Old Nov 18, 2012, 08:17 PM
walter3rd is online now
Find More Posts by walter3rd
I just want to go fly!
walter3rd's Avatar
United States, MD, Towson
Joined Aug 2012
thank you.
walter3rd is online now Find More Posts by walter3rd
Old Nov 19, 2012, 12:07 PM
shastamike is offline
Find More Posts by shastamike
shastamike's Avatar
United States, CA, Mt Shasta
Joined Jun 2010
Originally Posted by walter3rd View Post
quick question... after you plug in your battery to the plane and it does all its beeping do you wait more to let the gyro set up with the plane still or is it doing set up during the beeps? got in another 8 flights today. how much time can i expect out of hyperion 240 mah batts to a 80% run down? THANKS, WALT
I'm very careful about monitoring my batteries. I use Hyp 240 exclusivley in the Beast. My timer is set for 6 minutes. That averages very close to 80%. Flew in pretty heavy wind yesterday which uses up a bit more, I went to about 85% on one battery. I also had to make about 3 passes before I felt comfortable to land as the timer was beeping overtime. I go with 6 min. per Hyp240.
shastamike is offline Find More Posts by shastamike
Old Nov 19, 2012, 04:14 PM
walter3rd's Avatar
Joined Aug 2012
thanks. thats sounds good to me. im also running double hyperion 1s 180mah with a y harness to about 4 30-500 minutes and double 1s chicklets stick batteries to around 3 minutes! gotta use what i have. where can i get a rubber spinner for this plane? i saw a picture of one but dont know where it came from. thanks, walt p.s. ran 12 various batteries through her today at my favorite flying field. noticed there was a big glider stuck in the top of a tall tree. just a friendly reminder to stay focused on my new plane. getting better at flying in my landings under power.
Old Nov 19, 2012, 05:15 PM
w4yn is offline
Find More Posts by w4yn
United States, NC, Charlotte
Joined Jan 2007
To Unstick glider find an electrical line man or crew and see if you can borrow one of their Hot Sticks, I have some that go up to 50 feet!
Tim
w4yn is offline Find More Posts by w4yn
Old Nov 19, 2012, 10:12 PM
walter3rd's Avatar
Joined Aug 2012
its not my glider so i am not overly concerned but it looks like ugly trash in the tree at this point. im hoping the ownerwill get it down soon. bummer.
Old Nov 20, 2012, 01:07 PM
shastamike's Avatar
Joined Jun 2010
http://www.shapeways.com/model/30626...ductBox-search
There you go.'
MIke
Old Nov 20, 2012, 02:21 PM
IndyMatt is offline
Find More Posts by IndyMatt
Indianapolis, IN
Joined Oct 2010
Originally Posted by shastamike View Post
Those aren't rubber they are a hard plastic...still very very good!
IndyMatt is offline Find More Posts by IndyMatt
Old Nov 20, 2012, 02:50 PM
walter3rd's Avatar
Joined Aug 2012
looks like it is made to attach to the gws prop. are there any good spinners that press fit to stock prop? i guess ill just get a gws then huh?
Old Nov 22, 2012, 11:23 AM
SixDeuces is offline
Find More Posts by SixDeuces
Lawn Dart Specialist
SixDeuces's Avatar
United States, PA, Williamsport
Joined Jun 2006
Cure for wing waggle.
I haven't checked in here in a while, but I wanted to share a recent discovery with the Beast. I don't know if anyone has run into this before, but thought maybe I could save someone the headaches I went through.
Over the past month or so, I started to get some oscillation on the ailerons under power, aka wing waggle.
At first, I thought maybe a servo was getting jittery. I disassembled, cleaned and lubricated them both, but it didn't help. Next I spent time getting all of the slop out of the linkages, also with no result.
I did more testing, and realized it was only happening under power. (The plane flew nice and straight in a vertical dive.) So, I tried some other props. I replaced the stocker with a GWS 5030, which made things WAY worse. Next, a 5040, which made things a lot better. That pretty much confirmed my suspicion... an out of balance prop was creating a vibration that was getting into a harmonic with the AS3X as it tried to compensate..
When I got home, I balanced the motor, then the prop. The next flight was smooth as silk! Problem solved.
SixDeuces is offline Find More Posts by SixDeuces
Old Nov 22, 2012, 12:35 PM
pasantia is offline
Find More Posts by pasantia
United States, IA, Fort Madison
Joined Jan 2009
how do you balance motor?
pasantia is offline Find More Posts by pasantia
Old Nov 22, 2012, 12:40 PM
erkq is offline
Find More Posts by erkq
United States, CA, Sebastopol
Joined Dec 2010
Thank you... yes... this balance solution has long been known and discussed. AS3X definitely does not like vibes!
erkq is offline Find More Posts by erkq
Old Nov 22, 2012, 02:46 PM
SixDeuces's Avatar
Joined Jun 2006
I have a homemade balancer. It's essentially a basswood stick with one end clamped to a table. Connect the motor to the other end. At the very end of the stick, mount a small piece of mirror. Run the motor, and shine a laser pointer on the mirror so that it reflects on the wall. Any imbalance in the motor vibrates the stick, and the reflected laser will jump around on the wall. Then use small bits of tape to balance the motor.
This method works great, and it's easy to set one up for any size motor.
Old Nov 22, 2012, 02:58 PM
erkq is offline
Joined Dec 2010
That's a great method. But my motor runs smooth as silk. After I balance my prop's blades, then my magnetic prop balancer is telling me it is out of balance perpendicular to the blades. I know this can be a problem on larger props and wonder if we should use the same balancing methods they do to get that smoothed out too.
Old Nov 22, 2012, 09:36 PM
kalmon is online now
Find More Posts by kalmon
Parkzone junkie
kalmon's Avatar
United States, MI, Grand Traverse
Joined Oct 2008
I use a large drop of CA on the hub to add weight. I've had to do this on a couple of my props.
-Brian
kalmon is online now Find More Posts by kalmon
Old Nov 22, 2012, 11:54 PM
fooferdoggie is offline
Find More Posts by fooferdoggie
United States, OR, Happy Valley
Joined Aug 2012
my elevator servo has died or spazed out. only 5 flights on it the last I lightly stuck it in a tree. hard to wait 5 days to fly again only to discover the elevator was not working. playing with it with my finger it moved fully one way or the other but that was more of a spaz then anything else. I cleaned the servo with the cleaner I use on all my heli's and lubed it but nothing. So do I replace the servo or the board? and if the servo is this the right one
Replacement Servo Mechanics: 2.3-Gram 2030L
(SPM6836)
fooferdoggie is offline Find More Posts by fooferdoggie
Discussion ParkZone Ultra Micro T-28!!! THE Owners Thread!!!! RM_Sparks Micro Ready-to-Fly 10710 Today 08:25 AM
Official Parkzone P-51 Owners Thread - Part 2 monitor Parkflyers 2602 Jun 15, 2014 04:51 PM
Discussion UM beast, Now your talking qman Micro Ready-to-Fly 102 Dec 22, 2010 10:39 AM
Discussion The first OFFICIAL Parkzone Sukhoi SU-26XP BNF by ParkZone Owners thread skyjet Micro Ready-to-Fly 2 Mar 19, 2010 03:00 PM
Official Parkzone P-51 Owners Thread monitor Parkflyers 913 Oct 04, 2005 09:02 PM
