Old Oct 19, 2012, 04:47 PM
erkq is online now
Find More Posts by erkq
United States, CA, Sebastopol
Joined Dec 2010
Originally Posted by Kevin Greene View Post
But the UMX connector fits nothing else I have...All of the rest of my micros from other manufacturers have the JST connector so I adapted all of my planes to these...Additionally, almost all of the popular batts offer the JST connector as well..
Kevin
Well, your problem is that you don't have enough UMX planes and Blade helis! Buy more. Buy lots. Then the UMX connector will fit most of what you have.
erkq is online now Find More Posts by erkq
Old Oct 19, 2012, 05:19 PM
turboparker is online now
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
LOL!
I see that we used the same fix! Now I put the UMX connector on my other stuff that uses the same size packs. I prefer a single connector on the small stuff for the weight & space savings, but I won't give up balance-charging because I charge my packs at 5c+.
Joel
turboparker is online now Find More Posts by turboparker
Old Oct 19, 2012, 05:24 PM
erkq is online now
Joined Dec 2010
Originally Posted by turboparker View Post
LOL!
Joel
Yes... when it comes to the 3S stuff I have balance taps on them. It's a "must".
Old Oct 19, 2012, 05:39 PM
flypaper 2 is online now
Find More Posts by flypaper 2
I use foam to hold my hotglue
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
I use the MiniDeans as it's what's on all of my indoor goodies. I just soldered to the two outside wire if the existing connector.
Gord.
flypaper 2 is online now Find More Posts by flypaper 2
Old Oct 19, 2012, 08:29 PM
crvnation is offline
Find More Posts by crvnation
Joined Sep 2012
Exactly. Not like 6-batts-at-a-time UMX parallel charge cables are expensive or hard to come by, either. I don't need/want an extra balancing plug hanging off such small batteries, anyways.
crvnation is offline Find More Posts by crvnation
Reply With Quote  (Disabled)
Old Oct 19, 2012, 08:53 PM
IndyMatt is offline
Find More Posts by IndyMatt
Indianapolis, IN
Joined Oct 2010
I may try these. It's just too bad they have a 2C max charge rate.
Edit: I just weighed my Hyperion 2S 240mAh packs and they are 15.4g. HK says these 300's are 17g. Have you weighed them? Not that much of a difference, but they're not the same weight according to HK's site.
I soldered the UMX connector to my 300 35C packs and left the JST plug on them. In that configuration the packs were 16.8, 17.2, and 17.4.
IndyMatt is offline Find More Posts by IndyMatt
Old Oct 19, 2012, 09:02 PM
kalmon is offline
Find More Posts by kalmon
Parkzone junkie
kalmon's Avatar
United States, MI, Grand Traverse
Joined Oct 2008
I finally was able to get video of a KE spin (0:24) and a Lomcevak (0:09) on my B3D. I've had better KE spins but it this at least shows it is possible.
Short E-Flite UMX Beast3D Flight (1 min 4 sec)
had a couple Takeoffs and landings at the end as well. Sorry for the crappy camera angle, had to set the camera on a folding chair to get the video.
-Brian
kalmon is offline Find More Posts by kalmon
Old Oct 19, 2012, 09:41 PM
Joined Jul 2009
Brian,
Very impressive! I've managed to pull off a few Lomcevaks with the B3D (not consistently, however), but I've never managed to do a KE spin with it. Did you use the standard entry? How much throttle were you using?
Joel
Old Oct 20, 2012, 09:14 AM
Kevin Greene is online now
Find More Posts by Kevin Greene
United States, TN, Jackson
Joined Mar 2007
How does the charger know which cell is lower or higher than the rest when only one sensor wire is used???...The charger sees the 6 batts on as one pack and will only charge to an "average" of the cells leaving some over charged and some under charged...I'll stick with monitoring/charging my packs individually......
I have multiple chargers and now about 30 battery packs...I can take 3 chargers to the field and I'll bet that I never run out of battery packs for the day...
Kevin
Kevin Greene is online now Find More Posts by Kevin Greene
Old Oct 20, 2012, 10:16 AM
Joined Sep 2012
I've been charging multi-cell UMX batteries in helis and planes for years. I've never had an unbalanced pack at the end of a charge with the stock setup. I do also storage charge them individually after ever flying session.
Old Oct 20, 2012, 11:47 AM
kalmon is offline
Parkzone junkie
kalmon's Avatar
Joined Oct 2008
Brian,
Joel
I used a full scale entry for them Pull vertical with just under enough power for a hover, so basically slowly decelerating in the vertical. On the way up positive snap roll switching to negative snap same side. If you do it right the positive snap will get 3/4 of the way around as the momentum is running out and your the plane will be about 45* or so angle on its side, then abruptly give full negative elevator and increase power to 3/4+ while keeping the rudder and ailerons hard over. If the plane's vertical energy was right it will VERY HARSHLY tumble once then the nose will drop down as it does the second tumble. It should be in a KE 10*-15* nose down attitude I usually have to add throttle to keep the KE spin going. As you can see it spins at about this attitude. Be high as you do it as it falls quite fast and recovery takes another 15-20ft under the best conditions, ask me how I know. I'm just glad my grass was long that day!
The only other thing I've noticed is that it is not in a perfect KE it is actually about 5*-10* to the inverted side, still very close though.
-Brian
Old Oct 20, 2012, 11:55 AM
erkq is online now
Joined Dec 2010
Kevin
When they're all hooked up in parallel, they all balance out between them so they all get the same treatment from the charger. I went through the same skepticism you are going through now. There is much discussion and testing of this over in the batteries/charger forums. The easiest thing to do is just trust us: It works! I've been doing it for years with no problems at all. It's a great trick!
Old Oct 20, 2012, 01:12 PM
kalmon is offline
Parkzone junkie
kalmon's Avatar
Joined Oct 2008
The only dangers are plugging in a full pack and an empty pack at the same time or forgetting to plug in every battery and charging the other as if all 6 were plugged in. (not a problem in auto-sensing chargers like the FMA multi4/10/powerlabs)
-Brian
Old Oct 20, 2012, 02:54 PM
erkq is online now
Joined Dec 2010
-Brian
There is argument and measurements that show the combo of full/empty packs is not harmful. I'm not sure I buy it either. I think it's something to be careful of.
Your second point is entirely correct! I plug each battery separately into its dedicated plug and read the balance information first. Then I plug them all in to charge and hopefully all make the same electrical connection they just made individually seconds before. But there is that chance...
I also check them individually before I fly just in case one got missed that way. It hasn't happened so far, but it's always a possibility.
Old Oct 20, 2012, 03:33 PM
shastamike is offline
Find More Posts by shastamike
shastamike's Avatar
United States, CA, Mt Shasta
Joined Jun 2010
http://youtu.be/ZAwMWgPAXy4
-Brian
Very impressive video. Wish you had a hat cam and a little better background as it is hard to see. I'd have to say I've never seen flying quite like this. I'm wondering:
1. Which holes the ailerons are set in? And I would assume that the rudder and elevator are set in the stock position (maxed out, closest holes).
2. The battery/motor seems very lively. Is it stock motor and what battery?
Thank you for posting most amazing flying, not to mention bumpiest landing strip ever.
shastamike is offline Find More Posts by shastamike
Discussion ParkZone Ultra Micro T-28!!! THE Owners Thread!!!! RM_Sparks Micro Ready-to-Fly 10691 May 16, 2016 08:15 PM
Official Parkzone P-51 Owners Thread - Part 2 monitor Parkflyers 2602 Jun 15, 2014 04:51 PM
Discussion UM beast, Now your talking qman Micro Ready-to-Fly 102 Dec 22, 2010 10:39 AM
Discussion The first OFFICIAL Parkzone Sukhoi SU-26XP BNF by ParkZone Owners thread skyjet Micro Ready-to-Fly 2 Mar 19, 2010 03:00 PM
Official Parkzone P-51 Owners Thread monitor Parkflyers 913 Oct 04, 2005 09:02 PM
