Old Aug 18, 2010, 08:55 AM
SidewaysLS4 is offline
Find More Posts by SidewaysLS4
Redjestird Youser
SidewaysLS4's Avatar
Joined Jan 2009
Hobbypartz Optima 450 1380kv on 6S?
Think this motor will be ok on 6S?
http://www.hobbypartz.com/75m36-opti...20-1380kv.html
Has no voltage specs listed...but speed wise on 6S I think it should be ok. Are there any motor changes that make them able to handle higher voltages, or should this motor be ok? It's going into a heli
SidewaysLS4 is offline Find More Posts by SidewaysLS4
Old Aug 18, 2010, 10:31 AM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
It is rated for 244W max... so on 6s (~22.2v) theoretically you will be limited to 11A! Kv x V is over 30,000rpm... can it cope?
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Aug 18, 2010, 11:12 AM
Redjestird Youser
Joined Jan 2009
Ah ha, watts. So I'd be real close to the limit in normal flight...and blow though it on full collective. Drat. (Trying to avoid paying $55 for a Scorpion, and I still could use a lower kv than the Scorp's 1630 for their version of this type motor). Thanks!
Old Aug 18, 2010, 06:14 PM
mattyhawk is offline
Find More Posts by mattyhawk
Fill'er Up!
mattyhawk's Avatar
Joined Oct 2008
Have you seen this motor?
http://www.hobbyking.com/hobbyking/s...trunner_1860KV
Bit higher kv, but similar specs and size
mattyhawk is offline Find More Posts by mattyhawk
Old Aug 19, 2010, 06:09 AM
Redjestird Youser
Joined Jan 2009
Thanks, but too high kv for what I'm doing. I'm looking for around 1850 headspeed on 11T/6S, as it is already flying at 18amp on 3S on the bare airframe w/ballast...hence the desire to go 6S as there will be 2 3S packs on board. Ideally I'd be looking for 1200-1300kv in a 450 size format, with an 11T+ pinion for quietness. FWIW, Hobbypartz has one similar to that, but with a 2mm taller stator presumably giving more torque, sold as 1800kv, actually 1700kv, worked pretty well on a 3S ship doing the slow-motion deal.
Old Aug 19, 2010, 10:17 AM
Fill'er Up!
mattyhawk's Avatar
Joined Oct 2008
Cool, well, from what I have seen just poking around, based on your specs, the best thing is just go with the scorpion. Its really not that expensive, especially since its a proven motor for your application.
Discussion Stay Updated! Become a Fan of HobbyPartz.com on Facebook hobbypartz HobbyPartz.com 11 Dec 05, 2015 11:35 AM
Discussion HobbyPartz.com - Sell what you advertise on your website!! makeitworst HobbyPartz.com 32 Oct 08, 2010 04:06 PM
Discussion Optima 6s on here Bubba Gump Radios 13 Mar 31, 2010 05:13 PM
Question hobbypartz.com - no feedback on item purchased - worried! maxxer2.5 Vendor Talk 2 Jul 27, 2009 09:26 PM
Discussion Is there a scorpion for 450's on 6S ?? mattijs321 Mini Helis 1 May 28, 2009 06:43 AM
