Old Nov 23, 2012, 01:44 AM
erkq is offline
Find More Posts by erkq
United States, CA, Sebastopol
Joined Dec 2010
Originally Posted by kalmon View Post
I use a large drop of CA on the hub to add weight. I've had to do this on a couple of my props.
-Brian
Yup... that's the method I was talking about. So you should do that on little props too. OK... thanks!
erkq is offline Find More Posts by erkq
Old Nov 23, 2012, 07:09 AM
SixDeuces is offline
Find More Posts by SixDeuces
Lawn Dart Specialist
SixDeuces's Avatar
United States, PA, Williamsport
Joined Jun 2006
Originally Posted by fooferdoggie View Post
my elevator servo has died or spazed out. only 5 flights on it the last I lightly stuck it in a tree. hard to wait 5 days to fly again only to discover the elevator was not working. playing with it with my finger it moved fully one way or the other but that was more of a spaz then anything else. I cleaned the servo with the cleaner I use on all my heli's and lubed it but nothing. So do I replace the servo or the board? and if the servo is this the right one
Replacement Servo Mechanics: 2.3-Gram 2030L
(SPM6836)
First, remove both servos, carefully clean the contacts, then reinstall. If that doesn't help, swap servo positions and see if the problem moves with the mechanics. (Unlikely.) If problem persists in the same side, the board is shot.
SixDeuces is offline Find More Posts by SixDeuces
Old Nov 23, 2012, 10:27 AM
fooferdoggie is offline
Find More Posts by fooferdoggie
United States, OR, Happy Valley
Joined Aug 2012
Don't you have to cut the wires on them? I have not taken the board out but I thought they were soldered on.
fooferdoggie is offline Find More Posts by fooferdoggie
Old Nov 23, 2012, 11:29 AM
erkq is offline
Joined Dec 2010
Nope. Little biddy plugs. They would never solder them on (I'd hope). Much too difficult replacing dead/defective servos for an end-user. It would be completely serviceable in the field.
Old Nov 23, 2012, 01:40 PM
ckleanth is online now
Find More Posts by ckleanth
If it has wings it will fly...
ckleanth's Avatar
United Kingdom, England, Birmingham
Joined Mar 2011
hi chaps. today was a bit windy and the top wing on my beast(pre 3d version) finally gave up and snapped in half. I was going o buy a replacement when I saw that from my local shop the 3d set is slightly cheaper and have bigger control surfaces. on the other hand the tail & elevator control surfaces on the 3d also seem bigger.
questions are
-is my observation correct about the control surfaces or the difference of the basic and the 3d is the acx3 alone?
-has anyone fitted the 3d main wing set on the basic beast (and possibly would require fitting the elevator as well) or shall I stick with the old profile?
ckleanth is online now Find More Posts by ckleanth
Old Nov 23, 2012, 02:16 PM
erkq is offline
Joined Dec 2010
questions are
First, terminology, because it gets confusing about what you're discussing:
The 3D is a "basic" model. "Basic" just means it comes without charger, battery, Tx. I think you're referring to the v1 Beast when comparing. All control surfaces are the same size. So, given that, swapping wings would be pointless.
Old Nov 23, 2012, 03:00 PM
ckleanth's Avatar
Joined Mar 2011
yea I've got the v1... I wasnt sure about the "basic" terminology
right the difference is price but from what you're saying the V1 and the 3D a/c its exacly the same shape/size but with the as3x receiver?
Ultra Micro Beast Wing Set 14.24
http://www.wheelspinmodels.co.uk/i/121759/
UMX Beast 3D Wing Set 12.34
Old Nov 23, 2012, 03:04 PM
erkq is offline
Joined Dec 2010
Yes... just different markings.
Old Nov 23, 2012, 03:05 PM
ckleanth's Avatar
Joined Mar 2011
cheers
Old Nov 23, 2012, 04:16 PM
Joined Aug 2012
too many of my parkzone and blade helis have soldered on servo's
Old Nov 23, 2012, 05:01 PM
erkq is offline
Joined Dec 2010
Really! Yeah... I'd say even 1 is too many!
Old Nov 23, 2012, 11:22 PM
Joined Aug 2012
No plugs. Only the aileron servos have plugs. What a pain to take it apart. I will never complain about replacing a heli frame. Far easier. Now I have to solder those tiny wires
Old Nov 24, 2012, 06:53 AM
msdumo is offline
Find More Posts by msdumo
Canada, ON, Calabogie
Joined May 2011
What's on the brick stays on the brick
msdumo is offline Find More Posts by msdumo
Old Nov 24, 2012, 10:22 AM
Joined Aug 2012
at least a servo is only 6.00
Old Nov 24, 2012, 10:31 AM
erkq is offline
Joined Dec 2010
I have poor reading comprehension... apparently. Sorry... didn't register that it was on the brick. Duh...
Discussion ParkZone Ultra Micro T-28!!! THE Owners Thread!!!! RM_Sparks Micro Ready-to-Fly 10659 Today 07:54 AM
Official Parkzone P-51 Owners Thread - Part 2 monitor Parkflyers 2602 Jun 15, 2014 04:51 PM
Discussion UM beast, Now your talking qman Micro Ready-to-Fly 102 Dec 22, 2010 10:39 AM
Discussion The first OFFICIAL Parkzone Sukhoi SU-26XP BNF by ParkZone Owners thread skyjet Micro Ready-to-Fly 2 Mar 19, 2010 03:00 PM
Official Parkzone P-51 Owners Thread monitor Parkflyers 913 Oct 04, 2005 09:02 PM
