Old Aug 25, 2011, 12:52 AM
maukabud is offline
Find More Posts by maukabud
HELP I AM BEING SET UP!!
maukabud's Avatar
United States, OR, Deschutes
Joined Jul 2009
lol
maukabud is offline Find More Posts by maukabud
Old Aug 25, 2011, 01:08 AM
jabsten is offline
Find More Posts by jabsten
Can't get enough
jabsten's Avatar
United States, WA, Puyallup
Joined May 2010
Originally Posted by RCBABBEL View Post
ep,
I used a slightly longer prop screw to be safe.
Old sub-micro servo mounting screw works excellent.
My Beast/5043 prop mod here:
http://www.rcgroups.com/forums/showp...&postcount=327
rc
Where did you get that lucky screw lol... I would like a couple.. I ended up putting the 5043 on the sbach with stock screw and adapter, and seemed to fit fine. Probably didn't screw in all the way I imagine, but haven't had problems yet and it seems tight!
J
jabsten is offline Find More Posts by jabsten
Old Aug 25, 2011, 05:56 AM
MJF is offline
MJF
Find More Posts by MJF
MJF
Waiting Fer Da SEFF
MJF's Avatar
United States, GA, Perry
Joined Jul 2010
Originally Posted by telos81 View Post
The rudder often gets jammed after a crash, if the control horn slips free of the bent wire it's attached too ... That's not servo lock, it's just from the force of the crash. If it "popped" back into center, that's probably what you saw as rudder lock (unless, of course, you are positive rudder lock caused the crash)
I positive......
MJF is offline Find More Posts by MJF
Latest blog entry: eflite ultimate 20-300
Old Aug 25, 2011, 07:40 AM
billyjim is offline
Find More Posts by billyjim
billyjim
Cullman, AL
Joined Jun 2007
Would the Beast's BL swing a 6" prop?
I build and fly only "floaters." With that in mind I've been thinking of a scratchbuilt styrofoam bipe, maybe about 25" wingspan, 45 or so grams AUW. I'm wondering if a 6" prop would be too much for the BL. (I plan to keep the amp flow within the FET spec of 2 amps -- by placing a bar across the throttle gimbel about the 50% position - to keep if from moving higher.) Whatcha' think?
Bill
billyjim is offline Find More Posts by billyjim
Old Aug 25, 2011, 07:48 AM
binaryclock is offline
Find More Posts by binaryclock
I hate winter!
binaryclock's Avatar
Canada, ON, Barrie
Joined Jul 2011
Ugh so after rebuilding my Beast after the elevator issue I had the left aileron isn't giving as much up throw as my right aileron. They both give the correct amount of down throw, but up throw is off by a mm or two.
Just a refresher if you missed my crash post a few pages back - the right section of the elevator got creased and bent up in flight and caused the beast to loop and climb and I had to bring her down hard before she went in to some houses. I ripped the left wing off, the right servo was ripped off, the prop was broken, and the front of the fuse was slightly dented with a 1 inch hairline crack that didn't go too far through the foam - just on the surface really.
I've checked the throws on the servos and it seems the left servo is not completely making it to the end of the servo for whatever reason. It doesn't seem that there is any binding. The ailerons can travel freely and not get stuck on the wing, the servo seems smooth and straight. The CF rod joining the ailerons seems okay. I really can't figure it out. It looks like the top aileron throws a bit less than the bottom as well, and the top left aileron throws at least 1mm to 2mm less than the right top aileron.
I flew her today and it wasn't completely calm so it was being bounced around a tad (maybe 5km/h winds.) Obviously the wings took some serious damage so I know with the glue and rebuilding her, the CG isn't completely right. But she did fly pretty nicely after trimming her out - still, not as smooth like pre-crash though but I still have to try in calm conditions.
Anyways, anyone have any idea how to remedy the top aileron throws? At rest they both are the same level, it's just when turning. When the flaps go up, the top ailerons are at different heights. I didn't feel this affected me when flying low and slow but then again, I didn't let go of the stick too much because it wasn't completely calm.
binaryclock is offline Find More Posts by binaryclock
Old Aug 25, 2011, 07:52 AM
flitelab is offline
Find More Posts by flitelab
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
What Tx are you using? Perhaps check/set the endpoints there.
flitelab is offline Find More Posts by flitelab
Site Sponsor
Old Aug 25, 2011, 08:00 AM
I hate winter!
Canada, ON, Barrie
Joined Jul 2011
Thank you for your reply sir. I am using the DX6i. I looked around there but didn't find anything concerning end points. I did find throws and the such, but I could of overlooked something.
EDIT - Okay just checked the manual and the end point adjustments are the travel adjustments. I did play around with those and found that my aileron adjustment moves one side, and the flaps adjustment moves the other. Should I be adjusting the side that is not moving as far to over 100% or should I adjust the side that is moving too far under 100%?
Thanks for the advice.
Old Aug 25, 2011, 08:11 AM
flitelab is offline
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
As long as you don't push the servo beyond 100% it should be fine either way. You just don't want to push these micro servos beyond 100% as can burn them out when they bind at the end.
Site Sponsor
Old Aug 25, 2011, 08:50 AM
epoweredrc is offline
Find More Posts by epoweredrc
27 yrs. of Aircraft flying.
epoweredrc's Avatar
United States, GA, Tallapoosa
Originally Posted by maukabud View Post
Aha! The GWS 8X4 has a much thicker hub, different ID, etc. (I know 'coz I have some for my larger craft) Therein lies the culprit.
Bud, detective Bud
Oh alright then. Kinda thought that. might have to order some next pay day
ep,
rc
I was trying to find a longer screw but didn't find one with the same threads don't want to mess up he adapter. i will get a 2nd when i order other things.
man i run into you always int he micro threads
epoweredrc is offline Find More Posts by epoweredrc
Old Aug 25, 2011, 09:57 AM
SBOTI74 is offline
Find More Posts by SBOTI74
I fly em', there for I am.
SBOTI74's Avatar
United States, CA, Tehachapi
Joined Feb 2009
I would also check to see if maybe the aileron that isn't going up as much may have got the aileron connecting rod (One that goes from the top aileron to the botton aileron) may have got shoved up too far into the holder on the upper aileron... Just a thought seeing it was damaged, could happen..
SBOTI74 is offline Find More Posts by SBOTI74
Old Aug 25, 2011, 10:19 AM
ICU is offline
ICU
Find More Posts by ICU
ICU
Check out my Shapeways Shop
ICU's Avatar
Dallas,Tx.
Joined Apr 2007
What material are they made out of?
The material these are made out of is close to Nylon12. While it's not exactly Nylon12 it has all the same basic properties. I weighed them last night (I'll get some pics and testing notes up tonight) and they only weigh 0.1g more than the OEM prop mount and feel indestructible. But only time, and testing will tell.
Originally Posted by SBOTI74 View Post
No worries, just thought I would offer. Besides, I like the fact you're trying to help someone who's down/grounded. Hope the testing goes good.
SBOTI
Thanks.
I installed one each on my Beast and Sbach last night. All seemed to go well, so far, and I felt zero vibrations when running the motor up with and without a prop.
ICU is offline Find More Posts by ICU
Old Aug 25, 2011, 10:23 AM
SBOTI74 is offline
SBOTI74's Avatar
Joined Feb 2009
Great info and update! Crossing my fingers, I haven't broke any prop adapters yet but, I'm getting lower and lower..
So, this prop adapter, does it work on all three UMXs? The Beast, Sbach and Stryker? If so, what a great seller you will have! I know I would like to just have one as a spare so if any broke, I wouldn't be grounded..
Old Aug 25, 2011, 10:30 AM
nickimde is offline
Find More Posts by nickimde
Joined Jun 2011
Here are some pics of the servo covers I made using both ends of the packaging plastic from Trim nail product. It is the smallest type I could find and is raised in middle that clears the pushrods nicely. Only cost .99 at Walmart (http://www.walmart.com/ip/Trim-Nail-...-1-ct/10414565) and can make 2 from each package. Less than 4.99 for UM Stryker servo covers. Am using on Sbach, Beast and Corsair and dont seem to effect flight of airplanes at all. Just taped on so they can be removed for servo cleaning if I need to . Keeps little grass and rocks away from servo gears.
Nick
nickimde is offline Find More Posts by nickimde
Old Aug 25, 2011, 11:08 AM
turnerm is offline
Find More Posts by turnerm
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
Looks like Hurricane Irene is going to put a serious hamper on my flying this weekend! Winds are going to be very strong on Saturday and Sunday. Guess I better get it all out of my system tonight!!
On a more serious note - I pray that those along the coastal regions of North and South Carolina are spared from devestation. We've been here before and we'll be here at some point again - a small price to pay for being fortunate enough to live in such a beautiful area of the world.
turnerm is offline Find More Posts by turnerm
Old Aug 25, 2011, 11:15 AM
telos81 is offline
Find More Posts by telos81
telos81's Avatar
United States, CT, Glastonbury Center
Joined May 2007
we were in the Outer Banks just last week! (Duck) it was amazing! we want to make it an annual vacation now.
and i'm not sure i'll be able to fly all week very high winds and T-Storms today from the west, looks like it will be windy fri and sat too!
telos81 is offline Find More Posts by telos81
Discussion ParkZone Ultra Micro T-28!!! THE Owners Thread!!!! RM_Sparks Micro Ready-to-Fly 10763 Sep 13, 2016 07:08 AM
Official Parkzone P-51 Owners Thread - Part 2 monitor Parkflyers 2602 Jun 15, 2014 04:51 PM
Discussion UM beast, Now your talking qman Micro Ready-to-Fly 102 Dec 22, 2010 10:39 AM
Discussion The first OFFICIAL Parkzone Sukhoi SU-26XP BNF by ParkZone Owners thread skyjet Micro Ready-to-Fly 2 Mar 19, 2010 03:00 PM
Official Parkzone P-51 Owners Thread monitor Parkflyers 913 Oct 04, 2005 09:02 PM
