Here's a video of my "remaiden" after my replacement brick. Nothing special in terms of flying here, but it shows the model flying in windy condition. A real blast!
Latest blog entry: Dynam Me-262 Schwalbe in Flight
United States, TN, Jackson
Joined Mar 2007
Kevin |
Assuming that rudder throw is sufficient, difficulty with keeping the nose up in KE usually means that the CG is considerably forward of the neutral-handling point. Be sure that the CG is @ 19mm or slightly further aft. Quote:
There is more to this picture. Resolution is one thing. However, latency is often an even bigger deal than resolution - especially when flying planes that respond quickly to pilot input & when flying CP helis. A disconnected feel is typically caused by high latency, while an imprecise feel is typically caused by low resolution. There are often huge differences in latency between various transmitter models - even within the same brand. As one would expect - latency is usually inversely proportional to transmitter price. Joel |
Latest blog entry: Eflite UMX Sbach 3D on 3s - 2300Kv/5043...
United States, CA, Sebastopol
Joined Dec 2010
Joel |
Joined Mar 2007
I'm wondering if this has happened to any of you---I flew the 3D Beast first...I have the timer set to the same as my V1 Beast (7 minutes)...The battery in the 3D beast didn't last but 6 miuntes before I noticed a loss of power..I recharged the battery and then flew the V1 Beast...Flight time was @ 8 minutes before I noticed a power drop...
The logical thing is that the AS3X system definately consumes more power...Another thing...My V1 Beast is CONSIDERABLY faster than the 3D Beast...V1 has a 5043 prop and V2 has a 5030 prop but a higher kv motor...I'm going to install a 5043 prop on the V2 3D Beast to see if it picks up much speed....My V1 Beast not only has more speed but more vertical as well...I'm also going to tach the motors to see what they are turning... Kevin |
Joined Dec 2010
It was a good move. The AS3X definitely helps if the day is less than calm. Only problems for me is that the T-28 I find relaxing and durable. The Beast is well....the beast. Keeps me on my toes as it is so much faster if flown that way. The Beast isn't as durable for me. I've learned a lot about foam repairs from this forum and The Beast. The best for me is being able to point The Beast straight up, punch the throttle and aileron and watch it climb to what seem like infinity. ![]() Mike |
Bottom line, If you have a 2300kv motor put it in there with a 5043 prop. Power combinations in order of performance: First: 3000kv motor + 5030 prop Extremely close second: 2300kv + 5043 prop. Third: 2300kv with the 5030 prop Fourty Second: Stock 2500kv motor and stock 5x2.75 prop. ![]() As to draw yes AS3X sucks at least a minute out of the batteries while flying. -Brian |
J |
short answer: on that list it'd be fourth. Though there are other combinations I didn't list that could be better that that one.
Long answer: With high quality packs it is enjoyable to fly. But the plane just comes alive with either of the other motors. The 2500kv+5030 with BB hyp240s gives it unlimited vertical just not fast. Either of the other motors and it accelerates up! -Brian |
J |
| Thread Tools | |
| Discussion ParkZone Ultra Micro T-28!!! THE Owners Thread!!!! | dkintx | Micro RTF | 9047 | Today 03:15 AM |
| Official Parkzone P-51 Owners Thread - Part 2 | monitor | Parkflyers | 2601 | Oct 15, 2012 05:41 PM |
| Discussion UM beast, Now your talking | qman | Micro RTF | 102 | Dec 22, 2010 10:39 AM |
| Discussion The first OFFICIAL Parkzone Sukhoi SU-26XP BNF by ParkZone Owners thread | skyjet | Micro RTF | 2 | Mar 19, 2010 03:00 PM |
| Official Parkzone P-51 Owners Thread | monitor | Parkflyers | 913 | Oct 04, 2005 09:02 PM |
