Old Jun 28, 2003, 08:54 PM
rtp70 is online now
Find More Posts by rtp70
Soil Penetration Tester
United States, AL, Madison
Joined Jun 2003
First pictures for Slow Stick
Maiden flight of the Stick went off without a hitch. Very nice slow flying plane. Had to wait for the winds to die down this evening in order to try the camera. The pictures are in an area of new construction in our subdivision. Did notice the pictures taken with the motor off are the best. Have a penCam coming with the Wild Moose switch installed and the whole process should be easier.
Rick
rtp70 is online now Find More Posts by rtp70
Old Jun 28, 2003, 08:55 PM
rtp70 is online now
Joined Jun 2003
2nd picture
Old Jun 28, 2003, 08:58 PM
rtp70 is online now
Joined Jun 2003
oops! Forgot to add the picture.
Old Jun 28, 2003, 09:00 PM
rtp70 is online now
Joined Jun 2003
The camera installation.
Old Jun 28, 2003, 10:00 PM
Caveman is offline
Find More Posts by Caveman
Oops, reversed elevator!
Caveman's Avatar
Newmarket, Ontario, Canada
Joined Jan 2003
Look like you have a great start. I don't mind a bit larger pictures. Post more pictures.
Pin
Caveman is offline Find More Posts by Caveman
Old Jun 29, 2003, 05:23 AM
rtp70 is online now
Joined Jun 2003
Thanks Pin. I have tried posting a larger picture but everytime I do the site says my post is too large even though the picture size is well below the max allowable. I keep reducing the size until the site accepts it. I'm sure I'm doing someting incorrectly here. Not sure what it is though. I've compared my file size with postings from other members and I'm well within the same parameters. I must have something set wrong in my profile.
Rick
Old Jun 29, 2003, 11:45 AM
Caveman is offline
Caveman's Avatar
Joined Jan 2003
The file size limit is 100K. Your picture file size is only 16k.
Should be able to post larger size...
Old Jun 29, 2003, 12:39 PM
Karl Bē is offline
Find More Posts by Karl Bē
29 rods from you in western WI
Karl Bē's Avatar
Joined Jan 2003
Always save in jpg format, and watch out, some editors will give you a readout on pixel count, which isn't the same as the file size. The pixel count of your first picture is about 68k, though as Caveman says, it's only about 16k file size.
Edit your pictures with an editor that allows you to choose the jpg compression ratio. I use PhotoShop Elements (~ $90), and the jpg save options allow jpg quality levels of 1 to 10 as well as an estimate of the file size at each level. For rcgroups.com posting, I usually resize to around 600 pixel width to be browser-friendly, then save at a compression to yield no more than 60-70k file size.
Karl
Karl Bē is offline Find More Posts by Karl Bē
Old Jul 08, 2003, 02:35 PM
samhoff is offline
Find More Posts by samhoff
samhoff's Avatar
Sheridan, WY, USA
Joined Jul 2003
Photo Editing Software
May I recommend Irfan View? It's free and readily available all over the web; specifically go to:
http://www.tucows.com/preview/194967.html
I use this for all my photo editing. It is completely free, easy to use, small. . . everything a guy could want.
Sam
samhoff is offline Find More Posts by samhoff
Old Jul 08, 2003, 06:39 PM
gmaster is offline
Find More Posts by gmaster
Hooked Heli Human
gmaster's Avatar
Western NC
Joined Dec 2002
is your slow stick basically stock or did you do any mods? man i want to get one of these and get started doing this.. awesome
gmaster is offline Find More Posts by gmaster
Old Jul 09, 2003, 06:00 AM
rtp70 is online now
Joined Jun 2003
Hi gmaster,
The Stick is basically stock. I did replace the aluminium wing tubes with brass and epoxied the nylon wing stiffeners to the leading and trailing edges. The motor is also held on with 2 screws through the mount. Performance wise it is box stock. The construction mods were preformed at the advice of several members here. Lots of good knowledge in the forums for sure.
Rick
Old Jul 09, 2003, 07:41 AM
gmaster is offline
Hooked Heli Human
gmaster's Avatar
Western NC
Joined Dec 2002
thanks rick.. ok i went to LHS and they said they sold out but they are reordering and i can just order one when im ready if they dont have any instock.. its $34.95 and a flight pack is about $75 but comes only with a 400mah batt pack.. so.. i started a thread in slow flyers to get suggestions on parts/mods i should pickup.. if anyone has any suggestions please feel free to post.. thanks..
thread here
Discussion First time motor build, for Slow Stick chuckand Electric Motor Design and Construction 3 Feb 18, 2006 11:01 PM
Bomb Drop device for Slow Stick - pictures wanted sgil2001 Parkflyers 20 Jan 27, 2006 10:51 AM
Ready for slow stick maiden, her are the stats pictures to follow md2b1dy Parkflyers 16 Jan 19, 2004 01:22 PM
Battery To Heavy For Slow Stick?? AL TYLER Parkflyers 6 Sep 04, 2002 01:37 PM
What size ESC for a Slow Stick? Bob Mintus Parkflyers 3 Sep 02, 2002 02:42 AM
