Old Oct 16, 2012, 11:50 PM
TurboRacer is online now
Find More Posts by TurboRacer
TurboRacer's Avatar
United States, CT, Waterbury
Joined Oct 2002
So I did the BEast 3D to Sbach conversion.. I like the way it came out other than one thing.. I guess I have the aileron servos plugged into the wrong ports, because it was reversed.. I used my TX to reverse that channel, and it worked how it should... EXCEPT that the AS3X is now working backwards on the aileron channel..
Is there any way to reverse this through programming?! I'd rather not open it back up, it looks so nice and new!!!
Thanks for any help.
TurboRacer is online now Find More Posts by TurboRacer
Old Oct 17, 2012, 12:42 AM
airpower is offline
Find More Posts by airpower
Have fun
airpower's Avatar
United States, CA, Mission Viejo
Joined May 2007
Sorry man, even if you reprogrammed the brick you would still have to open her up.
airpower is offline Find More Posts by airpower
Old Oct 17, 2012, 06:12 AM
TurboRacer's Avatar
Joined Oct 2002
Gah.. Figured! Ok, guess I'm getting out the xacto
Old Oct 17, 2012, 06:53 AM
kalmon is offline
Find More Posts by kalmon
Parkzone junkie
kalmon's Avatar
United States, MI, Grand Traverse
Joined Oct 2008
no.Open it up!!! The two ways to reverse the servos both require unplugging them from the RX.
Slice the tape, don't peel it off.
Pro tip: When you reassemble use a slightly smaller pieces of tape and lay them on top of the existing tape you sliced. Now every time you take it apart you can safely peel that off and not pull the paint.
-Brian
kalmon is offline Find More Posts by kalmon
Old Oct 17, 2012, 08:22 AM
w4yn is offline
Find More Posts by w4yn
United States, NC, Charlotte
Joined Jan 2007
New Trick
Went to fly last night, above a certain speed both wings started flapping like a duck flying! Landed checked and all looked fine did same on next flight. Looking closer I found prop adaptor wobbling and about to break. I guess vibration from prop excited natural frequency of wings and started them flapping!!
Luckly I found this before prop launched itself!!
Tim
w4yn is offline Find More Posts by w4yn
Old Oct 17, 2012, 09:23 AM
TurboRacer's Avatar
Joined Oct 2002
Alright! Sliced the tape and switched the servo plugs. Good idea on the tape placement!!
Took her out before work this morning. Almost no breeze. She flew fantastic!! Great power, very stable. I like it! Inverted high alpha slow & low looks awesome!
Tried the 3S and it shot off like a rocket. Then it cut out. Was able to re-arm and land without incident. But i dont want that to happen again! Are people putting heatsinks on them? Not sure where to start, guess i have some searching to do. Until then I'll stick to 2S!
Old Oct 17, 2012, 10:03 AM
rtbates is offline
Find More Posts by rtbates
Joined Mar 2010
I just received my Beast last night and I find that the battery tray sucks. No way to put a larger battery in so I took it out. Now I have a very nice place to put my 350 2s that I use on the Gee Bee...Laid on the long edge and pushed back through the the fuse slot to the brick the cg seems pretty close... Finding cg is another issue... seems it very hard to balance level. Tip SLIGHTLY forward and it falls forward. Tip SLIGHTLY rearward and it tips rearward...
How in the world are you guys getting 3s in and maintaining CG?
rtbates is offline Find More Posts by rtbates
Old Oct 17, 2012, 10:12 AM
airpower is offline
Have fun
airpower's Avatar
Joined May 2007
If you shove it back enough the battery is right on the cg.
Old Oct 17, 2012, 10:15 AM
w4yn is offline
Joined Jan 2007
To assist with bigger battery one small detail I do is remove the retangular lock bar from cowl and replace with thin piece of balsa, helps with taller packs.
Tim
Old Oct 17, 2012, 10:22 AM
airpower is offline
Have fun
airpower's Avatar
Joined May 2007
I just removed the entire piece, my cowl holds tight enough with out it.
Old Oct 17, 2012, 10:46 AM
shastamike is offline
Find More Posts by shastamike
shastamike's Avatar
United States, CA, Mt Shasta
Joined Jun 2010
I can't get my Beast to balance either. Tips forward or back, but not balance. I guess that's just the nature of the Beast. I've let that go and just place the battery in a spot that flys the way I want.
shastamike is offline Find More Posts by shastamike
Old Oct 17, 2012, 11:23 AM
erkq is online now
Find More Posts by erkq
United States, CA, Sebastopol
Joined Dec 2010
Well, right... it's a case of unstable equilibrium when you are balancing it. You need to get it as close to the flying AOA and see which way it falls. Or you need to hang it by some point above its vertical COG.
erkq is online now Find More Posts by erkq
Old Oct 17, 2012, 11:24 AM
erkq is online now
Joined Dec 2010
+1 Been flying that way since v1.
Old Oct 17, 2012, 12:04 PM
shastamike's Avatar
Joined Jun 2010
Did not think of hanging it. Thanks.
MIke
Old Oct 17, 2012, 12:53 PM
rtbates is offline
Joined Mar 2010
Thanks guys for the info. BOTH on the removal of the hold down tab(not needed now that I got rid of the stock batt tray) and hanging it for cg...
Without the batt tray there is a surprisingly large area in the fuse for larger batteries.
Discussion ParkZone Ultra Micro T-28!!! THE Owners Thread!!!! RM_Sparks Micro Ready-to-Fly 10763 Sep 13, 2016 07:08 AM
Official Parkzone P-51 Owners Thread - Part 2 monitor Parkflyers 2602 Jun 15, 2014 04:51 PM
Discussion UM beast, Now your talking qman Micro Ready-to-Fly 102 Dec 22, 2010 10:39 AM
Discussion The first OFFICIAL Parkzone Sukhoi SU-26XP BNF by ParkZone Owners thread skyjet Micro Ready-to-Fly 2 Mar 19, 2010 03:00 PM
Official Parkzone P-51 Owners Thread monitor Parkflyers 913 Oct 04, 2005 09:02 PM
