistaken is offline Find More Posts by everynameistaken
Old Sep 20, 2011, 09:48 AM
United States, RI
Joined Feb 2006
Originally Posted by binaryclock View Post
Tony:
Also, try not to orient the plane coming directly at your or directly away from you - since the profile of the beast is so thin, it's easy to lose orientation on these vectors.
Also, I do agree it's a "biplane" thing. If you haven't flown biplanes before, the first time is going to be a challenge for your eyes to pick out the proper orientation.
Hope this helps - I hope that made sense to someone out there
Ryan
Ryan. That might be a problem for me because thats how I primarily fly - towards me or away from me. I have flown homemade biplanes before but they had lots of yellow, white or pink in them with some contrasting dark colors. Orientation wise the biplanes always seemed the hardest for me followed by mid-wingers.
Tony
Old Sep 20, 2011, 10:06 AM
telos81 is offline
Find More Posts by telos81
telos81's Avatar
United States, CT, Glastonbury Center
Joined May 2007
some people have mentioned painting the bottom of their bottom wing white or yellow ... i haven't seen any pics of that yet though
telos81 is offline Find More Posts by telos81
Old Sep 20, 2011, 10:33 AM
erkq is online now
Find More Posts by erkq
United States, CA, Sebastopol
Joined Dec 2010
Tony
Yup... I have trouble at dusk with trees as the background. You get to where you have faith in the orientation based on what it was the LAST time you knew for sure and what you've done in the meantime. That, and if the plane is still flying in the direction you intend, you're usually good. But it's that "usually" part that causes me to break out my Sbach when the sun gets low.
BTW, I find my eyes are tack-sharp when flying against the sky or some other high contrast situation. Guys at the club are amazed at how far out I can maintain orientation with these little things. So it's not an eye problem.
erkq is online now Find More Posts by erkq
Old Sep 20, 2011, 10:34 AM
slo-fly is offline
Scottsdale Arizona
Joined Dec 2009
I know somebody was talking about finding a stronger prop adaptor for the beast, this will also work for the sbach as well, ships from UK. I prefer the stock adaptor though, I like a breaking point somewhere. http://www.ebay.com/itm/E-Flite-UMX-...item3cbc27b757
Old Sep 20, 2011, 10:47 AM
Mattydiah is offline
Find More Posts by Mattydiah
Defender of the Aerobird!
Mattydiah's Avatar
Milwaukee, WI
Joined Dec 2002
I generally orient, at least up and down based on the fact that the top wing is not attached to the fuse, and the bottom wing is
Eh, that just moves the point of failure back to the firewall, or the motor shaft.
Mattydiah is offline Find More Posts by Mattydiah
Old Sep 20, 2011, 10:48 AM
erkq is online now
Joined Dec 2010
Wouldn't putting that on instead of the plastic one add to the nose-heavy problems of the Sbach? I find my Sbach balances perfectly with the battery all the way back as it is.
EDIT: Oops... wrong thread. Just saw the Sbach pic in the eBay listing.
Old Sep 20, 2011, 10:52 AM
Mattydiah's Avatar
Milwaukee, WI
Joined Dec 2002
That will probably also act as a flywheel, making the prop slower to spin up and down. Maybe not by much, but it will affect it.
Old Sep 20, 2011, 10:59 AM
binaryclock is offline
Find More Posts by binaryclock
I hate winter!
binaryclock's Avatar
Canada, ON, Barrie
Joined Jul 2011
The prop adapter ICU designed (a forum member) was still made out of a nylon or plastic type material. It probably could still break on a major impact (which is good.) The problem with the stock adapter is that it breaks way too easy - on light impacts sometimes.
The allow adapter that you have listed is insanely strong. on a major impact, instead of breaking a small $4 part, you'll break the firewall, motor shaft, prop, fuselage, etc. And to boot, your adapter will probably be bent and unusable.
People in the RC Car/Buggy/Truggy world have gone through this. Allow is nice to look at, but is heavier and when there is an impact it bends instead of breaks. Try bending a weirdly shared allow part back in to proper form.
binaryclock is offline Find More Posts by binaryclock
Old Sep 20, 2011, 11:09 AM
maukabud is offline
Find More Posts by maukabud
HELP I AM BEING SET UP!!
maukabud's Avatar
United States, OR, Deschutes
Joined Jul 2009
Tony
There are nav light kits available to help w/ dusk and/or dawn and/or low contrast visual conditions....the standard red/port green/starboard white/tail would help immensely in low light conditions with this ship...it's been talked about a few pages back, with links.
~Bud
maukabud is offline Find More Posts by maukabud
Old Sep 20, 2011, 11:22 AM
erkq is online now
Joined Dec 2010
~Bud
Yes... and they're reasonably priced. Been thinking... been thinking... haven't pulled the trigger yet though... I have all 3 BL UM's but prolly the Beast would benefit the most.
Old Sep 20, 2011, 11:35 AM
flitelab is offline
Find More Posts by flitelab
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
Would be nice if they supported an on/off or dimming control as well but from what I gather they currently are always on.
flitelab is offline Find More Posts by flitelab
Site Sponsor
Old Sep 20, 2011, 11:44 AM
erkq is online now
Joined Dec 2010
Apparently they don't draw much. I haven't been able to get a real answer about power draw as he confuses mA with mAh, but I think the draw is negligible to the point of being un-noticeable, like 10mAh out of the pack during a standard 6 min flight.
Are you thinking there are times, appearance-wise, you'd just like to have them off?
Old Sep 20, 2011, 11:47 AM
flitelab is offline
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
Ya I'd just like the option to turn them off at times. Could always add one of these I suppose - http://www.hansenhobbies.com/product...dacc/ers/pers/ Too bad the light kit doesn't have that as an option.
Site Sponsor
Discussion ParkZone Ultra Micro T-28!!! THE Owners Thread!!!! RM_Sparks Micro Ready-to-Fly 10739 Jul 18, 2016 12:27 PM
Official Parkzone P-51 Owners Thread - Part 2 monitor Parkflyers 2602 Jun 15, 2014 04:51 PM
Discussion UM beast, Now your talking qman Micro Ready-to-Fly 102 Dec 22, 2010 10:39 AM
Discussion The first OFFICIAL Parkzone Sukhoi SU-26XP BNF by ParkZone Owners thread skyjet Micro Ready-to-Fly 2 Mar 19, 2010 03:00 PM
Official Parkzone P-51 Owners Thread monitor Parkflyers 913 Oct 04, 2005 09:02 PM
