Old Aug 10, 2011, 12:30 AM
maukabud is offline
Find More Posts by maukabud
HELP I AM BEING SET UP!!
maukabud's Avatar
United States, OR, Deschutes
Joined Jul 2009
Originally Posted by turboparker View Post
There's nothing quite like ending a flight with a nose-high, power-on approach....followed by a nice 'n greasy three-pointer.
With an airframe this draggy - the angle of approach better be steep if the power isn't on! Dead-sticking the Beast sorta reminds me of dead-sticking a Quicksilver MX ultralight. (The Beast isn't quite as bad, though.)
Joel
[OT] Haha I went up a few times in an MX...full scale...PIC never told me he was one of those nutball 'Nam Cobra drivers...man, what a ride...never knew an MX could sideslip down the grass runway, a foot off the deck, at full power! Luved it. Crazy guy flat spinned the thing from 5k AGL (with me "ghosting" on the controls)...didn't pull out till we were about 50 ft. above the desert...then right into a wild down-on-the-deck ride, twisting through the junipers at full power...very high "wow factor"...not to mention "tight sphincter factor".... [/OT]
Dang, FEDEX dragged down WTs' commendable speed on getting my wee Beastie out within an hour of ordering last Friday...it's still sitting in Syracuse as of TU 22:30 PST... ETA is Friday...they better get the lead out...
[Brando] ....the horror....the horror.... [/Brando]
Bud, rode-a-looping-roller-coaster-all-day-to-compensate Bud
('twas fun)
maukabud is offline Find More Posts by maukabud
Old Aug 10, 2011, 02:21 AM
aerosoardude is offline
Find More Posts by aerosoardude
Its not that windy...
United States, CA, PORTER RANCH
Joined May 2007
Originally Posted by binaryclock View Post
I'm a computer/electrical engineer so I have no problems with making my own packs as I have the experience and proper equipment. I'll check out All e RC, thanks!...
...Also, instead of making your own packs, why don't you just buy the already made 2s 180mah pack?...I figure there's a reason, something I'm missing here
I too asked this question and, other than the issue with the stock connector, part of it is balancing. The ones that come pre-built do not have a balance tap. Personally, I'd make 1s packs and then an adapter to use for the beast, this way, you can balance using your own charger per each cell or parallel charge. You also don't need to keep using the kind of lead that the beast uses. One adapter to make the batts into series, and you're pretty much set.
Plus, the 1s batts can come in handy in the future for other micros.
Originally Posted by telos81 View Post
Yeah, that was the problem - I was on low rates ... I got it programed with a RTF TX though, so I've got it set now ...
Based on advice, I've set flaps to 35% down - and I know that they should only be used on the recommended 60% low rate setting to insure I never push an aileron servo past 100% travel.
I can't figure out how to setup a second, stronger flap setting though (while reducing aileron travel to keep them below 100%) - I found instructions for a DX6i, but I'm using a DX7. it seems like the programing might be different?
Here's what I do to make sure I can use the rest of my aileron travel.
_______FLAP______ELEV
Norm_DN 75%____0(for now, haven't set it up yet)
So let's say you have 75% for that.
Then go to a programming mix, any one really.
AILE->FLAP ON
RATE:+75%
_____-75%
SW: FLAP2
OFFSET: -2(this can change, play around with it)
(ignore the underscore, only used that to make it look correctly aligned)
If you find that you have to use UP instead of DN to get the flaps to work, then just flip the + and - for each one. You also might have to adjust the 75 to a higher or lower digit, but its the same for both if you alter it, so if it happens to be 76, change both to 76. I use the servo travel screen to adjust it. You'll notice that your roll rate will not be as affected anymore, since no matter the setting, you still get to use ALL of your servo travel
Hope this works for you like it works for me!!
aerosoardude is offline Find More Posts by aerosoardude
Last edited by aerosoardude; Aug 10, 2011 at 02:28 AM. Reason: To align the settings right
Old Aug 10, 2011, 05:47 AM
IndyMatt is offline
Find More Posts by IndyMatt
Indianapolis, IN
Joined Oct 2010
I called the store and they matched Horizon's $99 price.
Originally Posted by dfitzsim View Post
Yeah I don't get it. That's on their website. Next time I go into their store I'm going to see if they sell it for the $99 price.
IndyMatt is offline Find More Posts by IndyMatt
Old Aug 10, 2011, 06:39 AM
telos81 is offline
Find More Posts by telos81
telos81's Avatar
United States, CT, Glastonbury Center
Joined May 2007
AILE->FLAP ON
RATE:+75%
_____-75%
SW: FLAP2
Thanks for the help!
I agree about the batteries too, I've been using a pair of 1-cell Hyperion 160s with the Y-adapter ... Best of both worlds
telos81 is offline Find More Posts by telos81
Old Aug 10, 2011, 06:55 AM
telos81 is offline
telos81's Avatar
Joined May 2007
Cool!!
I just did that and it works great! (I love the servo monitor screen don't even have to turn on the plane!)
Although, what is the offset? I'm not sure what that means?...
Old Aug 10, 2011, 08:09 AM
RealGambler is offline
Find More Posts by RealGambler
Way to many airplanes!
Canada, QC
Joined Oct 2009
Are these the cells you are using or recommend to make the pack?
http://www.allerc.com/hyperion-g3-cx...ll-p-5106.html
They are the right ones.... And as other have said, it's nice to have a little stash all the time. They make nice 1S batteries as well. So I always have a few ahead, and I can decide what I want to make later on. You may also want to get some 240mah (Sbach Stryker but ok in the Beast as well). And maybe some 120mah. Dang that hobby is costly!
RealGambler is offline Find More Posts by RealGambler
Old Aug 10, 2011, 08:47 AM
village_idiot is offline
Find More Posts by village_idiot
Inciting Riots
village_idiot's Avatar
Joined Dec 2006
When you guys come up with a working flaps/elevator mix would you please find the mods and tips summary thread I started and add the info so that other new people can find it more easily than searching through 300+ pages of chatter. Discussions of the tips can take place here but it would be really nice to have a short summary of each setting/procedure/mix/etc. in a single thread.
http://www.rcgroups.com/forums/showthread.php?t=1480171
village_idiot is offline Find More Posts by village_idiot
Old Aug 10, 2011, 09:08 AM
dfitzsim is offline
Find More Posts by dfitzsim
Joined Feb 2011
Interesting I'll have to see what my local hobby town has to say.
dfitzsim is offline Find More Posts by dfitzsim
Old Aug 10, 2011, 09:34 AM
joshuajcrouch is offline
Find More Posts by joshuajcrouch
United States, OR, Eugene
Joined Feb 2011
I tried the flaps today, but the elevator setting I put in was too much and pitched the nose down. I had 35% flaps and (down arrow) \/ 6 on my elevator. I think I'll try probably 2 or 3 on elevator next time.
My Beast needs 0 elevator compensation when dropping the flaps.
joshuajcrouch is offline Find More Posts by joshuajcrouch
Old Aug 10, 2011, 09:41 AM
IndyMatt is offline
Indianapolis, IN
Joined Oct 2010
Picking mine up today.
Old Aug 10, 2011, 10:00 AM
RCBABBEL is online now
Find More Posts by RCBABBEL
**I'm Battman**
RCBABBEL's Avatar
Twin Falls, Idaho
Joined Jan 2005
IM,
You are in for a treat.
Such a huge upgrade from 1S UMs!
Treat her well...
rc
RCBABBEL is online now Find More Posts by RCBABBEL
Old Aug 10, 2011, 10:08 AM
dfitzsim is offline
Joined Feb 2011
Dude your going to find that it far exceeds your expectations.
Amazing plane. I got mine the end of last week. I'm loving it.
Old Aug 10, 2011, 10:17 AM
ICU is offline
ICU
Find More Posts by ICU
ICU
Check out my Shapeways Shop
ICU's Avatar
Dallas,Tx.
Joined Apr 2007
As far as the flaps go.
When I set them up on my Sbach I put in 35% for the flaps and 16% UP elevator. And it would float in nicely, unless it was a little windy. When it was windy it would baloon up badly.
I haven't had a chance to try them out on the Beast yet but I would start somewhere around 8% on the elev and go from there.
ICU is offline Find More Posts by ICU
Old Aug 10, 2011, 10:51 AM
dfitzsim is offline
Joined Feb 2011
What rate do you guys charge your 2s beast batteries at?
Old Aug 10, 2011, 11:00 AM
DoomsDay is offline
Find More Posts by DoomsDay
DoomsDay's Avatar
Charlotte Douglas, NC
Joined Sep 2003
Depends on what brand. The eflight I just use their charger for it. But the hyperions I am charging at a little over 5c or at 1amp on the 180's. around 12 minute charge time and I am back in the air.
DoomsDay is offline Find More Posts by DoomsDay
Discussion ParkZone Ultra Micro T-28!!! THE Owners Thread!!!! RM_Sparks Micro Ready-to-Fly 10705 Jun 18, 2016 08:57 PM
Official Parkzone P-51 Owners Thread - Part 2 monitor Parkflyers 2602 Jun 15, 2014 04:51 PM
Discussion UM beast, Now your talking qman Micro Ready-to-Fly 102 Dec 22, 2010 10:39 AM
Discussion The first OFFICIAL Parkzone Sukhoi SU-26XP BNF by ParkZone Owners thread skyjet Micro Ready-to-Fly 2 Mar 19, 2010 03:00 PM
Official Parkzone P-51 Owners Thread monitor Parkflyers 913 Oct 04, 2005 09:02 PM
