Old Aug 18, 2010, 06:32 PM
qman is offline
Find More Posts by qman
qman's Avatar
Wanaka, NZ
Joined Mar 2009
UM beast, Now your talking
http://www.modelflight.com.au/produc...NF-6419-6.html
qman is offline Find More Posts by qman
Old Aug 18, 2010, 06:47 PM
RealGambler is offline
Find More Posts by RealGambler
Way to many airplanes!
Canada, QC
Joined Oct 2009
WOWEEEEEEEE!
A UM with a brushless motor (180). Made by Eflite. Just as I was thinking it could be time to replace my 4-Site!
Is the AR6400LBL the normal long throw version of the AR6400??? Normally, I usually saw AR6400L for the long throw, so could this be a newer version with the brushless ESC onboard?
Very nice find!
RealGambler is offline Find More Posts by RealGambler
Old Aug 18, 2010, 07:06 PM
Cheese5 is offline
Find More Posts by Cheese5
Cheese5's Avatar
United States, CA
Joined Jul 2010
Yeah! Finally a brushless UM!!! Release of info to US should be tomorrow!
Cheese5 is offline Find More Posts by Cheese5
Old Aug 18, 2010, 07:13 PM
Canada, QC
Joined Oct 2009
There's really nothing anywhere about a AR6400LBL on the web...
Now crossing fingers that it's really a AR6400L with the brushless ESC built-in. It's driving an Eflite 180 (30W), so it could be 5amps.... No more brushed motors that have a relatively short life. No more "where do I stick that ESC without getting in the way of the servos...."
So, let's go AR6400"L"ongthrow"B"rush"L"less
Qman, you should change your title to something like: "UM beast by Eflite, now you're talking". Otherwise, in about an hour there will be 3 more threads about this nice plane.
BTW, the 180 brushless motor is "ideal for 3D models 2–3 oz (55–85 g), and sport and scale models 3–6 oz (85–170 g)" while the flying weight for this little beast is only 67g. Tons of power!
Old Aug 18, 2010, 07:16 PM
Cheese5 is offline
Cheese5's Avatar
United States, CA
Joined Jul 2010
Wow a clear canopy! A new RX(fingers crosses), Brushless micro, lipo battery inside the canopy, and it looks like a gws prop! But the flight time is less than the micro t-28 on the specs 6 minutes vs 5 minutes. I think I will pass on the trojan and save up for this brushless micro!
Old Aug 18, 2010, 07:26 PM
darksiede is offline
Find More Posts by darksiede
Foaming at the mouth..
darksiede's Avatar
USA, KS, Topeka
Joined Jul 2008
Specs list for EFLU4080
Wingspan 14.7 in (374mm)
Overall Length 15.7 in (400mm)
Wing Area 83.8 sq in (5.41 sq dm)
Flying Weight 2.36 oz (67g)
Motor Size 180BL Brushless Outrunner, 2300Kv (included)
Radio AR6400LBL 6CH Brushless ESC Receiver (included)
Trim Scheme Colors Black, Red, Gold
CG (center of gravity) 18mm from Leading Edge of Bottom Wing
Prop Size 5 x 2.75 in (127mm x 70mm)
Recommended Battery 2S 7.4V 120mAh Li-Po (included)
Aileron Yes
Elevator Yes
Rudder Yes
Throttle Yes
Flaps No
Retracts No
Approx. Flying Duration 5 minutes
Scale Ultra Micro
Charger Celectra 2S 7.4V DC Li-Po Charger (included)
Steering Yes
Experience Level Intermediate
Recommended Environment Indoor/Outdoor
Is Assembly Required No
2s, 180 brushless outrunner and a new specified brick.. AR6400LBL
Long throw, Brushless and setup for 2s! Should make for a great fall if they get that sucker out! Makes all my research into inrunners the obvious choice, but 1s is completely moot now..
Ah well..
~Kev
darksiede is offline Find More Posts by darksiede
Old Aug 18, 2010, 07:29 PM
LunaRendezvous is offline
Find More Posts by LunaRendezvous
Registered Drug Free
LunaRendezvous's Avatar
Joined Jan 2009
Crikey you were quick off the mark I wonder how long it will be before there's an "Official Parkzone UM Beast Future Owners" thread
LunaRendezvous is offline Find More Posts by LunaRendezvous
Old Aug 18, 2010, 07:32 PM
Cheese5 is offline
Cheese5's Avatar
United States, CA
Joined Jul 2010
The Bl motor is a direct drive(see the pictures). THe micro trojan then should be the last brushed micro made by HH.Wonder how much it would cost? $120? $150? It has to be under $200. Too bad this is a 2S battery. I will have to start to stock up on high quality 2S batteries.
Old Aug 18, 2010, 07:37 PM
Joined Jan 2009
lol.. Someone actually started a new thread, pity it's not a Parkzone bird
Old Aug 18, 2010, 07:40 PM
Cheese5 is offline
Cheese5's Avatar
United States, CA
Joined Jul 2010
Parkzone just released their micro T-28 which should be the last brushed airplane! Now every micro should be brushless from now on!
darksiede's Avatar
USA, KS, Topeka
Joined Jul 2008
Nope, buy the adapters to just plug 2 packs in series together.. then you can still use your 180 hyperions etc etc just tied together to make instant 2's packs, that pop apart and charge as 1s!
~Kev
Old Aug 18, 2010, 07:49 PM
Cheese5 is offline
Cheese5's Avatar
United States, CA
Joined Jul 2010
Yah thanks! Just waiting for the HH website to show the micro beast. 6hrs to go in CA!
Old Aug 18, 2010, 09:56 PM
Canada, QC
Joined Oct 2009
Battery inside the canopy is great because it's hidden. But this is only a 120mah 2S battery, and it does look very thight. Doesn't look like you can enlarge the space by cutting extra foam either. Somehow, I think I would rather have it under the plane, which allow for a better selection of batteries. Currently, I have some 200mah and 360mah batteries, and looking at the picture, even my 200mah do not look like they will fit.... Not even sure two of our 1S batteries would fit either. Not on top of each other, and side by side may be very thight.
But hey, no matter what, it does look like a very nice plane! The next few weeks, or months will be long for sure.
Old Aug 18, 2010, 10:12 PM
Canada, QC
Joined Oct 2009
Another interesting fact...
The prop is a 5 x 2.75 in (127mm x 70mm) almost the same as the Mustang or the 4-Site. Though, it's on a 180 size brushless!
When you look at most of the 2S conversions on the existing UM right now, particularly the Sukhoi, quite often a 5030 is used because it's more than powerfull enough. The Beast has a 5027! Most people have used a brushless motor that are way less powerfull than the 180 (saving weight) and have been able to use propeller with way more torque than a 5030 and the results were mind blowing.
So, with a brushless 180, I suspect that just changing the propeller will transform the Beast into a rocket. Next step? Attempting 3D at warp speed I guess...
Old Aug 18, 2010, 10:13 PM
GBX is offline
GBX
Find More Posts by GBX
GBX
Illinois
Joined Jan 2005
Oh Yeah !!!!!!!!!!!!!!!!!!! Bipe . . Brushless... Bind and Fly..... Kick A@@
GBX is offline Find More Posts by GBX
Discussion Make a flying wing out of your crashed PKZ UM Sukhoi! bluefisherking Scratchbuilt Indoor and Micro Models 211 Feb 22, 2012 08:33 PM
Discussion The "Whats In Your Maintenance Hangar Right Now???" Thread hbsurfer Electric Plane Talk 263 Mar 29, 2011 01:44 PM
Now I know what you guys are talking about ErnieR High Performance 6 Jun 08, 2001 10:27 AM
