The Beast uses UMX battery connector, I don't know if your 130X batts are the same, better check on that. I believe the stock battery is UMX type180mAH. http://www.allerc.com/hyperion-g3-cx...pi-6478_0.html I had a problem with the battery (Hype 240) rattling around in the compartment and had to wedge it in with a bit of thin foam like a foam plate foam. The Beast will keep you on your toes. I bounce it a lot on landing, so whatever you can do to correct that. Good luck and good flying to you. Let us know how it goes. ![]() Mike |
Joined Sep 2012
My Hyp 240's are 20 x 37mm. It's the thickness that is tight. Mine are 15 mm thick with velcro. I think that about 17mm is all you'll be able to fit. Someone else has tried these bigger batteries you have and should speak up.
Good luck with you're new plane. My Beast is in the hangar while I've been flying my new Sbach. Going to get The Beast out tomorrow and compare flight. In case you haven't seen the real Beast, may it and Bryan Jensen R.I.P. , here is a link:http://www.beastairshows.com/web/show-video.php?id=8 Mike |
![]() I think that I’ve flown it so much that the Velcro is probably worn out!
I hit a plane-eating tree today. Like a ten foot high bush. I couldn't climb it, and it wouldn't shake down so I was forced to knock it out with a stick - OUCH!
![]() Repairable? Probably. I am missing a pushrod, so I'll have to track that down, and it looks like it's out of stock in my neck of the woods. |
Latest blog entry: Dynam Me-262 Schwalbe in Flight
| Thread Tools | |
| Discussion ParkZone Ultra Micro T-28!!! THE Owners Thread!!!! | dkintx | Micro RTF | 9039 | Today 12:58 PM |
| Official Parkzone P-51 Owners Thread - Part 2 | monitor | Parkflyers | 2601 | Oct 15, 2012 05:41 PM |
| Discussion UM beast, Now your talking | qman | Micro RTF | 102 | Dec 22, 2010 10:39 AM |
| Discussion The first OFFICIAL Parkzone Sukhoi SU-26XP BNF by ParkZone Owners thread | skyjet | Micro RTF | 2 | Mar 19, 2010 03:00 PM |
| Official Parkzone P-51 Owners Thread | monitor | Parkflyers | 913 | Oct 04, 2005 09:02 PM |
