Old Aug 10, 2011, 06:46 PM
nickimde is offline
Find More Posts by nickimde
Joined Jun 2011
I always try to maiden all my planes in the same way.
1. Check all controls move in right directions and take a calm breath.
2. little to 0 wind.
3. big field even if I have to drive there and no airplane trees if possible !!!!!!
4. add throttle and as soon as clear of ground concentrate on wings level and get altitude.
5. after getting some altitude, pull back throttle to 1/2 or maybe a little more and start trimming.
6. fly around field at low/mid throttle and start lining up for where I want to land then when the line is good, less throttle and keep wing level then cut throttle to 0 just above ground.
If your really worried about trimming and flying sometimes a friend can move the trims for you while you concentrate on flying and figuring out what plane is doing (rolling left or right, climbing or diving). Just make sure you explain what trims do and is really a good friend .
nickimde is offline Find More Posts by nickimde
Old Aug 10, 2011, 07:03 PM
barnyardflyer is offline
Find More Posts by barnyardflyer
Experienced R/C Repairman
barnyardflyer's Avatar
Three Oaks, Michigan
Joined Sep 2003
After chipping the stock prop om my Beast, I decided to put on one of my GWS 5030 props instead of the spare in the box.
Question is, how does everyone hold the motor still while unscrewing the prop?
I can't really get my fingers in there to keep it from spinning, and I am afraid of damage to the motor if using pliers.
Also, what size screwdriver works best?
barnyardflyer is offline Find More Posts by barnyardflyer
Old Aug 10, 2011, 07:35 PM
turnerm is offline
Find More Posts by turnerm
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
I just pop the battery hatch off and put my index finger on top of the motor to hold it still.
turnerm is offline Find More Posts by turnerm
Old Aug 10, 2011, 07:41 PM
Joined Sep 2003
I tried that but I felt like I was crushing the plane and the screwdriver was just spinning without really gripping the screw head unless I put an extreme amount of force in both directions.
Old Aug 10, 2011, 07:48 PM
3dFlyer88 is offline
Find More Posts by 3dFlyer88
is it supposed to smoke??
3dFlyer88's Avatar
canada alberta outside edmonton
Joined Apr 2007
took my beast out for its first flight tonite and wow ami impressed. this is one of the best micros ive flown. Its really an all around performer. Now i just need more batteries
3dFlyer88 is offline Find More Posts by 3dFlyer88
Old Aug 10, 2011, 07:56 PM
binaryclock is offline
Find More Posts by binaryclock
I hate winter!
binaryclock's Avatar
Canada, ON, Barrie
Joined Jul 2011
Welcome to the beast club It sure is an awesome plane!
binaryclock is offline Find More Posts by binaryclock
Old Aug 10, 2011, 08:00 PM
telos81 is offline
Find More Posts by telos81
telos81's Avatar
United States, CT, Glastonbury Center
Joined May 2007
Do you know about the Y-connectors?
telos81 is offline Find More Posts by telos81
Old Aug 10, 2011, 08:05 PM
I hate winter!
Canada, ON, Barrie
Joined Jul 2011
Anyone know how well the turnigy 160mah batteries work with the Y connector? I have about 10 of them coming in the next few days, already landed in my country with customs now.
Old Aug 10, 2011, 08:10 PM
RealGambler is offline
Find More Posts by RealGambler
Way to many airplanes!
Canada, QC
Joined Oct 2009
Well, they will Work.... But life (cycles) will likely be reduced, flight time will be so-so, and performance will not be there. But you'll be able to cruise around and still have fun... But you will not be able to experience the awesome vertical, the superbe big loops, etc...
RealGambler is offline Find More Posts by RealGambler
Old Aug 10, 2011, 08:15 PM
aerosoardude is offline
Find More Posts by aerosoardude
Its not that windy...
United States, CA, PORTER RANCH
Joined May 2007
As far as the screwdriver goes, I don't really know about sizes, but when you're looking at your set of micro screwdrivers, find the one that has the thickest, smallest point, so it has a better bite to it. If you use the ones that are more pointy, they will just keep slipping off.
I don't think you have to grip the motor that hard to overcome the friction of the screw initially. The screwdriver you use should work without too much force, once you've loosened the screw, lightly press on the motor so it doesn't slip around.
Also, take off the spinner already and manhandle the prop if you have to, it's already broken anyways.
aerosoardude is offline Find More Posts by aerosoardude
Old Aug 10, 2011, 08:17 PM
turnerm is offline
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
Hmmm... Sounds like the screw is just really tight or you are using too small of a screw driver. Or... You've stripped the screw. Try a larger screw driver.
Old Aug 10, 2011, 08:20 PM
jimmy34256 is offline
Find More Posts by jimmy34256
Destructive Tester
jimmy34256's Avatar
Tampa, FL
Joined Apr 2008
Use a screwdriver with a larger body but with a tip that fits the screw. You have got to hold the motor and apply a little pressure to the screw as you untighten it. BTW the 5030 works better than the stock and is only a buck
jimmy34256 is offline Find More Posts by jimmy34256
Old Aug 10, 2011, 08:25 PM
telos81 is offline
telos81's Avatar
Joined May 2007
Yeah ... I have to agree - I've been using 160 Hyperions with the Y connnector (glenn's from rc-connectors.com) and the performance is noticeably better even compared to the stock 120 it comes with ... I tried to use e-flite 150s with the connector, but the performance was weak and they were pretty warm to the touch (almost hot) after just 4 minutes of flight.
Hyperions are just great batteries. All the report are 100% true
Old Aug 10, 2011, 08:34 PM
Joined Sep 2003
I got the 5030 prop on, but it just seemed harder to do than what it should have been.
Now just waiting for the wind to die down.
Old Aug 10, 2011, 08:51 PM
3dFlyer88's Avatar
Joined Apr 2007
what y connector are we speaking of?
im also on the fence about the 5030 prop. Do we think its a decent option or maybe someones using another prop of some sort?
Discussion ParkZone Ultra Micro T-28!!! THE Owners Thread!!!! RM_Sparks Micro Ready-to-Fly 10739 Jul 18, 2016 12:27 PM
Official Parkzone P-51 Owners Thread - Part 2 monitor Parkflyers 2602 Jun 15, 2014 04:51 PM
Discussion UM beast, Now your talking qman Micro Ready-to-Fly 102 Dec 22, 2010 10:39 AM
Discussion The first OFFICIAL Parkzone Sukhoi SU-26XP BNF by ParkZone Owners thread skyjet Micro Ready-to-Fly 2 Mar 19, 2010 03:00 PM
Official Parkzone P-51 Owners Thread monitor Parkflyers 913 Oct 04, 2005 09:02 PM
