Old Dec 25, 2012, 09:49 PM
Dlta Nvmbr Ynkee is offline
Find More Posts by Dlta Nvmbr Ynkee
Australia, QLD, Qunaba
Joined Dec 2012
They are centered on my aircraft must be different on the beast 3D to the V1
Dlta Nvmbr Ynkee is offline Find More Posts by Dlta Nvmbr Ynkee
Old Dec 25, 2012, 10:53 PM
turboparker is offline
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
As AP noted - all UMX Beasts come with symmetrical ailerons. The original Beast uses SPMAS2000L (non-differential) aileron servos. The Beast 3D uses SPMSA2030L AS3X-duty (non-differential) aileron servos. The SPMSA2030LO is the 70/30 offset servo that's used for differential ailerons on the Carbon Cub & MiG. Aileron differential is not desirable on purpose-built aerobatic planes because it only works when the plane is upright. It increases adverse yaw during vertical maneuvers & dramatically increases it during inverted maneuvers.
BTW - the original Beast also needed plenty of rudder in turns if you wanted them to look at all realistic. At least all four of mine did. AS3X doesn't get in the way during proper turns at all. It simply encourages you to develop proper flying technique in the first place by making improper turns look even worse than they normally do. You don't want to fall into the bank & yank trap & get into that old rut. Using rudder to coordinate your turns is considered to be an essential intermediate pilot skill. Learn it as soon as possible - before the bank & yank habit sets in.
Joel
turboparker is offline Find More Posts by turboparker
Old Dec 26, 2012, 05:12 AM
flypaper 2 is online now
Find More Posts by flypaper 2
I use foam to hold my hotglue
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
Yep, my mistake guys. Sorry about that. Should have taken them out of the box and took a second look. Got it mixed up with the Mig. Another old age brain phart..
Gord
flypaper 2 is online now Find More Posts by flypaper 2
Old Dec 26, 2012, 09:05 AM
Joined Jul 2009
Gord
No problem. I also get those every so often. Seemingly, more often as time goes by...
Joel
Old Dec 26, 2012, 03:24 PM
Huskee is offline
Find More Posts by Huskee
Huskee
Joined Aug 2012
Was there ever a consensus on the best battery aside from the EFlight pack? I'm going to make a batch buy specific for the Beast, and I know there's been some talk of Turnigys.
Huskee is offline Find More Posts by Huskee
Old Dec 26, 2012, 03:44 PM
erkq is offline
Find More Posts by erkq
United States, CA, Sebastopol
Joined Dec 2010
Absolutely! BabbelBatt's custom made Hyperions are the best performance/weight ratio. Then there are stock Hyperions, made with the proper UMX connectors now. Then there are Minivations, but I think those are over in the UK? And HobbyKing offerings are pretty good... the Nano-techs are decent and now come with UMX connectors, but only in the 180mAh size. Absolute, dead last in price/performance are the E-flight batteries.
If you really want some bang for your buck, get some 3S batteries for this Beast, as long as it's the AS3X version. Some run 3S without modification, some need more airflow and some need heatsinks on the ESC's FETs. But I think only one has smoked.
erkq is offline Find More Posts by erkq
Old Dec 26, 2012, 05:45 PM
Joined Jul 2009
Huskee,
I agree with Erkq. If you want the best performance you can get - just shoot RCBabbel a PM & order his super-light Hyperion packs. His Hyp 180 pack is the best for indoors, 3D, and flying close-in. The extra thrust-to-weight & speed of his Hyp 240 pack is great for pattern & IMAC-style flying. If you want to save a few bucks & don't mind an extra gram or two of pack weight - go with the factory Hyperion 180 and/or 240 UMX packs.
Another big plus with the Hyps is the 300+ cycle lifespan @ 5c charge.
Joel
Old Dec 26, 2012, 07:16 PM
kalmon is online now
Find More Posts by kalmon
Parkzone junkie
kalmon's Avatar
United States, MI, Grand Traverse
Joined Oct 2008
Gord
Joel
For the two of you:
Senior Moments by Golf Brooks - Call 352-391-0626 For Bookings & CD Sales! (3 min 22 sec)
-Brian
kalmon is online now Find More Posts by kalmon
Old Dec 26, 2012, 08:30 PM
ckleanth is offline
Find More Posts by ckleanth
If it has wings it will fly...
ckleanth's Avatar
United Kingdom, England, Birmingham
Joined Mar 2011
well actually there are Nano-techs 180mah, 260mah and 300mah available.
http://www.rcgroups.com/forums/showthread.php?t=1775728
I use the 260 with stock motor and prop and my beast although old it flies beautifully and does all the 3D stuff I ask it to do.
ckleanth is offline Find More Posts by ckleanth
Old Dec 26, 2012, 09:21 PM
erkq is offline
Joined Dec 2010
Thank you! I have the worst time with HK's Battery Heaven.
Old Dec 27, 2012, 01:43 AM
Joined Dec 2012
I noticed coming out of a big loop (I reduced throttle) the 2500kv motor seemed to over rev could this damage the motor ?
Old Dec 27, 2012, 01:55 AM
airpower is offline
Find More Posts by airpower
Have fun
airpower's Avatar
United States, CA, Mission Viejo
Joined May 2007
Over rev? No, but I have no idea what characteristic you are trying to describe? Do you just mean lots of windmilling under little to no power?
airpower is offline Find More Posts by airpower
Old Dec 27, 2012, 02:10 AM
Joined Dec 2012
Yes but it seems to do this exesivley
Old Dec 27, 2012, 02:17 AM
airpower is offline
Have fun
airpower's Avatar
Joined May 2007
It's fine, don't worry, it has no prop braking in default.
Old Dec 27, 2012, 02:45 AM
Joined Dec 2012
Discussion ParkZone Ultra Micro T-28!!! THE Owners Thread!!!! RM_Sparks Micro Ready-to-Fly 10708 Yesterday 09:07 AM
Official Parkzone P-51 Owners Thread - Part 2 monitor Parkflyers 2602 Jun 15, 2014 04:51 PM
Discussion UM beast, Now your talking qman Micro Ready-to-Fly 102 Dec 22, 2010 10:39 AM
Discussion The first OFFICIAL Parkzone Sukhoi SU-26XP BNF by ParkZone Owners thread skyjet Micro Ready-to-Fly 2 Mar 19, 2010 03:00 PM
Official Parkzone P-51 Owners Thread monitor Parkflyers 913 Oct 04, 2005 09:02 PM
